RE: Rc Fuel Faq
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
RCGF 26CC Gas Engine
Seller:  Furyflyer2
Details:   $192.99   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> RE: Rc Fuel Faq
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: Rc Fuel Faq - 4/11/2009 5:16 PM
GlassBullet
Score: 100
Last Login: 8/28/2009
Status: offline
sorry if this has been asked before, but what is the proper way to dispose of nitro fuel? I have about 1/5 gallon left that is almost 1 year old.
_____________________________
||~~~HPI Firestorm 10T~~~||
~http://www.youtube.com/GlassBullet13~
Hide Signatures
(in reply to Fuelman)
       Post #: 276
RE: Rc Fuel Faq - 4/11/2009 6:13 PM
controlliner
Score: 100
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: GlassBullet
Before you try to dispose of it, Try and run it. If it works, use it up. I have never thrown out fuel because of it being old. If there is moisture in it the engine will either not run at all ,or it will run poorly, if so then throw it out. I've had some fuel as old as 10 years old and it still ran well even though there was only 1/2 a gallon.
"Keep it clean and not too lean" Duke Fox
"just a little smackerel of huny, Rabit" Pooh
Hide Signatures
(in reply to GlassBullet)
       Post #: 277
RE: Rc Fuel Faq - 4/11/2009 6:59 PM
GlassBullet
Score: 100
Status: offline
alrite thanks. i'll give it a try.
Hide Signatures
(in reply to controlliner)
       Post #: 278
RE: Rc Fuel Faq - 4/11/2009 7:02 PM
w8ye
Score: 133
Status: offline
I use the old fuel for break in fuel
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 279
RE: Rc Fuel Faq - 4/12/2009 1:39 AM
GlassBullet
Score: 100
Status: offline
quote:
ORIGINAL: w8ye
does it being old make it better for break in or something?
Hide Signatures
(in reply to w8ye)
       Post #: 280
RE: Rc Fuel Faq - 4/12/2009 2:23 AM
w8ye
Score: 133
Status: offline
Bad fuel,
you can never get the HS needle peaked out and the engine will not run without heat on the glow plug. This is all OK for break in. You can leave the heat on and leave the engine rich.
If your fuel does not follow these parameters and runs OK, then it is OK to fly with it
Original AMA #31261
Hide Signatures
       Post #: 281
RE: Rc Fuel Faq - 4/12/2009 2:47 AM
GlassBullet
Score: 100
Status: offline
by heat, you mean the glow starter, right?
and i should have mentioned that this is fuel for a car. does that change anything?
Hide Signatures
(in reply to w8ye)
       Post #: 282
RE: Rc Fuel Faq - 4/12/2009 2:57 AM
w8ye
Score: 133
Status: offline
Glow starter is heat
Car fuel does not have enough oil for a airplane engine
If you are going to use the fuel you need to get some oil at the hobby shop (Castor oil) or buy some at the drug store
Original AMA #31261
Hide Signatures
       Post #: 283
RE: Rc Fuel Faq - 4/12/2009 6:27 AM
GlassBullet
Score: 100
Status: offline
no no no. it's car fuel being used in a car. no airplane anything involved. sorry for the misunderstanding.
Hide Signatures
(in reply to w8ye)
       Post #: 284
RE: Rc Fuel Faq - 4/12/2009 6:34 AM
w8ye
Score: 133
Status: offline
Well heck, if it will run use it up. Don't worry about it
Original AMA #31261
Hide Signatures
       Post #: 285
RE: Rc Fuel Faq - 4/12/2009 4:59 PM
GlassBullet
Score: 100
Status: offline
hah ok will do. thanks again for your help
Hide Signatures
(in reply to w8ye)
       Post #: 286
RE: Rc Fuel Faq - 5/12/2009 10:52 PM
xjqkz
Score: 100
Last Login: 11/4/2009
Status: offline
I'm trying to mix fuel for my buggy/truggy .
I have bought:
5 gallons of Methanol
1 gallon of nitro methane
2 pints of castor
I could not find a synthatic oil. The motorcycle shop I went to didn't carry it at all. Where can I find any synthatic oil? is synthatic same as the motor oil (5w-30) or marvel mystery oil?
Also I read on here to add 1 ounce of Propylene /gallon of mixture to make the idle more consistant. Some people are also suggesting adding aceton and armaroil, are those necessary for my application?
Hide Signatures
       Post #: 287
RE: Rc Fuel Faq - 5/14/2009 10:09 AM
downunder
Score: 105
Status: offline
Propylene Oxide is very dangerous and is banned by the American hot rod association. It boils at 34C (about 93F), has a flash point of -37C (about -35F) and any vapours can explode within an extremely wide range (2 to 37% !!).
Acetone isn't necessary because you'll be using nitro. Armorall stops foaming of the fuel in the tank from vibrations and all that's needed is one quick squirt into a gallon of fuel. Your engine will love the castor, it'll protect the rod bushes and stop the bearings from rusting too.
