RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  41 42 [43] 44 45 46 47 48 49 50   next >   >>
Login
RE: WACO YMF - 1/29/2007 2:22 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
Now for the "finished" piece. When you look at the prototype, the post exits perpendicular to the bottom edge of the fuse. The way the kit tailwheel mounts, it "leans" forward. In order to get the angle correct, the black tailwheel mount must be shimmed. I used a wheel collar to get the angle I wanted, when I do the permanent mount, I'll make a wooden wedge to place on top of the black mount so that the tailwheel pivot is at the proper angle. The same mounting screw holes can still be used. The hole in the fiberglass fairing must be elongated to clear the post and the brace.
It's obviously a heavier setup than the included one, but is lighter than you might think, because of all the solder and brass. The wheel is actually heavier than the entire bracket. Looks better than the one that comes with the ARF, don't you think?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
(in reply to khodges)
       Post #: 1051
RE: WACO YMF - 1/29/2007 3:16 AM
pimmnz
Score: 148
Last Login: 5/21/2013
Status: offline
Much better.
Evan, WB #12.
Hide Signatures
       Post #: 1052
RE: WACO YMF - 1/29/2007 4:38 AM
Ricatic
Score: 100
Last Login: 2/23/2012
Status: offline
Jeesh, you guys do some amazing stuff. I like the new tailwheel a lot. If you guys keep it up, it could be easier to build the kit. Oh, I forgot, thats your goal.
Ricatic
Waco Brotherhood #17
Hide Signatures
(in reply to pimmnz)
       Post #: 1053
RE: WACO YMF - 1/29/2007 4:46 AM
Stickbuilder
Score: 346
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Ricatic
Well, Now since you can get the plans from the AMA, and the parts for the build are posted right here, what's your excuse? Sheesh, you can even get the cowl from one of several companies, and the wheel pants as well. I'm doing a compression style sprung landing gear, and Khodges has come up with a tailwheel, I guess you'll have to build one.
Bill, AMA 4720
WACO Brotherhood #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to Ricatic)
       Post #: 1054
RE: WACO YMF - 1/29/2007 4:49 AM
Stickbuilder
Score: 346
Status: offline
Oh, forgot to post the gear drawing..... heh....heh The only thing that will be different is a longer threaded lug, and a compression spring under the nut.
Bill, AMA 4720
WACO Brotherhood #1
Click for fullsize
Hide Signatures
(in reply to Stickbuilder)
       Post #: 1055
RE: WACO YMF - 1/29/2007 4:52 AM
Stickbuilder
Score: 346
Status: offline
damifino, didja get the e-mail that I sentcha?
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1056
RE: WACO YMF - 1/29/2007 5:01 AM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
STICKBUILDER- I printed off pages 4 & 10 to see how they would come out. The 6" reference on page 10 printed 5 7/8" and the 3" ref. on page 4 printed out 2 31/32". Hopefully we can overcome this. I have not done the math yet but maybe the error is consistent and can be corrected with a copier set to enlarge 102.2% !! I know, I know! We can't do a tenth of a percentage point on a copier so 102% would suffice if the copier is capable, yes?
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
       Post #: 1057
RE: WACO YMF - 1/29/2007 5:21 AM
Stickbuilder
Score: 346
Status: offline
Maybe when I get to the website with ChrisMH, the thing will work as it's supposed to. Failing that, I can get all the pages copied, and send them snail mail. Of course, It could be because it's a jpeg file too. Is there another type of file that keeps the original dimension better?
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to damifino)
       Post #: 1058
RE: WACO YMF - 1/29/2007 5:53 AM
HarryJ
Score: 100
Status: offline
Here is the tailwheel I'm going to use on my Genesis Waco-YMF. Max dia 2 3/4", should be able to scale down to 1/5 scale.
Harry J
Waco Brotherhood Lucky #13
Hide Signatures
       Post #: 1059
RE: WACO YMF - 1/29/2007 5:56 AM
HarryJ
Score: 100
Status: offline
OOOOOOOOOOooooooooooooooops........................didn't get image.
Harry J
Hide Signatures
(in reply to HarryJ)
       Post #: 1060
RE: WACO YMF - 1/29/2007 6:00 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: HarryJ
Durn show-off
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1061
RE: WACO YMF - 1/29/2007 6:21 AM
HarryJ
Score: 100
Status: offline
Still operating with one hand, not much better than two at times.
Click for fullsize
Harry J
Hide Signatures
       Post #: 1062
RE: WACO YMF - 1/29/2007 6:36 AM
khodges
Score: 126
Status: offline
Master Chief-- If it's true that great minds think alike, could it also be true that Navy Chiefs and Air Force Lt.'s can do the same?
