RE: WACO YMF    Gallery
Logged in as Guest
Users viewing this topic: dadrivet
    Search This Thread
Printable Version
Graupner Vintage glider- Amigo 4 - ARF
Seller:  cat-boi
Details:   $98.46   |  5/23/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  610 611 [612] 613 614 615 616 617 618 619   next >   >>
Login
RE: WACO YMF - 8/29/2012 5:18 PM
jmdunstan
Score: 100
Last Login: 3/6/2013
Status: offline
tmac:
I sent one of the decal sheets from the kit to them.  When I ordered my graphics I told Cal-Grafx  there would probably be strong demand for graphics for this model.  When I received my graphics, I sent them a message advising that I would advertise their product on this forum.  I expect that if you e-mail them and ask about a set of decals for the PICA 1/5 scale WACO YMF-3, they will be able to quote a price from the files they created for mine.
Good luck,
Jim
Hide Signatures
(in reply to nine o nine)
       Post #: 15276
RE: WACO YMF - 8/29/2012 7:44 PM
Errol Levin
Score: 100
Last Login: 5/24/2013
Status: offline
Tmac
I was going to go for the four servo route, but hiding the servo wires to the top wing successfully presented a bit of a problem. So, two servos and counter weights is the route I chose.
The plane was designed that way by Peter Barth.
Thanks guys for all your input.
Regards
Hide Signatures
(in reply to tmac48)
       Post #: 15277
RE: WACO YMF - 8/30/2012 2:20 AM
ceije
Score: 100
Last Login: 5/22/2013
Status: offline
Errol, yes we did talk about the counter weights a while back but I went to the four servo system. I found that the paino hinges even with a lot of work still tend to be a little stiff for just two servos. Yes, there are those that will say it is over kill for a 1/4 scale bird. Building is always a learning platform...
Tmac, thanks..
Chris melhus, ceije 196
Hide Signatures
(in reply to Errol Levin)
       Post #: 15278
RE: WACO YMF - 8/30/2012 8:21 AM
nine o nine
Score: 105
Status: offline
Don't know if you've permanently installed your piano hinges yet Cejie. If not you could try what I did. I pulled the hinge wire and replaced it with a slightly narrower guage wire. The slop is negligible but the free swing of the hinge is now perfect. Mitch
Hide Signatures
(in reply to ceije)
       Post #: 15279
RE: WACO YMF - 8/30/2012 1:00 PM
ceije
Score: 100
Status: offline
Mitch, Dan had suggested the same proceedure and had shown me his. I did try this but the wire would only budge about 1 1/2 in. Before it would break off, I don't see any reason to cut up the rest of the hinge. I did soak the hinge in W-D 40 and with a little back and forth flexing it is very close to the results of changing the wire.
Regards,
Hide Signatures
       Post #: 15280
RE: WACO YMF - 8/30/2012 2:03 PM
tmac48
Score: 105
Status: offline
Chris what material is your piano hinge made out of? I was able to get some aluminium hinge and have not had any binding issues at all.
tmac
Hide Signatures
(in reply to ceije)
       Post #: 15281
RE: WACO YMF - 8/30/2012 7:18 PM
Errol Levin
Score: 100
Status: offline
Hi Ceije
I'm confused. Did you not get Kavan pinned hinges for your ailerons with your kit. Why are you using piano hinges?
Errol
Hide Signatures
(in reply to ceije)
       Post #: 15282
RE: WACO YMF - 8/30/2012 9:31 PM
ceije
Score: 100
Status: offline
Tmac, the piano hinge I'm using is Brass colored metal with a metal rod. I haven't been abler to find aluminum hinge here.
Errol, yes I did receive those hinges in the kit. But in building scale the full size plan uses piano hinge and i' duplicating it for scale, most all in their build have changed to piano hinge.
Ceije,196
Hide Signatures
       Post #: 15283
RE: WACO YMF - 8/31/2012 5:43 AM
tmac48
Score: 105
Status: offline
ceije, ok, the aluminium hinge I used was bought - in by a local hardware store for me.
tmac
Hide Signatures
(in reply to ceije)
       Post #: 15284
RE: WACO YMF - 9/2/2012 2:29 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: jmdunstan
tmac:
Good luck,
Jim
Jim,
What scale was the plane mentioned in your post on Cal-Grafx?  What did they charge you for yours, if you don't mind my asking?
And do you have the URL for their web site, assuming they have one?
_____________________________
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to jmdunstan)
       Post #: 15285
RE: WACO YMF - 9/2/2012 5:12 AM
rccrasher65
Score: 100
Status: offline
Brothers, Are any of you still experiencing the problem of opening your email link to the waco ymf forum? I'm still having to go completely around to get here. I have filed a trouble ticket, but still no help. If anyone else is still having this problem we need to fill out more trouble tickets so this issue can be resolved. Problem has been here for more than 3 weeks now. I'm not very computer savy so if someone else can explain the problem to rcu maybe it will get resolved faster. I know its not my computers. Its happenong on both of them. Thanks, George
George Waco brother#209
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15286
RE: WACO YMF - 9/2/2012 5:36 AM
rccrasher65
Score: 100
Status: offline
Hey Joe are you still having problems opening your email  to the forum?