Hide Signatures
(in reply to xjqkz)
       Post #: 288
RE: Rc Fuel Faq - 5/14/2009 6:05 PM
Sport_Pilot
Score: 105
Last Login: 11/6/2009
Status: offline
You are better off ordering your oil from Morgans, Sig, or Fox Manufacturing that from a motercycle shop. It will cost much less, and you don't have to worry about confusion about which oil for alcohol powered engines VS gas.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
(in reply to xjqkz)
       Post #: 289
RE: Rc Fuel Faq - 5/14/2009 7:34 PM
gkamysz
Score: 105
Status: offline
quote:
ORIGINAL: downunder
I've found one drop per liter is just about right. More than that it might precipitate out.
Greg
Hide Signatures
(in reply to downunder)
       Post #: 290
RE: Rc Fuel Faq - 5/14/2009 8:51 PM
jeffie8696
Score: 107
Status: offline
I don't know how much to put in but I do know if it is too much it will coat the element in the glow plug and it idles and runs horrible. I got a bad gallon once and had a to speak to the fuel engineer about it.
Insert snappy remark here.
Hide Signatures
(in reply to gkamysz)
       Post #: 291
RE: Rc Fuel Faq - 5/15/2009 3:04 AM
hunternaf
Score: 100
Last Login: 10/31/2009
Status: offline
hi new to the R/C truck stuff (duratrax rtx with supertiger 4.4 cs) and am amazed at the cost of fuel. I bought a gallon of trinity monster hp 20% nitro at 30.00 a gallon for break in and playing but have ran out. Now I am having great difficulty finding fuel other than traxis at 15.00 per quart so I read all the post here and used some common sense (ie 20% 99% pure nitro and 62% 99% pure methanol and 18% oil (75%syn 25% caster) is the same no matter what the intended vehicle type states on the bottle). I have decided to buy the 17.00 gallon of airplane fuel and give it a try. I did not make it to the hobby shop so I called duratrax support to make sure it would not void the warranty and they stated 18% oil is there recomendation and the fuel would be fine. The tech did say not to use traxis fuel in there truck. I had bought 1 quart of traxxis when I first ran low on fuel and had a very hard time getting the engine up to operating temp (half a tank) before it would shift then hard to keep temps under 330 could the problem have been from the fuel itself or may I have hurt something already
Hide Signatures
(in reply to jeffie8696)
       Post #: 292
RE: Rc Fuel Faq - 5/15/2009 3:12 AM
hunternaf
Score: 100
Status: offline
I have read all threads and only saw one snipit about boat engines I own a kb 3.5cc outboard and a duratrax rtx with supertiger 4.4 is there a fuel that will work for both. I do not race as I know no others in my area with the same interest although I have found Embassy raceway only 25 miles from my home to play with the truck.
thanks in advance Gary L Sundman
Hide Signatures
(in reply to hunternaf)
       Post #: 293
RE: Rc Fuel Faq - 5/15/2009 3:36 AM
w8ye
Score: 133
Status: offline
15% nitro model airplane fuel should work fine in both engines. It normally has 18% oil
Original AMA #31261
Hide Signatures
       Post #: 294
RE: Rc Fuel Faq - 5/15/2009 4:09 AM
downunder
Score: 105
Status: offline
My son uses simple home brewed 80/20 methanol/castor fuel in his car engine and it works perfectly. With a standard engine it's slightly down on power but if you're not racing you'd never know. My suggestion for your car and boat engines would be to get some plane fuel (usually has more oil than car fuel) with a low nitro content.
Hide Signatures
(in reply to w8ye)
       Post #: 295
RE: Rc Fuel Faq - 5/15/2009 4:36 AM
hunternaf
Score: 100
Status: offline
Thanks for the replies will follow the thread but now wondering about the venom fail safe with temp sensor? anyone use one? and what is the proper way to get an abc engine up to operating temp????? Gary sundman New Carlisle In.
Hide Signatures
       Post #: 296
RE: Rc Fuel Faq - 5/15/2009 4:51 AM
w8ye
Score: 133
Status: offline
Run it hard
Original AMA #31261
Hide Signatures
       Post #: 297
RE: Rc Fuel Faq - 5/17/2009 5:18 AM
hunternaf
Score: 100
Status: offline
Ran 1 tank of wildcat 15% nitro 18% oil (80%syn 20% degummed caster) 18.00 in my rtx (4.4 cs supertiger) after a complete tear down and resealing with copper permatex to the back of the engine and fuel inlets. Also used losi green slime to the needles and output shaft to the rotostart. Seemd like the needles both had to be opened considerably more than factory but it ran like a scalded dog once I richened it to stop bogging at the shift point with wot. Refilled the tank and switched glow plugs and the rotostart did not function right so I will be trying again tomorrow when I get the engine back in. (rotostart works after cleaning the one way bearing)
Gary L Sundman
New Carlisle In.
Hide Signatures
(in reply to w8ye)
       Post #: 298
RE: Rc Fuel Faq - 5/17/2009 5:53 AM
w8ye
Score: 133
Status: offline
Good luck
Original AMA #31261
Hide Signatures
       Post #: 299
RE: Rc Fuel Faq - 6/12/2009 2:33 AM
hunternaf
Score: 100
Status: offline
well after a half gallon of wildcat 15% nitro 18% oil 75%syn 25% caster truck is still running great and easier to keep tuned to keep temp 300 and under, usually shoot for the 270 mark as recomended by mfg but it sure sings at 300   Gary
Hide Signatures
(in reply to w8ye)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.893RCU1