I have been thinking of the exact same thing for my plane (your sprung main gear struts) almost down to the eraser marks on the drawings . It's amazing, and more than a little scary. I feel a lot better about it now, I guess it WILL work.
Right now, my next change to the ARF will be the ailerons. The ARF's hinge in the middle, where the prototype's are top hinged. Since mine is gonna have a ton of differential, the small gap at the bottom of the aileron will be no problem. As you can see in the first pic, I filled in the "notch" on the top half and then sanded the hinge surface flat, at an angle to permit the surface to clear when the aileron is in the 'down" position. I'll also sheet the tops and bottoms with 1/64 ply and strip them with 0.080 in. styrene angles to make the corrugated surfaces. The prototype has 31 ribs per aileron (each surface), so it'll take a bunch of angles to do it.
As the late, great, Jackie Gleason used to say, "And Awaaaay We Go!"
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by khodges -- 1/29/2007 6:44 AM >
Hide Signatures
       Post #: 1063
RE: WACO YMF - 1/29/2007 7:25 AM
mmattockx
Score: 100
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: Stickbuilder
Bill, AMA 4720
WACO Brotherhood #1
Bill,
For what you want to do a pdf is the best choice. Get the copies scanned at 100% and they can be printed at 100% with no issues on most printers. JPEG's will never give you a consistent scaling from page to page...
Mark
Waco Brotherhood #4
Hide Signatures
       Post #: 1064
RE: WACO YMF - 1/29/2007 7:36 AM
damifino
Score: 100
Status: offline
#1- I got the e-mail. No problem making them, however, let me know Monday your thinking on the thickness. I'm thinking around .050 stainless. I'll knock the corners down so you won't get cut, OK?
#2- Landing gear spring eye is no problem either, gimme a bolt size and I'll do up a couple of long ones so you can cut to lenth.
#3- I can wait on the wood parts drawings. Hopefully the web page deal will work. If not, the USPS can bring them to me.
Flew my Super Skybolt again today. Man, what a YS 110 FZ will do for a .60 size bipe. Can you say B A L L I S T I C ? She'll fly nice and slow with that 14 X 7 MA 3 blade prop. Point her straight up at half throttle and she goes pretty darn good, WFO and she becomes real small, real fast, rolling along the way if you want! I know it's an ARF, but I gave her a little soul by cutting a forward cockpit and building a new instrument panel/cowling for the pilot. The windscreens were cut from the stock, full canopy and a little scrap vinyl and pinheads make up the 'upholstery'. Scale appearing gear struts have since been added as well as a smoke system. The exhaust exits the bottom of the cowling in a scale location via the stock YS muffler screwed to a custom header I made.
Also thrown in here is a picture of my modified Bruce Tharpe Venture 60 kit. I built-up and planked the foredeck and cowling, moved the cockpit back, clipped the wings, built the floats from a kit and scratch built the float struts, scale-like dual rudder steering and retract stuff. Flies real nice with a Saito .080.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by damifino -- 1/29/2007 7:41 AM >
Hide Signatures
       Post #: 1065
RE: WACO YMF - 1/29/2007 4:24 PM
Michaelj2k
Score: 100
Status: offline
quote:
ORIGINAL: Hughes500E
Looks good Jim,
I must of overbuilt mine
So I'm looking at the template you showed me and on my manual, page 39 shows the blisters in the exact same locations as my glass cowl in the pictures above. I am unsure as to why Pica would do this but if your guys' plans and templates are different than mine, then we found another difference in the age of these kits
That explains why my 1/6th is the same as this one as well, NUTS!
Guys,
If you look at the drawing of the blister locations Hughes500E posted in message #1042, you will see that the top of the cowl as indicated on the drawing is actually 180 degrees off. On a radial engine, the #1 cylinder is always at the top. So when mounting the cowl, make sure that the two blisters for the #1 cylinder are at the top and not the bottom as indicated by the drawing.
< Message edited by Michaelj2k -- 1/29/2007 4:26 PM >
“He’s crazy Lew, he builds toy airplanes”.
Capt. Frank Towns - Flight of the Phoenix
Hide Signatures
(in reply to Hughes500E)
       Post #: 1066
RE: WACO YMF - 1/29/2007 6:04 PM
ChrisMH
Score: 100
Last Login: 3/7/2013
Status: offline
To: CHRISMH,
I have the fuselage parts traced, and ready to send to you for posting on the website. I need your e-mail address since I cannot e-mail a website. The first posting has 16 pages of full size parts. Each page has a size reference drawn. If it does not copy at the size indicated, you will need to correct the part before cutting. All parts show the dimension of the material, and also the kind/s of material used. The modification/s for using a radial mount are indicated, as is the stock part configuration for those who wish to use the Maple engine bearers. Also the provisions for making the tank a rear loader are shown as well. This is a major undertaking, and I sure hope that some of you build one. It was worth the time spent. This one won't die.