Hide Signatures
       Post #: 15287
RE: WACO YMF - 9/2/2012 2:40 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: rccrasher65
YES
Hide Signatures
(in reply to rccrasher65)
       Post #: 15288
RE: WACO YMF - 9/2/2012 2:49 PM
Dash7ATP
Score: 130
Status: offline
YES!
Hide Signatures
       Post #: 15289
RE: WACO YMF - 9/2/2012 3:50 PM
aminiet
Score: 115
Last Login: 5/12/2013
Status: offline
Me too, I though it was my computer acting up.
SO MANY WACOS, SO LITTLE TIME.......
Hide Signatures
       Post #: 15290
RE: WACO YMF - 9/2/2012 5:26 PM
WacoNut
Score: 175
Status: offline
Dash,
Who mage the F-86 kit that you have? Nice looking bird.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to aminiet)
       Post #: 15291
RE: WACO YMF - 9/2/2012 6:55 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: WacoNut
Dash,
Later!!
Anthony
Thanks, Anthony,
It's a BVM F-86. It's the 60" size before he went to the ARF or giant  scale version.  As of now it's still a hanger queen.  I love the plane and put a lot of time into  building  it.  I have another kit on the shelf I intend to build one day, maybe after I finish my WACO.  As of now, the place we used to fly our duicted fans at is off limits for awhile.
Hide Signatures
(in reply to WacoNut)
       Post #: 15292
RE: WACO YMF - 9/2/2012 8:37 PM
WacoNut
Score: 175
Status: offline
Sweet,
I was looking at his 80" kit. too much $$$$$ The F-86 has always been my favorite jet.
kit+ turbine= Divorce
Later!!
Anthony
Hide Signatures
       Post #: 15293
RE: WACO YMF - 9/2/2012 9:48 PM
jmdunstan
Score: 100
Status: offline
Re my decals from Cal-grafx:
My plane is the 1/5 scale YMF-3.  They charged me $67.50, including mailing, mostly, they said for the required computer design time, which is now done.  Their URL is http://www.cal-grafx.com/
Jim
Hide Signatures
       Post #: 15294
RE: WACO YMF - 9/2/2012 11:24 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: jmdunstan
Jim
Jim.
Thanks for the info,. I assume that you got the vinyl single color graphics. Were they able to do the pinstripes that are on all WACO markings ?
Joe
Hide Signatures
       Post #: 15295
RE: WACO YMF - 9/3/2012 1:53 AM
gunner3
Score: 100
Last Login: 3/14/2013
Status: offline
Hide Signatures
       Post #: 15296
RE: WACO YMF - 9/3/2012 2:51 PM
rcjunky67
Score: 100
Last Login: 9/12/2012
Status: offline
yes sir, I'm still having the same trouble with opening emails from this site. what do you knopw? maybe them there mayan's hide it right after all, 12-21-12 bein the end of the world and all . I'd have never guessed it would have started with  our beloved RC Universe !!! Oh well, I guess it was all circleling the drain and had to end some time,ay boy's? in the the mean time , let's all show as much love as we can for the ones we care for in our own lives and get out there and fly them WACO's, or what ever else you got. you know , just in case they are right. clear skies and calm winds everyone
Robert,AMA#947232 waco brotherhood #222
Hide Signatures
       Post #: 15297
RE: WACO YMF - 9/3/2012 9:52 PM
Rainbow1
Score: 100
Last Login: 5/21/2013
Status: offline
How do I get to be a member of the Waco Botherhood? I am BuildING a PEPINO WACO
Robin, AMA #263677, Waco Brother #227
Hide Signatures
(in reply to rcjunky67)
       Post #: 15298
RE: WACO YMF - 9/3/2012 11:07 PM
Stickbuilder
Score: 346
Status: offline
quote:
ORIGINAL: Rainbow1
NEW BROTHER ALERT !!!!
You just did. Welcome Rainbow1. You are Brother # 227. Don't know what your name is, but if you will enlighten me, I will add it to the information.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to Rainbow1)
       Post #: 15299
RE: WACO YMF - 9/4/2012 12:10 AM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: Rainbow1
Welcome aboard,
I built a Pepino Waco several years back and it turned out to be a beautiful plane. I never flew it and donated it to the Waco Museum in Troy Oh. I commend you for taking on the build. If you can build that plane you can build anything. Post some pics when you can.
Later!!
Anthony
Hide Signatures
       Post #: 15300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
