RE: WACO YMF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: WACO YMF Page: <<   < prev  62 63 [64] 65 66 67 68 69 70 71   next >   >>
Login
RE: WACO YMF - 3/5/2007 4:23 AM
damifino
Score: 100
Last Login: 8/11/2012
Status: offline
KHODGES- What paint scheme are you gonna do? Maybe I missed it earlier...
I cut the V-stab and rudder parts today, will glue them together tonight. Next is the crutch and formers. Thanks to STICKBUILDER's tracings I'm making this thing a reality. Next time I post some pictures I'm going to include some of my Master Airscrew balsa stripper. It's mounted to the table along with a guide fence that makes cutting strips almost too easy.
< Message edited by damifino -- 3/5/2007 4:29 AM >
_____________________________
Everybody knows you can''t make a time machine out of a Tilt-A-Whirl.........-:WACO Brotherhood 25:-
Hide Signatures
(in reply to khodges)
       Post #: 1576
RE: WACO YMF - 3/5/2007 4:37 AM
Hughes500E
Score: 105
Last Login: 5/21/2013
Status: offline
I had a great day myself as well.
I got the top wing mounted and I got the interplane struts drilled and bolted on. After getting it all finished I levelled the fuse and pulled out the incidence meter. I would like to say all surfaces are dead on the money but I have to say all surfaces are within a very acceptable range, within a needle width away from 0
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1577
RE: WACO YMF - 3/5/2007 4:54 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: damifino
I've thought long and hard on this. I already have a yellow WACO, and the red is a bit too popular, although it is a very visible color. Blue is too somber, white gets dirty too easy, can't think of a shade of green that would look good unless I did it as a military trainer, and they weren't green anyway. I want something that is elegant, and that the trim will show up well on to help tell which direction it's pointed in .
The one on the left is the colors I'm going with, and the scheme I'll use is the one on the right. There aren't many I've found with the scalloped wings, and I like that:
Click for fullsize
Click for fullsize
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
(in reply to damifino)
       Post #: 1578
RE: WACO YMF - 3/5/2007 5:06 AM
khodges
Score: 126
Status: offline
hughes, it's looking good! I really like your struts, good work. Something I've noticed on all these kits and ARF's, and maybe it's already been discussed, is the lack of a front cockpit. In the WACO nomenclature, the "M" denotes 2 and 3 passenger airframe, so there should be a second cockpit. I'm not sure on the originals, but the new Classic has a removable windscreen and tonneau cover for the front 'pit when it's not in use.
I also noticed your Saito radial. I assume it's the 170? No better powerplant for a WACO, a radial, and no better radial for a model than a Saito.
Hide Signatures
(in reply to Hughes500E)
       Post #: 1579
RE: WACO YMF - 3/5/2007 5:09 AM
damifino
Score: 100
Status: offline
I second what KHODGES says about the radial. Please say you are running on board glow. That engine drops the bottom left cylinder regularly.
In my mind I keep going back to cream over all with red orange in a scalloped scheme like yours. The one I've ridden in is cream over all and orange scallops with gold pinstriping outlining the orange. I have a book with an earlier WACO on floats that is sorta hunter green with a silver and cream striping scheme, and the floats are silver. Real classy. That's another option for me.
< Message edited by damifino -- 3/5/2007 5:17 AM >
Hide Signatures
       Post #: 1580
RE: WACO YMF - 3/5/2007 5:12 AM
Hughes500E
Score: 105
Status: offline
Thanks, can't believe it's becoming a reality. I am going to be using a cover on my front cockpit just to simulate its there. I won't be cutting or anything. You nailed it, Saito 170 3 cylinder running on board glow and independant exhaust stacks.
Maiden flight is going to be shaky
Hide Signatures
       Post #: 1581
RE: WACO YMF - 3/5/2007 5:18 AM
damifino
Score: 100
Status: offline
The plane will be fine, you'll be shakin'!!
Hide Signatures
       Post #: 1582
RE: WACO YMF - 3/5/2007 5:38 AM
Hughes500E
Score: 105
Status: offline
That's for sure. Maiden flights are like a drug. Once it's over, you have to experience it again.
Hide Signatures
       Post #: 1583
RE: WACO YMF - 3/5/2007 8:06 AM
damifino
Score: 100
Status: offline
V-stab and rudder are glued up. I hope to begin building the crutch tomorrow night.
