RE: 1/10 Buggy Compatible Parts    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: 1/10 Buggy Compatible Parts
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: 1/10 Buggy Compatible Parts - 8/23/2007 5:14 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
for the single speed one, this comes with the bearings, not the washers: http://www.clermontmotorsports.com/servlet/the-200/Hpi-17-tooth-vented/Detail if you mean the 2 speed then no, it doesnt.
< Message edited by ehroof -- 8/23/2007 5:15 PM >
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to rowldog76)
       Post #: 301
RE: 1/10 Buggy Compatible Parts - 8/30/2007 6:22 AM
tyhodge07
Score: 100
Last Login: 3/28/2013
Status: offline
I just took these off my stampede and they fit right onto the tornado with no problem. idk if they've been posted before, but if not than here they are
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLR99&P=7 (just a little wider, but not really a difference once put on)
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDUZ6&P=M (might have the wrong link, but the ones that fit a rustler/pede)
< Message edited by tyhodge07 -- 8/30/2007 6:23 AM >
Hide Signatures
(in reply to ehroof)
       Post #: 302
RE: 1/10 Buggy Compatible Parts - 8/30/2007 8:28 AM
StephenW
Score: 100
Last Login: 1/18/2009
Status: offline
Nitro racer 1... this is kinda late but on ur car the only other thing i would recomend is a dif exaust header. Otherwise ur car is sweeeeeeeeet
Hide Signatures
(in reply to tyhodge07)
       Post #: 303
RE: 1/10 Buggy Compatible Parts - 1/7/2008 5:47 AM
Redharris
Score: 105
Last Login: 12/9/2012
Status: offline
Ok…..
I managed to fit some T-Maxx Shocks on my Volcano SV. The only thing you have to modify is the Top shock mount. If you buy the T-Maxx Shocks from the LHS, the kit has all the spacers you need. You also need to buy 8 socket head cap screws 3mm X 18. Also from the LHS. The Pictures should be self explanatory. I posted pictures of the truck with stock shocks in back and T-Maxx shocks in front so you could see the difference in Bore and Spring size.
I went with these inexpensive T-Maxx shocks because I wanted this to be an Everyman sort of project. You can get these Shocks on E-Bay for less than $20 shipped if you find a Bargain. This Mod drastically improves the driveability, and thrashability of your truck.
I gotta give a shout out to nitro_racer_1 , who’s Buggy Pics inspired me. Also Nantucket, who’ s Volcano SV rocks!. He pm’d me some info as well.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
Hide Signatures
(in reply to nitro_racer_1)
       Post #: 304
RE: 1/10 Buggy Compatible Parts - 1/7/2008 6:30 AM
ehroof
Score: 105
Status: offline
looks awesome bro, great job
Hide Signatures
(in reply to Redharris)
       Post #: 305
RE: 1/10 Buggy Compatible Parts - 1/7/2008 7:05 AM
Macanan
Score: 100
Last Login: 4/10/2011
Status: offline
Is there a steal tranny gear out there for both the 2 speed and single speed Tornado's ?
Hide Signatures
       Post #: 306
RE: 1/10 Buggy Compatible Parts - 1/7/2008 7:09 AM
rc_crazy21
Score: 100
Last Login: 2/6/2009
Status: offline
quote:
ORIGINAL: Macanan
Nothing as of yet from redcat!
Sponsered:
tricountyracing tricountyhobbies
Hide Signatures
(in reply to Macanan)
       Post #: 307
RE: 1/10 Buggy Compatible Parts - 1/10/2008 3:19 AM
arlo1
Score: 100
Last Login: 5/5/2008
Status: offline
To take full advantage of it you can change the exhause port duration to a lower number (compared to the transfer port for your state of tune and combination) than it would in comparison to a naturaly asperated 2 stroke. For eg alot of intake charge will blow out the exhauste port and not be forced back in by the pipe like it is suposed to with a supercharger with the exhauste duration of 190deg and transfer pot duration of 145 deg but If you run 145 transfer with a exhause duration of 175 deg it will stop some of the fresh air fuel charge from blowing out the exhauste out. This is one major concideration you need to look at if you are trying to use a supercharger thew whole engine needs reworking to make it work in most cases. Not saying how well or if it is worth it. As well the exhauste presure pushes the fuel into the carb and if you try to up the presure in the carb with a supercharger it will not get enough gas to run properly. I personaly would just run a higher percentage of nitro which is alot like using nitrous and I would jet it right if that didnt satify me I would port or replace the engine with a better one. These engines dont rev to there potential to begin with so I would look into that first. just my 2 cents. I have a RC Car chassis dynamometer if anyone has a project to be proved if it works or not I would be more then willing to help them out!
Tornado bb.
Hide Signatures
(in reply to Kemo)
       Post #: 308
RE: 1/10 Buggy Compatible Parts - 1/10/2008 3:22 AM
arlo1
Score: 100
Status: offline
quote:
ORIGINAL: trueman313
Quck question fella's, does anyone know if there are any other brands that the 47T throttle gear can be compatibel with the Tornado BB? I had the same problem as above that the gear was chewed up and rounded out. Looks exactly like the picture above. Any suggestions. Trying to buy from local hobby store then paying outrageous shipping costs and days waiting.
bump for answer
Tornado bb.
