RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF
Page: <<   < prev  611 612 [613] 614 615 616 617 618 619 620   next >   >>
Login
RE: WACO YMF - 9/4/2012 1:05 AM
jmdunstan
Score: 100
Last Login: 3/6/2013
Status: offline
Joe:
Cal-grafx replicated the decal sheets that came with the kit.  The large "N numbers" are conventional slide-off decals with very thin black outlines on the white figures.  See photo below.  All of the other graphics are white vinyl with very agressive adhesive.  I'm sure Cal-grafx can provide other features if you want and will pay for them.
Jim
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to WacoNut)
       Post #: 15301
RE: WACO YMF - 9/4/2012 5:35 AM
Dash7ATP
Score: 130
Last Login: 6/20/2013
Status: offline
Jim,
Nice looking model! I'm surely going to check them out.
Did you use the aileron plastic "covers" that came in the kit?  I"m still tring to decide if I want to use those corrogations or try something else. Yours looks pretty good!
Thaks for your infol.
Joe
_____________________________
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
(in reply to jmdunstan)
       Post #: 15302
RE: WACO YMF - 9/4/2012 10:57 AM
Rainbow1
Score: 100
Last Login: 5/25/2013
Status: offline
Now WacoNut you spooking me a little, Just started on the build. Any pointer you can give would be of great help..
Robin, AMA #263677, Waco Brother #227
Hide Signatures
       Post #: 15303
RE: WACO YMF - 9/4/2012 5:07 PM
jmdunstan
Score: 100
Status: offline
Joe:
Yes, I did use the plastic aileron covers that came with the kit.  I searched for the SIG plastic corrugated sheet suggested in this forum, but could not find them.  The plastic parts were a bit of a pain to blend and fill to achieve smooth edges with the balsa, but they turned out pretty nice.
Jim
Hide Signatures
(in reply to Rainbow1)
       Post #: 15304
RE: WACO YMF - 9/4/2012 8:38 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: jmdunstan
Joe:
Jim
Thanks Jim,
I had suspected that would be a problem (blending them to the surface).  How did you attach  them? CA? Had you applied any type of prep to the balsa before adding the plastic?  I know. A lot of questions, but it all helps to avoid any mistakes that may have been made before by someone else.
Joe
Hide Signatures
       Post #: 15305
RE: WACO YMF - 9/4/2012 10:02 PM
jmdunstan
Score: 100
Status: offline
Joe:
I used medium CA to attach the aileron covers to the balsa sheeting.  I did not use any prep on the balsa.  They seem to be securely bonded in place.  I did not attempt to inset them into the balsa, but simply sanded both the leading and trailing edges to a bevel, then filled the open ends of the corrugations with lite filler.
Jim
Hide Signatures
(in reply to Dash7ATP)
       Post #: 15306
RE: WACO YMF - 9/4/2012 10:10 PM
WacoNut
Score: 175
Status: offline
quote:
ORIGINAL: Rainbow1
Check for the Pepino Waco thread in the scratch building forum. There is alot of info you will be interested in. There are more errors on the plans than I can remember. I had to draw new ribs for mine and all 4 panels are different sizes on the plans. Your better off picking a top and bottom panel and building both sides from that. The left and right side of the stab/elevator and not symetrical and the top view of the fuse is crooked. The stringer notches are in the wrong location and will result in a wavy look thru the covering material. That is just a start.
You can correct all these problems but I suggest you check everything before cutting any wood.
Later!!
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 15307
RE: WACO YMF - 9/5/2012 12:16 AM
dadrivet
Score: 100
Last Login: 6/19/2013
Status: offline
dont know if anybody else is still having problems.i can't tell now as i no longer seem to be getting email's
Dadrivet(Martin) Waco Brother #225
Hide Signatures
       Post #: 15308
RE: WACO YMF - 9/5/2012 1:08 AM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: dadrivet
I'm still getting emails, but I can't get into this site through the email links. I wish they would fix this Da_n problem!
I have some photos I want to post, but I'm not even going to try until it's fixed.
Joe
Hide Signatures
(in reply to dadrivet)
       Post #: 15309
RE: WACO YMF - 9/5/2012 3:09 AM
WacoNut
Score: 175
Status: offline
Posting pics does not seem to be a problem lately.
As far as linking thru e-mails I do not know as I never follow the e-mail links, I have links for the different forums saved in my favorites and I just go thru the main menu. Some threads like this one get so much traffic it will fill your inbox. When a thread starts getting that busy I remove my subscription to stop the mails and I just stop in each day and check for new post.