I haven't looked at the plans concerning adding a front cockpit. I'd at least like to cut it in there even if it had to be very shallow.
< Message edited by damifino -- 3/5/2007 8:14 AM >
Hide Signatures
       Post #: 1584
RE: WACO YMF - 3/5/2007 8:18 AM
Hughes500E
Score: 105
Status: offline
Would be very nice to complete two cockpits! I did look at the plans and considered doing it. I even have the pencil lines in my fuse from when I attempted to get the right shape before cutting. I couldn't get happy with my lines. Had I of obtained a descent line, I would have kept it shallow as well.
Hide Signatures
       Post #: 1585
RE: WACO YMF - 3/5/2007 1:41 PM
Stickbuilder
Score: 346
Status: offline
If you would like, I can scan the front cockpit cover for you, and post it here.
I now have the crutch built, and the bottom formers and landing gear assembled and in place. Looks like the adjustable stab should work just fine. There is no binding, and the linkage is slop-free. I'll post pics tonight. (camera batteries need charging again)
Bill, AMA 4720
WACO Brotherhood #1
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 1586
RE: WACO YMF - 3/5/2007 5:40 PM
WacoOne
Score: 100
Last Login: 5/19/2013
Status: offline
Question for anyone... Referencing the QCF pictures from skylark on page 63, post #1571, can anyone tell me the function of the 'bent pipe' looking device on the bottom of the wing connected to the aileron in the last picture? It also shows up on a picture I have of the YMF. Judging from the curved slot at one end, that may be for adjusting trim, but is it the aileron actuator or what? My stupid foggy brain can't figure out how it works.
Bill Hogue
WACO Brotherhood #21
Hide Signatures
(in reply to Stickbuilder)
       Post #: 1587
RE: WACO YMF - 3/5/2007 6:38 PM
skylarkmk1
Score: 210
Status: offline
Bill H.,
That is the aileron pushrod you see. It is connected with "ball links" for lack of the technical word. If you remove the plate on the wing, access to the "bellcrank" mechanism is under the plate. Instead of a straight slot we use when hiding a side mounted servo in the wing, they use a curved slot that follows the rotation of the bellcrank and at the same time induces differential to the ailerons. The pivot for the bellcrank is at the greese fitting. A couple of pictures from a UBF (Texaco 17) and a little different angle may help you visulize how it works. Texaco 17 was a racing WACO and has a steamling fairing over the linkage. I will try to get a photo with the plate removed next time I am up there.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by skylarkmk1 -- 3/6/2007 12:07 AM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
Hide Signatures
(in reply to WacoOne)
       Post #: 1588
RE: WACO YMF - 3/5/2007 7:24 PM
Hughes500E
Score: 105
Status: offline
Thanks Bill,
This kit I have has the template for the cover and the windshield. I'm laughing now
I do appreciate the offer!
Hide Signatures
       Post #: 1589
RE: WACO YMF - 3/6/2007 3:51 AM
khodges
Score: 126
Status: offline
I cut out the front cockpit on my ARF, and made a windscreen for it. It put the windscreen for the rear cockpit to shame, so I made a new one for it, too. They're not quite complete, haven't finished the rear's frame or the brackets to mount the front yet. I found two different front windscreens on the YMF Classic, one has four panels and one has three. I made the three panel. Both are made of 1/16 inch Lexan (polycarbonate). The frame for the rear 'screen is 0.08 styrene strips (it doesn't have an outer frame, just where the panels hinge, because it's designed to fold up when removed), and that's what I'll use for the front frame.
Here's a pic or two, the old foot long "yardstick" is for the Master Chief's benefit, the dial caliper is for you more "high tech" types
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1590
RE: WACO YMF - 3/6/2007 4:11 AM
yel914
Score: 120
Last Login: 5/20/2013
Status: offline
Khodges and all of the other brothers, I came upon this color listing in my kit recently. I don't know how authentic it is or where it came from-maybe somebody else can shed some light on it. I hope it comes in handy when we all think about the colors of our creations
Click for fullsize
Kits show building skills, ARFs show shopping skills. WACO Brotherhood #24
Hide Signatures
       Post #: 1591
RE: WACO YMF - 3/6/2007 4:18 AM
khodges
Score: 126
Status: offline
That's great! I don't know what the color codes refer to, or what the asterisks are for, but it looks like the color schemes matched to the registration and tail #'s. For anyone wanting to do a specific plane, you'd be all set. I only saw one that had a base color of cream, with maroon stripes and gold trim. Makes me more sure that's the one I want to do. I guess I'll use the registration # too.