Hide Signatures
(in reply to trueman313)
       Post #: 309
RE: 1/10 Buggy Compatible Parts - 1/10/2008 5:12 AM
bjack29
Score: 100
Last Login: 1/17/2009
Status: offline
i have ran about a gallon of fuel thru my bb and the clutchbell spring are holding up well
Hide Signatures
(in reply to TORNADO BB)
       Post #: 310
RE: 1/10 Buggy Compatible Parts - 1/10/2008 5:13 AM
bjack29
Score: 100
Status: offline
i think the new clutch bell is great since they make them out of steel now
Hide Signatures
(in reply to bjack29)
       Post #: 311
RE: 1/10 Buggy Compatible Parts - 1/19/2008 2:31 AM
pede_187
Score: 100
Last Login: 8/10/2012
Status: offline
quote:
Ok…..
May I ask how exactly you modified the top shock mount?
Hide Signatures
       Post #: 312
RE: 1/10 Buggy Compatible Parts - 1/19/2008 3:15 AM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: arlo1
bump for answer
NG brother, nothing fits
Hide Signatures
(in reply to arlo1)
       Post #: 313
RE: 1/10 Buggy Compatible Parts - 1/22/2008 3:05 PM
jim_dixon
Score: 100
Last Login: 11/26/2008
Status: offline
I found some Tamiya tires that fit. SP-1240 (51240) for the front and SP-1241 (51241) for the rear. The description is "High Density Spike Tires K (4WD/Rear, 62/35)"
They come with foam inserts.
I'll let you know how they go after a few runs.
Hide Signatures
       Post #: 314
RE: 1/10 Buggy Compatible Parts - 1/23/2008 9:49 AM
Redharris
Score: 105
Status: offline
quote:
ORIGINAL: pede_kid
quote:
Ok…..
Hey Pede....
I used the SPACERS that come with the Shock kit. And I just threaded the 3mm X 18mm Cap head screw into the top shock mount.
I will try to take a Better Picture when Its Daylight and post it for you.
Hide Signatures
(in reply to pede_187)
       Post #: 315
RE: 1/10 Buggy Compatible Parts - 3/21/2008 7:34 AM
dominicevans
Score: 100
Last Login: 8/31/2012
Status: offline
quote:
ORIGINAL: TORNADO BB
Will a crowd pleazer body work on our buggies.I have the body posts.
plz post a link to one of them
speed is all I need
Hide Signatures
       Post #: 316
RE: 1/10 Buggy Compatible Parts - 3/14/2009 8:57 AM
like2race
Score: 100
Last Login: 8/20/2009
Status: offline
Hi I am looking for a compatable metal geared transmission single speed to replace a 2 speed transmission
any help apreciated
Cheers
HPI Baja SS stoker with Rear Dominator - Predator RC Baja with rear upgrade clone pipe
Hide Signatures
(in reply to dominicevans)
       Post #: 317
RE: 1/10 Buggy Compatible Parts - 3/14/2009 4:25 PM
joeyhatch11
Score: 109
Status: offline
I have yet to see any metal spur gears for these Rc's. I've heard that the two speed trannies are a pain and eat gears often. I have the single speed HyperSpeed by Exceed. Went through two main gears but they were my fault. As long as you have the right gear mesh you wont have any problems. The spur gear I have in there now has been in there for over a month and shows no sign of wearing.
Hide Signatures
(in reply to like2race)
       Post #: 318
RE: 1/10 Buggy Compatible Parts - 3/17/2009 3:43 AM
tornadobbstart
Score: 100
Last Login: 1/16/2010
Status: offline
Im looking for some monster truck tires or some truck tires that are bigger or wider than the stock tornado bb tires. Any one have any ideas? Thanks
Hide Signatures
(in reply to joeyhatch11)
       Post #: 319
RE: 1/10 Buggy Compatible Parts - 3/17/2009 4:29 AM
joeyhatch11
Score: 109
Status: offline
You can get truggy tires but I dont know how bad that's going to affect you low end performance.
Hide Signatures
(in reply to tornadobbstart)
       Post #: 320
RE: 1/10 Buggy Compatible Parts - 3/17/2009 7:38 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
Depending on how big you go, it will make your accel go way down
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
       Post #: 321
RE: 1/10 Buggy Compatible Parts - 3/17/2009 2:44 PM
joeyhatch11
Score: 109
Status: offline
I love double posts. Fun fun same answers, two different threads.
Hide Signatures
(in reply to chevyderek72)
       Post #: 322
RE: 1/10 Buggy Compatible Parts - 4/19/2009 8:57 AM
driving_a_chevy
Score: 100
Last Login: 6/4/2009
Status: offline
yes i got a tornado bb with the .18 and i was wondering whats the biggest motor i can put on this thing its my first nitro car
Hide Signatures
(in reply to Popper252)
       Post #: 323
RE: 1/10 Buggy Compatible Parts - 4/19/2009 11:55 AM
chevyderek72
Score: 100
Status: offline
If its your first i would learn to drive good first (not saying you cant drive but they take some getting used to if your new). With mods anything will fit. But you can drop in a sh 18 from redcat, and get the engine replacement program and get it for 45 bucks. Great improvement, great engine. And there is a os engine, i think the cr-vs or something like that which is even better, but a lot more expensive, and also the os tz, which ive heard is nuts. But you'll probably be blowin out your drivetrain by then.
Its me ti**ta
Hide Signatures
(in reply to driving_a_chevy)
       Post #: 324
RE: 1/10 Buggy Compatible Parts - 4/19/2009 1:12 PM
driving_a_chevy
Score: 100
Status: offline
well see my buddy has the s-maxx with the 3.3 and i drive it all the time i like it its fast and i want mine to go faster than what it does what can i o to it to make it faste like parts just let me know what all i can do
Hide Signatures
       Post #: 325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
