RE: Review of the Wild Hare CAP 232
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Review of the Wild Hare CAP 232
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Review of the Wild Hare CAP 232 - 4/11/2006 5:36:36 AM
mstroh3961
Status: offline
I have access to a dril press and the tap, let me know.
_____________________________
Regards
Mark
(in reply to ben beyer)
       Post #: 51
RE: Review of the Wild Hare CAP 232 - 4/11/2006 6:23:14 AM
ben beyer
Status: offline
Yeah, he's going to be available Thursday night. Thanks though. I'm thinking about entering the IMAC competition in Arvada in a few weekends with this one.
Team DOD Member
www.downonthedeck.com
       Post #: 52
RE: Review of the Wild Hare CAP 232 - 4/11/2006 6:31:29 AM
mstroh3961
Status: offline
me thinks you need to order a second engine....
I should be at the field all next weekend. and Wednesday as well.
Regards
Mark
       Post #: 53
RE: Review of the Wild Hare CAP 232 - 4/11/2006 2:17:40 PM
rctom
Status: offline
quote:
ORIGINAL: ben beyer
Just FYI Jeff Carte won 2nd in basic this past weekend. I've been saying the Cap is so smooth and steady it would make a good IMAC plane.
I was right.
TF
       Post #: 54
RE: Review of the Wild Hare CAP 232 - 4/12/2006 6:14:11 AM
ben beyer
Status: offline
So I finally got a chance to work on the CAP. I started tonight by installing the SIG wheel pant mounts. If you've never used them, I suggest you try them. I first figured out where the inside pant needed to go. Then, using the axle, I found where the outside pant goes. I just used the drilled holes for the inside pant to figure out the drill location for the outside mount. I used a GP dead drill tool to accomplish this. Just took it out of the rest of the tool. Once you do one side, do the other.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
(in reply to rctom)
       Post #: 55
RE: Review of the Wild Hare CAP 232 - 4/12/2006 6:17:25 AM
ben beyer
Status: offline
In the end, you get nice pants that will never crack from vibration and never give you any trouble at all. No loctite required.
Also, check out the tail wheel assembly. It's pretty nice. I also put the rudder tiller arms on.
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 56
RE: Review of the Wild Hare CAP 232 - 4/12/2006 5:10:17 PM
karlwatt
Status: offline
Hey Ben,
Thanks for chiming in on the **** thread I posted on a plane for the OS 160. I opted for the Tunnel Vision which is coming along well, waiting for some parts to finish it. I friend is finishing up his WH 73" Edge and it is looking sooooo good, makes me wonder if I made the wrong decision. But we need more variety at the field and I was hoping to get a good tax refund and get one of the 50 cc WH's. So, my question to you is which one would you chose if this was your first gas plane? It seems from all the posts on RCU that you have experience with many WH planes. The Cap you are building now looks like a really sweet one!
Karl
"It scares me how obsessed I have become with this hobby"
       Post #: 57
RE: Review of the Wild Hare CAP 232 - 4/12/2006 5:18:29 PM
ben beyer
Status: offline
They're all built to last. People have complained that they can't destroy there bunny. If you're planning on getting a DA 50, for example, I would recommend any of them. The CAP however would be my first choice. I've heard of people coming in at 15.5 lbs. stock with a DA 50. Of course, if you got the Edge or Extra, you could get it down to 16-16.5 lbs. using micro servos on throttle, CF spinner, CF wing and stab tubes. The advantage of the Edge or Extra is that they can probably take a little more of a beating. Let me PM you an offer.
Team DOD Member
(in reply to karlwatt)
       Post #: 58
RE: Review of the Wild Hare CAP 232 - 4/13/2006 2:36:45 AM
Sailor
Status: offline
Ben's right about them taking a beating. I have always had a thing for Cap's and when I dumb-thumbed my H9 80" Cap, I looked far and wide for something comparable. Couldn't find one, so I went to a WH 300LX, just transferring the guts from the old plane. The 300LX has been a real winner and flies great! I am waiting for command authority to get one of Tom's Cap's and it will be the 91".
BTW, Ben you are doing a great job on the review. Keep it up, we need a video!
       Post #: 59
RE: Review of the Wild Hare CAP 232 - 4/13/2006 6:21:34 AM
ben beyer
Status: offline
Thanks Dave, hopefully I can maiden her this weekend and get a video of that.
Tonight, I fuel proofed the firewall and adjacent ares. I also installed the fuel tank in addition to the receiver. Since I like to run redundant receiver batteries, I'm also installing a Smart Fly BatShare as well as a Smart Fly Regulator. Running redundant batteries saved my Edge last weekend. I had one battery get flung to the back of the plane doing knife edge spins.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
(in reply to Sailor)
       Post #: 60
RE: Review of the Wild Hare CAP 232 - 4/14/2006 7:26:23 AM
ben beyer
Status: offline
I just put on some more bling tonight. I'm going to be mounting the engine tomorrow and trying to get things finished up.
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 61
RE: Review of the Wild Hare CAP 232 - 4/15/2006 8:28:17 AM
ben beyer
Status: offline
Well, with phamil1's help, I got the engine mounted today. Pretty sweet set up. Now that the beast is in the cowl. I finally got a chance to glue the rudder. I also set up the pull-pull cables. I haven't sealed the rudder hinge gap yet, but I'll do that tomorrow morning or sometime before I put the cotter pins in the horns. And lastly, there's a picture with the cowling on.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team DOD Member
       Post #: 62
RE: Review of the Wild Hare CAP 232 - 4/15/2006 8:38:41 AM
mstroh3961
Status: offline
Ben If you go to the field tomorow call me. I want to see it fly.
Regards
Mark