< Message edited by khodges -- 3/6/2007 4:21 AM >
Hide Signatures
(in reply to yel914)
       Post #: 1592
RE: WACO YMF - 3/6/2007 4:34 AM
Nightstalker
Score: 100
Last Login: 1/25/2010
Status: offline
quote:
ORIGINAL: khodges
Whom are you refering to as "high tech" LT?... What's so "low tech" about the "thumb to forefinger" measurement method? Or in my Doggie case, the "dewclaw to foreclaw" measurement method?
Nice pics though... (the planes, not the high tech instruments of ultra precise measurement)
You know they do make digital yardsticks these days, 'cept they're metric...
Doggie 47
Hide Signatures
       Post #: 1593
RE: WACO YMF - 3/6/2007 4:45 AM
Stickbuilder
Score: 346
Status: offline
Okay, here's the weekend's work as promised. The tailwheel is only a mock=up, and the final result will be scale-like in appearence, and will have the fairing (I promise). You should be able to see the tail loading tank box, and the removable part of the former (F-7B) that enables you to service the tank. The gear is not welded up yet, and lots of good stuff to come. The lightening of the formers made it possible to add the heavier parts without gaining any weight. In fact the fuselage parts with modifications are still lighter than the original parts.
Bill, AMA 4720
WACO Brotherhood #1
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Nightstalker)
       Post #: 1594
RE: WACO YMF - 3/6/2007 6:46 AM
WacoOne
Score: 100
Status: offline
skylarkmk1
I appreciate the explanation of the aileron push rod. Makes sense to me now. It's just that it looks so different for a push rod that I couldn't imagine that's what it was. Very odd shape. Anyway, thanks for clearing it up. Now I can sleep.
Bill Hogue
< Message edited by WacoOne -- 3/6/2007 6:51 AM >
Hide Signatures
(in reply to skylarkmk1)
       Post #: 1595
RE: WACO YMF - 3/6/2007 7:02 AM
skylarkmk1
Score: 210
Status: offline
Bill H.,
None of us here would want you to lose any beauty rest.
Hide Signatures
       Post #: 1596
RE: WACO YMF - 3/6/2007 10:21 AM
old git
Score: 100
Last Login: 12/26/2011
Status: offline
Hi Bill et al,
I have now a MANTRA that I NEED to repeat every morning.
"I have no need of another project.
I do not want another project.
I will NOT become MORE interested in the WACO.
The WACO Brotherhood is EVIL.
Get thee behind me Stickbuilder!"
This thread is soooo seductive.
old git - - - - - - - aka John L.
Waco Brotherhood No. 14.
Hide Signatures
       Post #: 1597
RE: WACO YMF - 3/6/2007 11:16 AM
pimmnz
Score: 148
Status: online
Then for gods sake do not accept the offer of a `quick fly with this one' when you see someone on the field having a bit of fun with an old Waco...Evilness will overcome all resistance...
Evan, WB #12.
Hide Signatures
(in reply to old git)
       Post #: 1598
RE: WACO YMF - 3/6/2007 1:32 PM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: khodges
quote:
ORIGINAL: damifino
Why not say, "If I was alive and rich back when this plane was being sold, this is how I would have ordered it." Works for me.
Ed Cregger
"Practice makes prefect"
Hide Signatures
       Post #: 1599
RE: WACO YMF - 3/7/2007 1:04 AM
khodges
Score: 126
Status: offline
quote:
ORIGINAL: Ed Cregger
Ed Cregger
The saddest part of all this is that they are STILL building and selling this plane, and I AM alive (at least on weekends), but I could sell and mortgage everything I have or have had, and still couldn't afford one. A Plain Jane YMF Classic goes for about 450K with the 275hp Jake. I'll have about 1/500th of that in mine.
Hide Signatures
(in reply to NM2K)
       Post #: 1600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.030RCU1
