Review of the Wild Hare CAP 232
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> Review of the Wild Hare CAP 232 Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Review of the Wild Hare CAP 232 - 3/21/2006 2:12:34 AM
ben beyer
Status: offline
Well, I got in late last night, but got to pick up my airplane from my uncles' house. This is one high quality plane. I haven't finished unpacking it, but it's really nice. It has a nice big cut out for canisters, the canopy is tinted and pre-cut, and the the holes for the canopy hold down bolts are already drilled with blind nuts installed.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Team DOD Member
www.downonthedeck.com
       Post #: 1
RE: Review of the Wild Hare CAP 232 - 3/21/2006 2:57:30 AM
mstroh3961
Status: online
Looking good Ben! With all the snow why dont you have it put together yet?
Regards
Mark
(in reply to ben beyer)
       Post #: 2
RE: Review of the Wild Hare CAP 232 - 3/21/2006 3:16:08 AM
ben beyer
Status: offline
Didn't get into town until 2 AM this morning.
Team DOD Member
(in reply to mstroh3961)
       Post #: 3
RE: Review of the Wild Hare CAP 232 - 3/21/2006 3:49:03 AM
mstroh3961
Status: online
Excuses
Regards
Mark
       Post #: 4
RE: Review of the Wild Hare CAP 232 - 3/21/2006 4:41:39 AM
ben beyer
Status: offline
Well, I got the throttle arm soldered on the 3W 56. It's not going anywhere. About to glue the elevator and horizontal stab hinges.
Click for fullsize
Team DOD Member
       Post #: 5
RE: Review of the Wild Hare CAP 232 - 3/21/2006 4:50:56 AM
Grotesquebass
Status: offline
heres a few pics of red
Click for fullsize
Click for fullsize
"I've got a fever and the only prescription is more cowbell"
       Post #: 6
RE: Review of the Wild Hare CAP 232 - 3/21/2006 6:03:13 AM
ben beyer
Status: offline
I got the elevators glued into the horizontal stabs. I like to wipe the beveled surfaces with WD 40. I helps to keep the glue from sticking to the covering.
Click for fullsize
Click for fullsize
Team DOD Member
(in reply to Grotesquebass)
       Post #: 7
RE: Review of the Wild Hare CAP 232 - 3/21/2006 11:56:17 AM
airborneSGT
Status: offline
I do the same. I also use that or silicone spray lubricant to prevent the hinges from binding from any glue expansion. Works great and a lot easier and cleaner then the melted vasoline method.
Very sweet engine. Twins are much more fun for 3D!
       Post #: 8
RE: Review of the Wild Hare CAP 232 - 3/21/2006 2:07:10 PM
rctom
Status: offline
I guess you guys didn't read the instructions. My improved method with the masking tape gives much better results than using WD 40.
TF
(in reply to airborneSGT)
       Post #: 9
RE: Review of the Wild Hare CAP 232 - 3/21/2006 2:45:46 PM
ben beyer
Status: offline
I read that, just didn't feel like doing it. I'm going to give it a try on the ailerons though.
Team DOD Member
(in reply to rctom)
       Post #: 10
RE: Review of the Wild Hare CAP 232 - 3/22/2006 4:27:01 AM
ben beyer
Status: offline
I did a little work on the CAP this evening. I'm also having to repair my Funtana and I'm still recovering from the weekend. I glued the left aileron into the left wing. Tom has a new method for gluing the hinges which involves using masking tape over the hole to keep it clean. I like the way it works. I also drilled out the cowl screw holes and put in some grommets. I do this to prevent the cowling from getting damaged by keeping the holes from enlarging. I also went to machine shop and gave them an idea of what I wanted in the way of standoffs. It may be a week or so before they even get to the though. Oh, this thing even has laser cut holes for the servo screws...very nice.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 11
RE: Review of the Wild Hare CAP 232 - 3/24/2006 3:06:20 AM
ben beyer
Status: offline
I glued the right aileron to the right wing panel tonight. Pretty easy. I also started to balance the prop using the DOD method. Just gotta balance the hub now. After that, I sealed the covering around the aileron servo slots and dripped some thin CA around them.
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 12
RE: Review of the Wild Hare CAP 232 - 3/25/2006 10:21:02 PM
ben beyer
Status: offline
I got the prop balanced DOD style. I'm waiting on standoffs for my engine and my servos.
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
