Giant Scale Restraints ; what do you use???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Giant Scale Restraints ; what do you use???
Page: [1]
Login
Giant Scale Restraints ; what do you use??? - 3/21/2006 6:48:44 PM
zzw26n
Status: offline
On my 28% Extra I use the padded tuning fork that goes into the ground and cradles the stab on both sides if the fuse, works great for that size of Aircraft.
What do other Pilots use to restrain there 35%, 40% while starting? Wouldn't it have to be something pretty big?
thanks for any input , zz
       Post #: 1
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 6:54:28 PM
bhanley
Status: offline
Its usually another guy - preferally not too thin....
_____________________________
Come down gently......
(in reply to zzw26n)
       Post #: 2
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 7:17:30 PM
bubbagates
Status: offline
ZZ,
I use the same thing you do. I have a couple of sizes I made. One for glow and one for gas. Mine fold down in one direction only so all I have to do is back the plane up far enough so that it lays down
The ones for gas are a bit wider and have a longer garden spike on them. My biggest is a 30 percent Yak
< Message edited by bubbagates -- 3/21/2006 7:19:00 PM >
Bill James
Normal is not something to aspire to, it's something to get away from
       Post #: 3
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 8:48:27 PM
Bass1
Status: offline
I can't remember the guys name but I believe he is in a club in Florida. He sent me a few photos of these cool safety devices. These pull vertically out of the ground for airplane release. They probably could be finished in a day with the right crew.
Click to see fullsize image.
Click for fullsize
< Message edited by Bass1 -- 3/21/2006 8:52:52 PM >
(in reply to bubbagates)
       Post #: 4
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 9:03:49 PM
GalenB
Status: offline
I prefer a person as a holder too. But if one is not available then I use a rope around the tail. My rope is thicker parachute type rope with a carabineer to help get it hooked around fence posts etc. I use a thicker softer type of rope rather then thinner harder twisted nylon type rope...
Cheers!
       Post #: 5
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 9:35:02 PM
dork_blaster
Status: offline
I use a big soft rope as already suggested or a person I trust. I make sure the rope is taught before swingin the prop. Wouldn't use a spike in the ground (for big planes) even if I could get spike in the ground - anyone who's tried to dig a hole in SoCal knows what I'm talking about!
DB
Blasting dorks for the good of humanity...
(in reply to GalenB)
       Post #: 6
RE: Giant Scale Restraints ; what do you use??? - 3/21/2006 11:13:02 PM
RTK
Status: offline
If I can not find a willing person I use a Craftsman extra long honking screw driver Place it two feet in the ground at an angle and use a soft rope around the tail feathers. It will hold a 100cc plane at WOT, but I would never risk trying that in front of the plane. You never can be too safe.
(in reply to dork_blaster)
       Post #: 7
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 4:46:44 AM
WW2 Ace
Status: offline
quote:
ORIGINAL: zzw26n
Here is a post I started that may give you some ideas.
http://www.rcuniverse.com/forum/fb.asp?m=3794276
"Learn from the mistakes of others, because you won't live long enough to make them all yourself"
WW2 Ace
       Post #: 8
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 5:40:01 AM
Bass1
Status: offline
I found the club that has the neat system for restraining large airplanes. It would be great/safer if all the RC clubs had these. Go to www.charlotterc.com and click useful info, then CRCS plane restraints.
(in reply to WW2 Ace)
       Post #: 9
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 7:57:50 AM
Rcpilot
Status: offline
I use a person. Not too hard to find a willing participant around our field. Not too many guys flying gas, and they are intrigued by it. Always somebody willing to stand over the tail.
I don't fly gassers alone--so if I go out and no one is around, I either wait for someone to show up or go home. Only live 6 miles from the field.
I've never been seriously hurt playing with planes. Got my fingers wrapped once while playing with the timing on a 50cc conversion engine. That was enough of a lesson to keep me from ever messing with one when I'm alone at the field.
I'm knocking on my wooden computer desk right now.....................
Airplanes have expiration dates. It''s just not printed anywhere on them.
I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
(in reply to Bass1)
       Post #: 10
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 10:14:19 AM
ifshnee-RCU
Status: offline
Looks like the Punta Gorta field to me. I was just there for JR Challenge
(in reply to Bass1)
       Post #: 11
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 10:16:46 AM
ifshnee-RCU
Status: offline
Don's hobby sells the one I use & it can hold a 40%er
       Post #: 12
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 3:08:28 PM
Zeeb
Status: offline
Well this is a question I'm very interested in since I've got to figure out a way to hang on to the model I'm just finishing with a 100 size twin in it while I get it set up...
On my 50 size gasser I use the tail feathers restraint method to start it, then stand with over it with a leg on each side of the fuselage in front of the stab for the warm up and quick power check.
As you get to the bigger sizes, some method of holding them by the wings needs to be employed as the larger gas engines are capable of doing damage to the tail feathers at high power settings. Holding them by the tail feathers should prevent it from getting away from you on an accidental power increase, but as my buddy can attest, just holding it by the tail feathers while setting up the carb on a ZDZ-80 WILL damage the tail feathers on a certain YAK...
Zeeb
       Post #: 13
RE: Giant Scale Restraints ; what do you use??? - 3/22/2006 6:05:20 PM
zzw26n
Status: offline
Ifshnee,
I use the Midwest restraint also on my 28%, but I'm wondering if it will be able to handle a 35% with a DA-100 ? Maybe for starting, but not throttling up to max. I really like the padded PVC gates that are in a previous post. This uses the wings, provide concrete for the gas drips and looks like it would be easy on the airframe. Now, can I make one for our Field is the question?
thanks for all the insight ............
(in reply to Zeeb)
       Post #: 14
RE: Giant Scale Restraints ; what do you use??? - 3/23/2006 12:08:57 PM
stomper
Status: offline
This works.
Click for fullsize
Click for fullsize
Doug
       Post #: 15
RE: Giant Scale Restraints ; what do you use??? - 3/23/2006 2:19:31 PM
Zeeb
Status: offline
Well that's exactly what I use for starting models and have done it with everything but my first trainer. Some models like my Funtana 90 require the strap to go the other way because of the carbon fiber stab supports on the underside of the horizontal stab, or other models that the strap will hit the servos/linkages for the tailfeathers. It's also how my buddy had his Yak held when he damaged the tailfeathers setting up the ZDZ. It works great for starting since I don't think an inadvertent throttle up
