twist 40 build
Tower Hobbies
Logged in as Guest
  Printable Version
E-Flite Blade CP Pro - RTF
Seller:  TheRealSuperDave
Details:   $350.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> User Product Reviews >> twist 40 build
Page: [1]
Login
twist 40 build - 3/20/2006 8:54:47 PM
leftseat88
Status: offline
I have just about finished the build and found that the ailerons near the root are not equal distance from the bottom of the fuselage. One aileron is about 3/4 inch from the bottom and the other is about 1/2 inch. Has anyone else come across this problem and if so how so I correct it.
       Post #: 1
RE: twist 40 build - 3/21/2006 3:46:05 PM
TimC
Status: offline
leftseat88, I'd go ahead and fly the plane. You will be able to trim out any roll caused by this. You might re-post this question on one of the other forums. The Product Review forum is probably one of the lesser visited ones.
(in reply to leftseat88)
       Post #: 2
RE: twist 40 build - 3/21/2006 9:19:30 PM
leftseat88
Status: offline
Thanks I will do both!!!
(in reply to TimC)
       Post #: 3
RE: twist 40 build - 3/21/2006 10:04:54 PM
TimC
Status: offline
These planes like the Twist jump all over the place anyway, so in my opinion, perfect trim's not a big deal.
< Message edited by TimC -- 3/21/2006 10:07:03 PM >
       Post #: 4
RE: twist 40 build - 4/19/2006 1:30:39 PM
RCLT40
Status: offline
I putting one together also and have the same problem. The manuel states that you can sand the inside of the fueselage so It rest parallel. (Step 3 on page 7). I'm going to remove the covering first before I test fit the stab. (Step 5 on page 8).
(in reply to TimC)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