Bill,
AMA 4720
WACO Brotherhood #1
Sorry, Bill, didn't touch the Internet over the weekend
Send anything you want posted to: hogancm@gmail.com and I'll put it up right quick!
Chris
WACO Brotherhood #15
Chris Hogan
WACO Brotherhood #15 - http://www.houseofmoy.com/waco
Hide Signatures
       Post #: 1067
RE: WACO YMF - 1/29/2007 11:06 PM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: Michaelj2k
Guys,
I think that is an illusion; if you considered the blisters that are closer together as a cylinder pair, then you're right, but it's actually the blisters that are further away from each other that constitute a cylinder pair. Most all the pictures I have of YMF's all show the blisters essentially the same distance apart all around the cowl. It would actually depend on the model, and the engine used, as to the proper spacing of the valve blisters, and the Jake's valve train is fairly evenly spaced.
Click for fullsize
Hide Signatures
(in reply to Michaelj2k)
       Post #: 1068
RE: WACO YMF - 1/30/2007 2:45 AM
Hughes500E
Score: 105
Last Login: 5/23/2013
Status: offline
That's the whole idea of my post:
in order to build this Pica model scale, you have to use the Cowl with the grouped blisters like the picture I posted.
This Pica model is scaled after the Waco YMF-3 NC-14031
If you want it to be scale and use blisters that are spaced equally all the way around, don't use the #'s NC-14031 on it.
As far as I know there are only two kits available, the blue one and the red and white one.
I know about the blue one and I just bought a kit of the red and white one. I was hoping the #'s were different but it too is NC-14031
Anyone have a kit or a set of plans with different #'s??????
Hide Signatures
       Post #: 1069
RE: WACO YMF - 1/30/2007 4:38 AM
flyguy888
Score: 100
Last Login: 4/1/2013
Status: offline
I just pulled up som pics of the NC-14031 and in the pictures it shows both types of blister layout. The oldest black and white photos show equal spacing, the newer color ones show grouped. Obviously it was fitted with a different cowl at some point because maybe it had a different engine put in or somthin. Point being if the full scale had different ones you can't go wrong having one or the other.
http://www.nationalwacoclub.com/f3f5album/
< Message edited by ronj10 -- 1/30/2007 4:40 AM >
If you love to build you have to pay the price
Waco Brother #7
Hide Signatures
       Post #: 1070
RE: WACO YMF - 1/30/2007 4:43 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: ChrisMH
Chris
Okay Chris, Yo now have the e-,ailed parts tracings. Let's see what you can do with them....
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
(in reply to ChrisMH)
       Post #: 1071
RE: WACO YMF - 1/30/2007 4:47 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: khodges
And as the late (Greater) John Wayne once said,........."NOT HARDLY"!!!
The very Idea an Air Scout Butter Bar, in the same general area of a Master Chief, and one who was Chief of the Boat as well.....The very idea.....
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1072
RE: WACO YMF - 1/30/2007 4:58 AM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: khodges
Khodges,
I just printed the photo of the, "Shaky Jake", and checked the spacing on the rocker boxes. On the Jacobs engine the rocker boxes are spaced dead on evenly both between cylinders and on the same sylinders. It would then follow that the YMF cowl had the blisters evenly spaced, while the UMF would have used the paired blisters. I can't see where it would make a great difference, since this is at best a stand-off scale model. Pica stated that they did not have to deviate from the scale outline, but there are enough items where ease of building would preclude this from ever being a Top Gun caliber model. Please, let's not have a general falling out over anything as trivial as this. Me? I like them both.
Bill, AMA 4720
WACO Brotherhood #1
Hide Signatures
       Post #: 1073
RE: WACO YMF - 1/30/2007 5:04 AM
Hughes500E
Score: 105
Status: offline
I'm not sure the conversation would turn negative, it's important, however, I do stand corrected in light of the above, many thanks.
Hide Signatures
       Post #: 1074
RE: WACO YMF - 1/30/2007 5:29 AM
damifino
Score: 100
Status: offline
STICK- You think the .050 stainless will be okay? Oh, I'm kinda partial to the number 21. You think I am worthy of the Brotherhood???....... I own One, I've ridden in One and I've got the ball'sa to build One.........
Hide Signatures
       Post #: 1075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
