Fuelman
NY, USA Status: offline
Good question Jon, quote:
Why do they say, do not use airplane fuel in nitro car motors or vice versa? Lets not let the flames get out of hand here folks, this is my opinion. First of all- many car fuels have low oil contents, usualy around 10% to 15% or so. That is where the little hi-revving, over cooled engines are most responsive in transition and top end. Second- Many airplane fuels contain between 16% and 22% or more in total lubricant because that is what many engine manufacturers recommend. To answer your question, car makers recommend car fuel because they more than likely have a car fuel blend made for them and want you to buy the very expensive car fuel (with their name on it of course). The engines will run just fine with most car fuels on the market with the appropriate nitro content. No airplane engine manufacturer that I know of has a fuel made for them, so they just recommend a fuel which contains XXXX and XXX. I have not seen an airplane engine instruction book that recommends a real low oil for a common use sport engine. I have seen one that recommends 15% or more, and that is about as low as I've seen recently. So, unless you are real sharp on the needles and the car fuel has some pretty spectacular oils in it, you may not want to run a low oil car fuel in an airplane or heli engine. (I have several customers that do, but thats a different story). Now, you can run a high oil airplane fuel in a car engine without any problems, you just will not have the performance or the super crisp transition. The extra oil in a car engine will change the tune considerably, you will need to open the high and low speed needles up a considerable amount to get the same amount of burnable mixture in the combustion chamber and they will run a touch warmer. You will not hurt a car engine by running a high oil fuel through it, it just needs to be tuned correctly.
_____________________________
Fuelman Cooper Fuels LLC
