RE: Review of the Wild Hare CAP 232
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Review of the Wild Hare CAP 232
Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: Review of the Wild Hare CAP 232 - 10/6/2006 2:57:05 AM
Grotesquebass
Status: offline
yes it does pull to the gear not too bad tho put 2 washers under each of the bottom standoffs vertically the thrust is perfect now i just need a little more right thrust
_____________________________
"I've got a fever and the only prescription is more cowbell"
(in reply to erikpmort)
       Post #: 226
RE: Review of the Wild Hare CAP 232 - 10/6/2006 3:08:20 AM
erikpmort
Status: offline
oh nice! yeah i've been doing the same... so can you hover so its neutral now or do you still have to hold up elevator? i put in R thrust and its perfect but had to do it twice, put in a lot of up thrust but it still does it(pull to gear)... I didn't want to put in too much.... did you notice any other differances with the upthrust besides the hovering? good to talk to someone else 3Ding the cap.
Grip it and Rip it
(in reply to Grotesquebass)
       Post #: 227
RE: Review of the Wild Hare CAP 232 - 10/6/2006 10:35:00 AM
Grotesquebass
Status: offline
well my uplines are uplines now and it doesnt jump down when i hit the gas stuff like that very good plane when you resolve the thrust troubles as for it still pulling to the gear i figure its tendancy of caps with the high horizontal stab but i do notice once it gets locked in that goes away just keep trying you'll get it
       Post #: 228
RE: Review of the Wild Hare CAP 232 - 10/6/2006 2:49:57 PM
erikpmort
Status: offline
Yeah I think I will shim it a little higher and then leave it... its already much better than before.
Grip it and Rip it
       Post #: 229
RE: Review of the Wild Hare CAP 232 - 10/9/2006 9:28:41 AM
bluemagic98
Status: offline
are you guys running your CG at 4" and what engine's are you using? Ill be setting mine up this week and would love some input
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
       Post #: 230
RE: Review of the Wild Hare CAP 232 - 10/9/2006 2:31:28 PM
Grotesquebass
Status: offline
i am using a da-50 hitec digitals all around with this setup you will be tailheavy initially i set up for 3 3/4" cg but i have moved back since not sure where i am all i doo to check cg is pull into a 45 degree climb roll inverted and see which way it pulls and go from there
(in reply to bluemagic98)
       Post #: 231
RE: Review of the Wild Hare CAP 232 - 10/9/2006 5:10:21 PM
erikpmort
Status: offline
mine is behind 4" a bit start at 4
Grip it and Rip it
       Post #: 232
RE: Review of the Wild Hare CAP 232 - 10/9/2006 5:33:12 PM
bluemagic98
Status: offline
Erikpmort is yours a DA-50 as well Ill be ussing a Evolution 58 and its a lot heavyer than the DA. In my Ultimate i had the rudder servo in the tail as well as both batteries and the regulators and switches the only thing up front was the RX the throttle and choke servos. and i still added a fish weight or 2 to the tail however I was going tail heavy. I like my planes on the touchy side and a tail heavy plane slows down faster
       Post #: 233
RE: Review of the Wild Hare CAP 232 - 10/9/2006 5:39:21 PM
erikpmort
Status: offline
i have the 3W-75 but mine is the 91" if yours is the 85" you might be looking at rudder servos in the tail, ask tom he did the 91" with the evo but might have used the evo for the 85" too...
Grip it and Rip it
       Post #: 234
RE: Review of the Wild Hare CAP 232 - 10/9/2006 6:01:59 PM
bluemagic98
Status: offline
well all the parts are on the bench and the plane left STEVENS POINT,
WI, US 10/09/2006 7:30 A.M. OUT FOR DELIVERY So im gonna have a bird to fly soon. Im sure someone will have some input on this if not im sure ill find a spot for everything. but knowing where the rudder servo will go is a real plus I would like to have it in the ussual place if at all possable.
       Post #: 235
RE: Review of the Wild Hare CAP 232 - 10/9/2006 6:05:19 PM
erikpmort
Status: offline
oh man you're like checking the tracking # every 5 min. I bet... been there.... see if you can finish it in one week like I did lol
Grip it and Rip it
       Post #: 236
RE: Review of the Wild Hare CAP 232 - 10/9/2006 6:13:49 PM
bluemagic98
Status: offline
a week what takes you so long? 2 days if im left alone and there are 24 hours in a day trouble is when the plane is ready im not I allways try and sleep just before i fly. note the word "try" However the plane will get here and ill be flying as im headed to the field now
       Post #: 237
RE: Review of the Wild Hare CAP 232 - 10/9/2006 6:18:06 PM
erikpmort
Status: offline
oh man you got it bad
Grip it and Rip it
       Post #: 238
RE: Review of the Wild Hare CAP 232 - 10/10/2006 4:16:29 PM
bluemagic98
Status: offline
well engine is mounted choke and throttle servos mounted and linkages made up cowelling mounted tank mounted elevators hinged alierons hinged batteries and regulators mounted main gear mounted ignition is mounted and programed. need 4-40 all thread to make up linkages need to hinge rudder and mount tail wheel need to mount canopy and make up wheel pants also need to mount rudder servo and figure balance. almost done right? lol
       Post #: 239
RE: Review of the Wild Hare CAP 232 - 10/11/2006 9:45:21 PM
ScottZ
Status: offline
I have a H9 33% Cap 232 and hated it, until I dropped the weight from 26.5lbs to only 22.6lbs. The biggest drop in weight came from swapping out the 3W 100 B2 in favor of the 3W 80 xi single. Almost all of the bad flying tendencies went away. However do not give up on your plane WH makes good stuff. I improved the hovering tremendously by adding more right thrust and a little upthrust. Adding the upthrust got me off the continuous up elevator in a hover and also the bad coupling to the belly in KE. These Caps in general have to be tweaked quite a bit sometimes but patience will reward you with a great flying plane. Do not give up!!!!!!!!!!!!!!!!!!!
       Post #: 240
RE: Review of the Wild Hare CAP 232 - 10/11/2006 10:11:31 PM
erikpmort
Status: offline
thanks!
Grip it and Rip it
(in reply to ScottZ)
       Post #: 241
