RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: FMBB
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  112 113 [114] 115 116 117 118 119 120 121   next >   >>
Login
RE: WACO YMF - 6/20/2007 12:06 AM
Stickbuilder
Score: 346
Last Login: 5/21/2013
Status: offline
It was a labor of love..... The G-23 should pull the model with good authority, since it was originally designed for a .60 to .90 2 stroke. The 16" diameter prop won't look large enough, but should fly the model well. Most of the models that I have built or seen come in at about 14 1/2 pounds or more. They will fly well at 18 pounds though, so don't worry too much about it. Yoou should be under power on your landings and shoot for a wheel landing and then cut power and let the tail settle. Don't get too slow when you are close to the ground. It is very easy to run out of altitude, airspeed and ideas at the same time.
Bill, AMA 4720
WACO Brotherhood #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to SuperCub Man)
       Post #: 2826
RE: WACO YMF - 6/20/2007 12:18 AM
SuperCub Man
Score: 105
Status: offline
Thanks Bill - that's what I hoped. I have a fat and heavy Supercub that has an old wheasy Quadra 41 in it. At 20lbs. it flies just like a cub should and loves wheel landings under power. Also have it on B-USA floats and ditto. A friend is running a G26 with an 18 X 6 prop and it moves his ARF (ugh) Super Stearman quite nicely so I will probabl;y put an 18" prop on this. Makes it a little more scale too as you suggest.
Thanks for the info - now to work on the wood list!
Jim
< Message edited by SuperCub Man -- 6/20/2007 12:27 AM >
Jim, MAAC #5343
WACO Brotherhood #56
Hide Signatures
(in reply to Stickbuilder)
       Post #: 2827
RE: WACO YMF - 6/20/2007 3:28 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
Jim---to add to Stickbuilder's reply, I have a G-26 in mine, and it flies great, plenty of power at 18 pounds flying weight (that was probably my plane he was talking about) It's solid as a rock in the air, and glides like one when you cut the throttle . All I had to do to fit mine was two holes in the bottom of the cowl for the spark plug and plug wire, and a small cutout along the Slimline Pitts muffler. The Quadra 35 is much bigger, and you'll have to make a big hole for the cylinder head. The G-23 should fit fine, about like the -26. You have to use the short insulator block between the carb and cylinder, and there's no room for a velocity stack. Here's a few pics of my installation, with and without the cowl:
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
       Post #: 2828
RE: WACO YMF - 6/20/2007 9:08 PM
Hughes500E
Score: 105
Status: offline
Replied to your PM, sorry for the delay!
Hide Signatures
(in reply to damifino)
       Post #: 2829
RE: WACO YMF - 6/20/2007 10:46 PM
skylarkmk1
Score: 210
Status: offline
All,
Since this is an YMF thread, figure I will get started posting YMF pictures. These pictures are of a 1987 YMF Classic, built by Waco Classic Aircraft Corp, NC 14081, Owned by Robin Williams of Traverse City, Michigan. The YMF Classic is most similar to the original YMF; the YMF Super has many more changes.
The subject of lower wing fairings keep coming up so in this installment I will show what I have, other sections I will cover later.
Picture 1 – Rear view showing the wing walk on the left.
Picture 2 – Lower Cowl, exhaust ports, Landing Gear Center mount, and general underbelly with landing gear fairings.
Picture 3 – Top view of the right wing fairing with notch.
Picture 4 – Rear view of the left underside of the wing fairing
Picture 5 – Leading edge of wing, trailing edge of landing gear fairings. Note the lower Red light and antennas
Picture 6 – Low shot of the same area. This joint on many models is neglected to facilitate mounting of the lower wing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to Hughes500E)
       Post #: 2830
RE: WACO YMF - 6/20/2007 11:59 PM
skylarkmk1
Score: 210
Status: offline
Jay,
Here's proof that we wore our WACO Brotherhood shirts proudly. A shot of Ken checking out the the "Skybolt" . UPF-7 NC 39748 in the background just finished refueling.
Click for fullsize
Hide Signatures
(in reply to skylarkmk1)
       Post #: 2831
RE: WACO YMF - 6/21/2007 12:34 AM
SuperCub Man
Score: 105
Status: offline
Thanks khodges that's great! Those pix will go a long way to helping me with the motor mount. I have ordered a G26 muffler a minute ago for the G23 I will use. (G23 pipe points back?? - G26 pipe points down!) I do have a "wraparound" style like you have used, but I think the stock muffler will fit inside the cowl and I'm going to see if I can do some creative welding for the pipes to approach a scale look and thus avoid cutting out for the muffler.
