Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Something I'd like to add about balance and added weight here. For those putting togerher any new plane you will benefit greatly from mounting the engine first, placing all the components inside the plane where you think they should go using masking tape, and then check to see where the plane balances before you secure anything. More often than not you'll find that the locations you've selected for the components will have to be changed to get a close final balance point. Don't be afraid to be a little creative and move components to places other than the pre-made cut outs. That applies to any plane with any manufacturer.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
