Rezagh
CA, USA Status: offline
Hi Dale, Well it's not unexpected! See when servos work really hard to give you max juice, they do sometimes burn as 180 ozin servo is the minimum requirement for this plane, Servos under lots of load sometimes just can't take it anymore. That's why it's recommended to use higher torque servos like 5955 or 8611. 5955 are going to be fine and you won't see that problem any more. Thank you for sharing your experience with us. Good Luck, Reza Quique's Aircraft Support
< Message edited by Rezagh -- 4/5/2006 10:11:13 PM >
_____________________________
Quique's Aircraft Company