Great shots skylarkmk 1. Thanks
Jim
Jim, MAAC #5343
Hide Signatures
(in reply to khodges)
       Post #: 2832
RE: WACO YMF - 6/21/2007 12:37 AM
SuperCub Man
Score: 105
Status: offline
Stickbuilder - what's the drill for getting a Waco Brotherhood number? And Damifino - any Tee Shirts left?
Jim
Jim, MAAC #5343
Hide Signatures
       Post #: 2833
RE: WACO YMF - 6/21/2007 1:56 AM
kestrel0222
Score: 105
Last Login: 12/6/2011
Status: offline
Damifino,
I received my tee's today....The first word that came to me was...... AWESOME!!!!!!!!!!!! Thanks again for taking the time and effort to make these tee's available to all of us!!!! I, for one, am VERY impressed with the quality of the artwork!!!
Tom - AMA Member Since 1973
WACO Brother #39
Hide Signatures
       Post #: 2834
RE: WACO YMF - 6/21/2007 2:20 AM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
SuperCubMan- Speaking for Stickbuilder, you just asked for and will receive a number. PM me with your shirt size(s) and I'll see what I've got left. I'll also include payment info in the reply.
Thanks to our 'roving reporters' for the fantastic pictures. You guys.............!
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
       Post #: 2835
RE: WACO YMF - 6/21/2007 2:29 AM
skylarkmk1
Score: 210
Status: offline
All,
Some of the other Waco’s present; 3 UBF-2s, NC 2091K (Tan/ Brown trim), NC 12002 (Red/Silver w/Black trim) and NC 155Y – TEXACO 17 (Red/White) all based at CCA, NC 155Y was flown a couple of times. QCF-2, NC 9220J (Cream w/Red trim) proves you can get 2 people in the front cockpit, but it’s cozy. ASO NC 662Y (Blue/Silver w Red trim) #26 on take off, is part of the Air Tours Group (note the under camber of the wings). A static replica of WACO #1, the “Cootie” was built full size (22’ wing span) and brought to the Museum by Roger Teagarden. Plans are to cover the wings, finish the fuselage and put the correct prop in place (the prop shown was put on as a joke).That is the Museum’s JYM to the right. ASO (Black/Silver) NC 701E was flown in from Ft. Worth, TX and is headed back to California. The pretty Red w/Black trim Taperwing, NX 149TW, was actually built by the owner, Robert Patrick, in 2005 and flew in from central Idaho. This pretty well covers the Wacos that flew in; the museum has about 14 more that were on display in the museum hanger. The 2008 AWC Fly In will again be held at Creve Coeur Airport about the same time next year.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 6/21/2007 2:34 AM >
Hide Signatures
       Post #: 2836
RE: WACO YMF - 6/21/2007 5:04 AM
Skinny Bob
Score: 100
Last Login: 3/3/2013
Status: offline
John, what a great job of photography!, it is very evident you knew what you wanted to shoot. Also, a great job explaining your every shot. You have answered many Brotherhood questions I'm sure. I have saved every picture you have posted. Thanks again.
Skinny Bob
Skinny Bob - AMA 713081
WACO Brotherhood #10
Hide Signatures
       Post #: 2837
RE: WACO YMF - 6/21/2007 6:06 AM
khodges
Score: 126
Status: offline
Here's some more bits and pieces of what we saw this past weekend. In most of the pics I have collected on WACO's from the 'net, most have had wooden props. Not so this weekend; only one WACO showed up with a wood prop, and only after he had been there, left, and returned. There were a couple of variable pitch jobs with the counterweights, and several more that are ground adjustable for specific pitch, but the most popular (and desired by all who don't have one) was the Curtiss-Reed propeller. It is polished steel, and the cross-section of the prop is very thin. They are made flat and then formed to the desired pitch. Most who used them said they will "flatten out" with full power, lowering the effective pitch and making it into a good pulling prop, and then, when power is reduced to cruise, the blades return to their nominal set, making a good "speed" prop. I asked a couple of people about it, both said they weren't sure if it was an intended design characteristic, but it sure did work well.