Later!!
Anthony
Hide Signatures
       Post #: 15310
RE: WACO YMF - 9/5/2012 6:11 AM
rccrasher65
Score: 100
Status: offline
Martin, the problem is still there, nobody really posting ,only a few .
George Waco brother#209
Hide Signatures
       Post #: 15311
RE: WACO YMF - 9/7/2012 12:34 PM
Stickbuilder
Score: 346
Status: offline
When I got home yesterday, I had just a little mowing left to do. Finished that, and took a plane out of the shop and went flying. Dead calm on the ground, but 100 feet up, it was gusty as all get out. Still a windy day flying is better than a calm day sitting on yer arse. Hopefully everyone is doing okay. Sorry about the site problems, don't know what's up with that.
Bill, Waco Brother #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
(in reply to rccrasher65)
       Post #: 15312
RE: WACO YMF - 9/7/2012 6:14 PM
rccrasher65
Score: 100
Status: offline
Bill, Hope you had a good day of flying. I have been pressing RCU for a fix on the site problem. What I got so far is that the url's are changing on there own, the url that is coming up for our forum is actually a url for a dura trax car forum on rcu. The tech I have been in contact has told me the problem has been given to the IT people, so hopefully the problem will eventually be solved, my suggestion would be to get as many brothers to place a trouble ticket in with rcu, that may light a fire under some butts. If they don't get trouble tickets they don't know whats going on. The squeeky wheel gets the oil all the time. George
Hide Signatures
(in reply to Stickbuilder)
       Post #: 15313
RE: WACO YMF - 9/8/2012 12:46 PM
rcjunky67
Score: 100
Last Login: 9/12/2012
Status: offline
 hey  , whats a trouble tickett?
Robert,AMA#947232 waco brotherhood #222
Hide Signatures
       Post #: 15314
RE: WACO YMF - 9/8/2012 4:55 PM
rccrasher65
Score: 100
Status: offline
Robert, go to the top of the page, you will see help me, click on the and it will take you to all the it problems. they do not describe our perticular problem but you will find a spot where you can explain what is going on. tell them you can't open your email links to this forum. then send. an IT person will get back to you through email.
quote:
ORIGINAL: rcjunky67
Hide Signatures
(in reply to rcjunky67)
       Post #: 15315
RE: WACO YMF - 9/9/2012 1:39 AM
WacoCabinaero
Score: 100
Last Login: 11/27/2012
Status: offline
Plans for the Pica YMF 1/6th scale
Click for fullsize
Click for fullsize
< Message edited by WacoCabinaero -- 9/9/2012 2:10 AM >
Hide Signatures
       Post #: 15316
RE: WACO YMF - 9/9/2012 1:51 AM
WacoCabinaero
Score: 100
Status: offline
Plans for 1/5th scale Pica Waco
Click for fullsize
Click for fullsize
< Message edited by WacoCabinaero -- 9/9/2012 3:27 AM >
Hide Signatures
(in reply to georgewaldrop)
       Post #: 15317
RE: WACO YMF - 9/9/2012 1:57 AM
WacoCabinaero
Score: 100
Status: offline
Plans for 1/5th scale Pica Waco http://www.outerzone.co.uk/plan_details.asp?ID=3269
Plans for 1/6th scale Pica Waco http://www.outerzone.co.uk/plan_details.asp?ID=3182
anyone with an inkjet can use a on line tiling service
http://www.lucubration.com/pdf-tile-printer
to use their inkjet to print off a copy and the patterns that accompany the fifth scale can be reduced for the the sixth scale.
Hide Signatures
       Post #: 15318
RE: WACO YMF - 9/9/2012 1:11 PM
ceije
Score: 100
Status: offline
to all, if your looking for the pica plans and having trouble with the web site AMA has the 1/6, and the 1/5 scale in stock along with the patterns that Stickbuilder submitted centuries ago. if your looking for larger plans they AMA can blow the 1/5 scale up tp whatever you want. Greg, who works this dept. has a new copier that does the enlargements without distorsions. both dan and i have the 1/4 90in. wingspan blowup of which he is building as we speak and i also have a set blown to 1/3 scale about 122in. wingspan for a future project.
