Stickbuilder
Score: 346 Joined: 11/20/2005 Last Login: 6/18/2013 From: Leesburg,
FL, USA Status: offline
quote:
ORIGINAL: damifino STICKBUILDER- I know you are covered up. When you have time how about posting an overview of your tips, mods, improvements to the PICA 1/5 WACO? Especially helpful are those things that will apply to us scratch building these birds who have had no experience with the kit. I know we are getting closer and closer, a small step at a time, to making this thing a 'virtual kit', so the more people we have building it, the larger the pool of knowledge. Patterns will be refined, hardware will be (is) available, and before we know it there'll be a WACO in every shop. Well, you know what I mean..... By the way, I made a wing alignment fixture from .060 aluminum which I would like to make available as a laser cut item. Will probably be easier to use than a pasteboard one. What do you think, Brothers? STICKBUILDER will have, in a few days, stainless steel replacements for the plastic 'L' brackets that came in the PICA kits for cowl mounts, etc. If they work OK they too will be available. Geez, let me see if I remember it all... 1. Make a dent in the trash can with part #F-1, and make one from 1/4"ply. 2. Follow suit with former #F-4B, and make one from 1/4 or 5/16th ply. Do not cut the tank access hole, and drill a hole large enough to get your fuel lines through. 3. Make the tank floor 1 1/4" wider,, because you will not be using the maple engine bearers. 4. Relieve former #F-7B to enable you to install the fuel tank. 5. Replace the 1/4" square stringers back to Former #F-9B with 1/4" square hardwood, splice in 1/4" square balsa (use the lap joint method) for the remainder of the fuselage stringers. 6. Make a new Former F-14B from 1/4" ply. You will be mounting a 1/2A or e.p. nosegear mount to this former. Wings: When building the wing center section, do not use the W-10, W-10A, W-11, W11A as drawn. Instead make new ones from 1/8" ply, only make them go from the center of the wing, out at least 3 ribs into the wing. (you will need to cut the spar slots in these ribs to allow the longer wing joiners to fit. When completing the top wing center section, do not sheet the top until you decide on the incidence. At that time you will need to drill the mount blocks, and install T-nuts. Then you may add the sheeting to the top of the center section. When you cut the ribs for the bottom wing, use a forstner bit, and with the ribs stacked, and aligned from the rear main spar, drill a 1//2" hole in all the ribs to allow you to install a paper tube for the aileron wires to travel through. Make the aileron door mounts from 5/16" hardwood, and install them outboard of the interplane strut mounts. Allow sufficient room for the doors to mount into place, and still be flush with the bottom of the ribs. I will do photo's. That should keep you busy for a wiile. Bill, AMA 4720 WACO Brotherhood #1
_____________________________
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