John had the much better camera for action and telephoto shots. Mine worked fairly well for static and interior because it was wide angle. The interiors and instrument panels on these planes were also works of art, excellent examples of form following function, with a little art deco thrown in. The cabin WACO's reminded me of the interior of a 40's era Hudson, or Studebaker. Wood trim galore, tweed and wool fabrics, and even leather in the SRE. The windows had cranks to roll them down, just like a car. Even the DH-4 had a simple elegance to its business-like panel. And on the other end of the spectrum, the Curtiss Robin in the museum was the essence of spartan simplicity. Below are, left to right, the VKS interior, the SRE interior, the DH-4, and the Robin: Below that are the different props we saw, variable, ground adjustable, wood, and Curtiss-Reed:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 6/21/2007 6:42 AM >
Hide Signatures
(in reply to Skinny Bob)
       Post #: 2838
RE: WACO YMF - 6/21/2007 6:21 AM
skylarkmk1
Score: 210
Status: offline
Bob,
Thanks. There was so much going on it was hard to keep up everything going on. I did have one goal in mind and that was to get good pictures of an YMF and I believe I accomplished that. My second goal was to get a few shots of each Waco that flew in for the weekend and I managed to do that. The rest was a bonus.
Besides the Wacos and the DH-4 with Desmond Penrose (a highlight in my opinion), there were many other aircraft that flew demo flights. Everything from a J-3, an L-4B, an L-16, a Fairchild 24, Fairchild 71, the numerous PT-17s, 3 Ercoupes, a Travel Air 4000, A Monocoupe, 2 Cessna 195s, a Pete-N-Paul, a Swallow, a few Pitts, Christen Eagles, an Acro Sport and then the heavy metal military aircraft. An AT-6 painted all yellow “Yahoo”, an F-51D Mustang (painted as “Petie 2nd”), the big 6 man Skyraider all decked out with rockets and finally a Russian L-29 Jet Trainer. Plus wandering around all the hangers and seeing what was inside each one. Planes just sitting, planes in pieces, planes being restored and planes were being polished. I am not forgetting all the modern metal skin General Aviation Aircraft, just ignoring them for now.
I think one of my best memories will be of watching Ken trying to take it all in as well. He was like a big kid in a candy store not knowing which way to turn or what to grab first, he was practically jumping up and down with excitement. Thanks for coming out to the Fly In and palling around with me, I know you enjoyed it as well.
Hide Signatures
       Post #: 2839
RE: WACO YMF - 6/21/2007 6:34 AM
khodges
Score: 126
Status: offline
Bits and pieces, redux. There was some model cabin WACO in a hangar for restoration; the wings were in process of re-covering. I shot a couple of pics from the tank well of the top wing, into the interior of the structure. The wing had been covered, ribs stitched and taped, and the cover shrunk, but not yet doped or painted. The stitching is fascinating. Another plane in a different hangar being restored a little at a time was a GeeBee R-2. Reminded me of a bumblebee, no way the thing can fly That's a P&W Wasp, Jr hanging on the front:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2840
RE: WACO YMF - 6/21/2007 7:00 AM
khodges
Score: 126
Status: offline
The one unchanging, universal attitude about the people we met this week was their absolute passion for their aircraft. One couple epitomized this with their "build book" they brought along with their beautiful YKS-7. The restoration took place in their house, from the living room to the garage, to the driveway. They had pictures of covering the wings and control surfaces in their living room; the fuselage resided in the garage. And when it came time to mount the engine, they hired a tow truck to lift it into place. He had been furloughed at work, so he rebuilt while she worked to support the family, as well as diving in on the weekends to help with the restoration.
The front view shows the much desired Curtiss-Reed prop.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 6/21/2007 7:03 AM >
Hide Signatures
       Post #: 2841
RE: WACO YMF - 6/21/2007 7:16 AM
khodges
Score: 126
Status: offline
John is right, I was like a kid at the zoo, pointing, oohing and ahhing. I've been to many airshows and museums, primarily warbirds from WWII and later; this was my first exposure to so much Golden Age and earlier stuff.
My last entry for the night: more interiors and instrument panels. I'm afraid I wasn't as good at writing down what was what as John was. No matter, they're all beautiful.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 6/21/2007 7:24 AM >
Hide Signatures
       Post #: 2842
RE: WACO YMF - 6/21/2007 7:53 AM
damifino
Score: 100
Status: offline
I have several XXL's and a few L's left. Get these while you can. PM me with your inquiries please.
