RE: Review of the Wild Hare CAP 232 (Full Version)
All Forums >> [RC Airplanes] >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support
Message
ben beyer -> RE: Review of the Wild Hare CAP 232 (3/31/2006 7:43:21 AM)
Then, tonight, we got the cut out for the carb and throttle connections done. We also test ran the engine and set the needles. The last picture is of the engine at idle believe it or not.
rctom -> RE: Review of the Wild Hare CAP 232 (3/31/2006 12:47:38 PM)
That's not your Cap, it's the Edge!
TF
ben beyer -> RE: Review of the Wild Hare CAP 232 (3/31/2006 3:31:59 PM)
Yeah, I'm going to fly both planes with the same engine. I can only take one to the field so it'll work. I didn't post any pictures of the CAP the other day and mentioned that as the reason why. As a result, someone asked for pictures of it so I thought I'd give it to them. Still working on the CAP though, but I'm being held up by the lack of the standoffs I ordered not showing up yet. Once I get those and get the engine out of the Edge and into the CAP, it's just setting up the radio, which is pretty easy and should be done in a few nights. If I get the standoffs by Tuesday of next week, I might be able to maiden (with a video of it) next weekend.
AndresAM -> RE: Review of the Wild Hare CAP 232 (3/31/2006 4:04:51 PM)
Ben beyer,
That 3W twin is a beauty! I woder how much power it has.
Do you have top RPM“s numbers with that 3W prop?.
Andres
erikpmort -> RE: Review of the Wild Hare CAP 232 (3/31/2006 5:39:23 PM)
very nice very nice, videos are good. how much does that twin weight?
ben beyer -> RE: Review of the Wild Hare CAP 232 (3/31/2006 5:47:28 PM)
We have not tached the engine yet because it was run for the first time last night. The engine weighs 4.1 lbs. with ignition. So maybe about .75 lbs. more than a DA 50 and it will swing a 22x10 at 7200 when broken in. Those are G62 numbers.
erikpmort -> RE: Review of the Wild Hare CAP 232 (3/31/2006 5:52:56 PM)
Wow, light twin. that'll look awesome with the cowl on too.
karlwatt -> RE: Review of the Wild Hare CAP 232 (3/31/2006 6:44:01 PM)
Ben,
You posted that you balance your props "DOD" style. Where can I find an outline of this?
ben beyer -> RE: Review of the Wild Hare CAP 232 (3/31/2006 6:47:29 PM)
The video is called Prop Balancing 101:
http://www.downonthedeck.com/videos_instruction.htm
The engine turned over really easy last night. About 5 flips with the choke on and it popped. Then, 4 flips and it was running. This is one sweet engine. Plus, I had the prop blades balanced in addition to the hub along with it being a twin....very smoothe. I ordered a Bolly 22x10 for the plane today so I'm going to balance that one DOD style to.
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/1/2006 7:53:37 AM)
Ok, I had to finish up the Edge tonight, so I didn't get to work on the CAP. However, I did get some 'Bling' for the CAP from Kirby's Kustom today.
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/4/2006 7:45:31 AM)
Ok, I got the standoffs for the motor and a little time to work on the plane. I got the ailerons hooked up tonight. I like to use CF rods from Central Hobbies with titanium ends. I just use a little JB Weld to hold them in.
I also installed the rudder servo. On all of these servos, I used #3 servo screws from microfasteners.com. I really like them and they are easier than the phillips head ones that come with the servos. I also replaced the servo horn screws with socket head screws from microfasteners.com.
erikpmort -> RE: Review of the Wild Hare CAP 232 (4/4/2006 4:12:04 PM)
Hey are you guys with the heavier engines using the pull pull setup for rudder, or 2 in the back?
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/4/2006 4:48:42 PM)
I just move my battery packs as far back as I can and then move them forward if I need more nose weight. The plane is designed to balance around an engine this size and it's only a little more heavier than a DA 50. I also move my throttle and choke servos back in addition to the ignition battery.
erikpmort -> RE: Review of the Wild Hare CAP 232 (4/4/2006 8:11:04 PM)
wow sombody was selling a NIB 5997 TG in the adds for 65$.... guess who bought it? :)
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/5/2006 7:32:07 AM)
I finished up the ailerons tonight and started working on the elevator servos. I also got pulled the pull-pull cable from B&P Associates and installed the rudder horn.
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/5/2006 7:33:49 AM)
This picture shows the location of the elevator servo. I like servos that are up more so I can get a straighter linkage between the arm and control horn; however, this still works fine though. I also started putting on some of the graphics.
tomriddle -> RE: Review of the Wild Hare CAP 232 (4/5/2006 2:43:10 PM)
Ben,
What servo arms are you using?
v/r
tom
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/5/2006 4:24:51 PM)
Air Wild
tomriddle -> RE: Review of the Wild Hare CAP 232 (4/6/2006 12:08:46 PM)
Thanks; 1.25" arms?
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/6/2006 3:44:01 PM)
Yep, and the rudder is a 3" arm.
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/7/2006 7:10:13 AM)
I'm just working on odd jobs on the plane right now. I glued in some plywood for the Sig Wheel Pant Mounts and also cut a piece of balsa to cover up the canister opening.
erikpmort -> RE: Review of the Wild Hare CAP 232 (4/10/2006 2:48:53 AM)
any videos of the cap yet from anybody/
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/10/2006 4:44:22 AM)
I might have the one of the maiden for this one next weekend. Depends on if I can get help mounting the engine and if the weather cooperates.
mstroh3961 -> RE: Review of the Wild Hare CAP 232 (4/10/2006 8:00:42 AM)
Ben what help do you need...I will be back in town after Wednesday, be happy to assist.
ben beyer -> RE: Review of the Wild Hare CAP 232 (4/10/2006 3:15:15 PM)
Just with the engine mounting. I need a drill press since the standoffs I have aren't open through the middle and a 1/4-20 tap. I emailed one of the guys I fly with and if he can't help, I may take you up on your offer.
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.2809906