Happy hunting
Chris Melhus, ceije 196
Hide Signatures
(in reply to WacoCabinaero)
       Post #: 15319
RE: WACO YMF - 9/9/2012 1:38 PM
skypup50
Score: 100
Last Login: 12/13/2012
Status: offline
I found and won a 1/5 Waco in pristine condition yesterday on ebay . I have a new saito FG-21 gas engine I've just broken in and will being flying on a 120 Spacewalker II. I may be able to use it on the Waco. I'm excited about the find.
http://www.ebay.com/itm/150893742747?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_500wt_1414
Hide Signatures
(in reply to ceije)
       Post #: 15320
RE: WACO YMF - 9/11/2012 4:01 AM
rc_wings
Score: 100
Status: offline
Just in case anyone is interested...there is a 1/5 scale Pica kit on eBay.
http://www.ebay.com/itm/Waco-YMF-3-Golden-Age-Biplane-R-C-model-airplane-kit-Pica-RC-1-5th-new-box-/200816242799?_trksid=p4340.m2109&_trkparms=aid%3D555001%26algo%3DPW.CURRENT%26ao%3D1%26asc%3D7%26meid%3D1960251021521555481%26pid%3D100010%26prg%3D1004%26rk%3D4%26
Marko
WACO Brother #163
Hide Signatures
(in reply to skypup50)
       Post #: 15321
RE: WACO YMF - 9/11/2012 4:25 AM
georgewaldrop
Score: 105
Last Login: 6/8/2013
Status: offline
quote:
ORIGINAL: ceije
Happy hunting
Chris,
Do you recall, offhand, what the charge was for the "blown up" plans? I have the 1/6 plans I snagged off the internet somewhere long ago, as well as the 1/5 scale information and plans I snagged off the MOY site long ago...I also have a 1/5 scale PICA Kit yet to build, but am very interested in building a 1/4 or 1/3 scale version down the road...Thanks in advance for the info!
George Waldrop~AMA-L1307~IMAA-LM207~Have a Blessed Day!
Waco Brotherhood #151 ~~ Carl Goldberg Ultimate Brotherhood #58
Hide Signatures
(in reply to ceije)
       Post #: 15322
RE: WACO YMF - 9/11/2012 1:29 PM
ceije
Score: 100
Status: offline
quote:
ORIGINAL: georgewaldrop
quote:
ORIGINAL: ceije
Happy hunting
Chris,
Do you recall, offhand, what the charge was for the ''blown up'' plans? I have the 1/6 plans I snagged off the internet somewhere long ago, as well as the 1/5 scale information and plans I snagged off the MOY site long ago...I also have a 1/5 scale PICA Kit yet to build, but am very interested in building a 1/4 or 1/3 scale version down the road...Thanks in advance for the info!
George, As i recall they printed both a 1/4 and a 1/3 scale copy plus all the patterns and Dan Hudson's wing modification ribs, if i remember correctly for 135.00 shipping included. They were rolled and in a tube. Please keep in mind it takes time for these plans to be printed due to the size if you order have patience. Make sure you tell Greg you want the patterns and Dan's rib mods. sometimes they forget.
Good Luck and happy scratch building.
Chris Melhus ceije 196
"Sometimes you have to build it a little wrong, to make it look right."-DAVE PLATT-
Hide Signatures
       Post #: 15323
RE: WACO YMF - 9/11/2012 6:18 PM
kvlasblom
Score: 100
Last Login: 6/1/2013
Status: offline
Hi everyone, I have a question. As written on my WACO SRE thread:
The brackets have been completed and the left N-strut has now also been made. That took some time as everything had to been measured, checked and re-checked etc. But it fits beautifully.
I can now go ahead and design/make the flying wires (or are they landing wires?). Does anyone happen to know the thickness and width of the full-scale ones?
I was thinking of making them out of a firm material, such as carbonfibre rods, which could then be fixed at one end and then the other end could simply be pushed into a piece of fuel tubing in the wing to hold it in place...
WACO Brotherhood #93
Current project: 1/6 WACO SRE build from plans
Hide Signatures
(in reply to ceije)
       Post #: 15324
RE: WACO YMF - 9/11/2012 7:52 PM
Dash7ATP
Score: 130
Status: offline
quote:
ORIGINAL: kvlasblom
Check out this site: http://www.mickreevesmodels.co.uk/~mickreev/Bipes/p2bipe.html  They hae the flat wire is several sizes for your wires, as well as the fork ends for attachment.  Some of the items may be hard to find, so look over the sie well.
Joe
Hide Signatures
(in reply to kvlasblom)
       Post #: 15325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