Click for fullsize
Hide Signatures
       Post #: 2843
RE: WACO YMF - 6/21/2007 9:01 AM
skylarkmk1
Score: 210
Status: offline
Ken,
You gave me a bit of a challenge with the interior shots but here goes:
1- WACO UPF-7 NC39727
2- Fairchild 71 NC 9727 (photo1)
3- WACO UBF-2 NC 2091K
4- Swallow NC 979 (photo 2)
5- WACO UBA NC 13041
6- Stinson SR-6
7- Travel Air
8- Russian Shavrov-2 Seaplane (photo 3)
9- Stinson SM-8A
10- WACO QCF NC 12428
11- Russian Antonov AN-2P N 147AS (photo 4)
The shots of the wing interior are of the WACO YKS that I posted wing tip pictures before.
The Gee Bee will become an R-1/R-2 when completed as was done in 1933 after both the R-I and R-2 had crashed and they were put together.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 6/21/2007 9:38 AM >
Hide Signatures
       Post #: 2844
RE: WACO YMF - 6/21/2007 3:12 PM
Skinny Bob
Score: 100
Status: offline
Ken, sorry I left you out. I apologize. Your close ups will help us all with scale detail. I am very envious of you guys. What a treat to be able to see all those beautiful aircraft.
Thanks for all the great pictures.
Hide Signatures
       Post #: 2845
RE: WACO YMF - 6/21/2007 4:18 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: SuperCub Man
Jim
Jim,
If you will look back to page 110, you will find that you are WACO Brother #56. I used to update the roster when a request was made, but now I only move the roster to the current page every 10 pages. The size of the thing almost wipes out the entire page for posts, and so that is how I do it. Welcome to the Brotherhood. I hope you derive some good from it.
Jay,
Great job on the shirts....Mine came yesterday, and they not only fit well, but they look great. How about a second edition?????
All,
Jay and I have been talking about different editions, and not using the same colors twice. That way one would be able to recognize which edition of shirt that you are looking at. Janelle has already requested a shirt with her Red Waco, so I'm trying to talk Jay into doing that one next. I would like a windbreaker as well, so Jay, the ball is in your court.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 2846
RE: WACO YMF - 6/21/2007 4:54 PM
SuperCub Man
Score: 105
Status: offline
Bill - Thanks very much for accepting me into the Brotherhood. I have contacted Jay and will have a couple of shirts in a few days to wear with pride and proudly promote this noble interest. My buddy and co-WACO lover - who is now away on a well deserved holiday - will probably contact you on his return.
Regards
< Message edited by SuperCub Man -- 6/21/2007 4:57 PM >
Jim, MAAC #5343
Hide Signatures
       Post #: 2847
RE: WACO YMF - 6/21/2007 6:42 PM
mrdhud
Score: 110
Status: offline
ALL
I have run in to a bit of a problem with my wing tip. The pics not to good but I think you can see the w-13 T.E does not line up with w-7 & w-8 rib. I have checked to be sure the wing rib are the proper size. I don't see how the covering will work out if this is left as is. Is this a common problem?? At this point I can recut another one to match the ribs ends but don't know.
On a different subject I've been playing around with how to do the corrugated cover for the ailerons and have come up with this see what you think it is vary thin aluminum.
Click for fullsize
Click for fullsize
Click for fullsize
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
       Post #: 2848
RE: WACO YMF - 6/21/2007 7:59 PM
Hughes500E
Score: 105
Status: offline
Looks like you're already glued! I would just leave it and shape it when you pull the wing up. Even if you were confident, there is still a lot of shaping in that area when you're finished.
ALL:
I found this in my search to do scale panel lines. I thought I would share it on here!
http://www.tompierce.net/SBD/html/paint.htm
Hide Signatures
(in reply to mrdhud)
       Post #: 2849
skylarkmk1
Score: 210
Status: offline
Dan,
Take a look at the full size wing tip pictures I posted back on page 110, post 2728, they may help you visualize your situation. The plans show the Ribs W-7 and W-8 attached to W-13 in the rear and the Big Tip Block in the front. W-13 should project past W-8 slightly to blend in with W-9 Tip piece. The wing tips taper slightly on top from the last W-6 to the tip and much more on the bottom. The taper on the bottom (of W-13) of the real wing starts about halfway between the last 2 W-6 Ribs and continues to the tip. It seems to give that section washout as the bottom of the ribs taper up towards the rear more than at the front.
The aileron skins look very, very good, what thickness of aluminum are you using? Roof flashing I think is too thick but would be good because it can be obtained in small rolls for a continuous surface. You may need to make the wood core of your aileron a little smaller for the skins to meet at the trailing edge like they do on the real ones.
< Message edited by skylarkmk1 -- 6/21/2007 8:01 PM >
Hide Signatures
       Post #: 2850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.703RCU1
