RE: Review of the Wild Hare CAP 232
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Review of the Wild Hare CAP 232
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Review of the Wild Hare CAP 232 - 3/31/2006 7:43:21 AM
ben beyer
Status: offline
Then, tonight, we got the cut out for the carb and throttle connections done. We also test ran the engine and set the needles. The last picture is of the engine at idle believe it or not.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Team DOD Member
www.downonthedeck.com
(in reply to ben beyer)
       Post #: 26
RE: Review of the Wild Hare CAP 232 - 3/31/2006 12:47:38 PM
rctom
Status: online
That's not your Cap, it's the Edge!
TF
< Message edited by rctom -- 3/31/2006 12:53:39 PM >
       Post #: 27
RE: Review of the Wild Hare CAP 232 - 3/31/2006 3:31:59 PM
ben beyer
Status: offline
Yeah, I'm going to fly both planes with the same engine. I can only take one to the field so it'll work. I didn't post any pictures of the CAP the other day and mentioned that as the reason why. As a result, someone asked for pictures of it so I thought I'd give it to them. Still working on the CAP though, but I'm being held up by the lack of the standoffs I ordered not showing up yet. Once I get those and get the engine out of the Edge and into the CAP, it's just setting up the radio, which is pretty easy and should be done in a few nights. If I get the standoffs by Tuesday of next week, I might be able to maiden (with a video of it) next weekend.
Team DOD Member
(in reply to rctom)
       Post #: 28
RE: Review of the Wild Hare CAP 232 - 3/31/2006 4:04:51 PM
AndresAM
Status: offline
Ben beyer,
That 3W twin is a beauty! I woder how much power it has.
Do you have top RPM“s numbers with that 3W prop?.
Andres
       Post #: 29
RE: Review of the Wild Hare CAP 232 - 3/31/2006 5:39:23 PM
erikpmort
Status: offline
very nice very nice, videos are good. how much does that twin weight?
Grip it and Rip it
(in reply to AndresAM)
       Post #: 30
RE: Review of the Wild Hare CAP 232 - 3/31/2006 5:47:28 PM
ben beyer
Status: offline
We have not tached the engine yet because it was run for the first time last night. The engine weighs 4.1 lbs. with ignition. So maybe about .75 lbs. more than a DA 50 and it will swing a 22x10 at 7200 when broken in. Those are G62 numbers.
Team DOD Member
(in reply to erikpmort)
       Post #: 31
RE: Review of the Wild Hare CAP 232 - 3/31/2006 5:52:56 PM
erikpmort
Status: offline
Wow, light twin. that'll look awesome with the cowl on too.
Grip it and Rip it
       Post #: 32
RE: Review of the Wild Hare CAP 232 - 3/31/2006 6:44:01 PM
karlwatt
Status: offline
Ben,
You posted that you balance your props "DOD" style. Where can I find an outline of this?
"It scares me how obsessed I have become with this hobby"
       Post #: 33
RE: Review of the Wild Hare CAP 232 - 3/31/2006 6:47:29 PM
ben beyer
Status: offline
The video is called Prop Balancing 101:
http://www.downonthedeck.com/videos_instruction.htm
The engine turned over really easy last night. About 5 flips with the choke on and it popped. Then, 4 flips and it was running. This is one sweet engine. Plus, I had the prop blades balanced in addition to the hub along with it being a twin....very smoothe. I ordered a Bolly 22x10 for the plane today so I'm going to balance that one DOD style to.
Team DOD Member
(in reply to karlwatt)
       Post #: 34
RE: Review of the Wild Hare CAP 232 - 4/1/2006 7:53:37 AM
ben beyer
Status: offline
Ok, I had to finish up the Edge tonight, so I didn't get to work on the CAP. However, I did get some 'Bling' for the CAP from Kirby's Kustom today.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 35
RE: Review of the Wild Hare CAP 232 - 4/4/2006 7:45:31 AM
ben beyer
Status: offline
Ok, I got the standoffs for the motor and a little time to work on the plane. I got the ailerons hooked up tonight. I like to use CF rods from Central Hobbies with titanium ends. I just use a little JB Weld to hold them in.
I also installed the rudder servo. On all of these servos, I used #3 servo screws from microfasteners.com. I really like them and they are easier than the phillips head ones that come with the servos. I also replaced the servo horn screws with socket head screws from microfasteners.com.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 36
RE: Review of the Wild Hare CAP 232 - 4/4/2006 4:12:04 PM
erikpmort
Status: offline
Hey are you guys with the heavier engines using the pull pull setup for rudder, or 2 in the back?
Grip it and Rip it
       Post #: 37
RE: Review of the Wild Hare CAP 232 - 4/4/2006 4:48:42 PM
ben beyer
Status: offline
I just move my battery packs as far back as I can and then move them forward if I need more nose weight. The plane is designed to balance around an engine this size and it's only a little more heavier than a DA 50. I also move my throttle and choke servos back in addition to the ignition battery.
Team DOD Member
       Post #: 38
RE: Review of the Wild Hare CAP 232 - 4/4/2006 8:11:04 PM
erikpmort
Status: offline
wow sombody was selling a NIB 5997 TG in the adds for 65$.... guess who bought it?
Grip it and Rip it
       Post #: 39
RE: Review of the Wild Hare CAP 232 - 4/5/2006 7:32:07 AM
ben beyer
Status: offline
