Stickbuilder
FL, USA Status: offline
quote:
ORIGINAL: Hughes500E Add me to the list of 1/5th Waco builders Scratch building this one from Pica plans and templates, even bending my own wire LOL So far I am really enjoying it. I did get the wing ribs laser cut though I have a Saito 170 3 cylinder that I am wanting to use but, the rail mount construction has me worried a bit. Don't want to add too much weight adapting a firewall etc. May just go with a 1.25 single. Hoping it flies as well as my 1/6 Dave Platt YMF that I sold! You don't appear to be too far along to change the firewall. Use the forward former (i will look up the number if I need to, but replace the stock former with one that you cut from 1/4" ply. eliminate most of the maple engine bearers, but dead end them at the back of the new firewall. Then dummy up your engine, add your blind nuts, and you are home free. The balsa block fuse end will be epoxied to the new firewall, and the rest is easy. I do this mod to all my 1/5th WACO's and I use the OS 1.60 twin for power. The triple Saito should be an outstanding choice for this bird. E-mail me if you don't understand what I told you, and we can either go back and forth in that medium, or we can do it on the phone. I'll talk you through it. It's worth the effort. Bill, AMA 4720
_____________________________
It's easy, just glue all the pieces together, and sand off everything that doesn't look like an airplane.
