RE: build composite aircraft
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> RE: build composite aircraft Page: <<   < prev  1 [2]
Login
RE: build composite aircraft - 3/29/2006 6:58:10 PM
Rikard Levenstam
From: Stockholmwww.modellbyggeriet.se/sukhoi, SWEDEN
Status: offline
www.cnczone.com
(in reply to ptxman)
       Post #: 26
RE: build composite aircraft - 3/29/2006 11:10:03 PM
daven
Status: offline
Just curious, how would you join a two piece mold cut out of aluminum?
I have a quickie wing mold that Wayne Seiwert made for me, but I would really like to get one made out of aluminum, but the costs are very expensive. Not sure if you have any interest in laying up and selling wings after completion, but there would be a market for wings like this if done in the right airfoil.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to Rikard Levenstam)
       Post #: 27
RE: build composite aircraft - 3/29/2006 11:47:31 PM
cncfoam
Status: offline
yep. cnczone.com If you click on forums, then DIY cnc machines, then wood routers, cnc wood router project log, then last is "Quick build cnc router" this is my build log for my machine.
Not sure, but should probably keep comments of building machine over there on cnczone.
DAVEN, To join a mold, cut out left and right, butt them together at the root. Im thinking that would work.. but then again Ive never done it. Yea, I would try it. You have a design in mind.
EZ
(in reply to daven)
       Post #: 28
RE: build composite aircraft - 3/30/2006 12:06:25 AM
daven
Status: offline
Yes I do.
Naca 66-012, 52" long with 500 square inches total area minimum.
The wing thickness needs to be 1 3/16" measured with a no go gauge. You want to be as close as possible, but it has to be thick enough.
An area I think can be slightly improved with the current designs are the wing tips, but I am no expert there.
I have several cross sections of the more popular designs from cracked wreckages (all composite).
Dave Norman
klasskote.com
supertrc.com
(in reply to cncfoam)
       Post #: 29
RE: build composite aircraft - 3/30/2006 2:33:47 AM
cncfoam
Status: offline
I still need to do a little testing and will need help from the list. but i will take a crack at it. Probably do it out of MDF first, then try aluminum. I am going to call my cnc buddy and see what I need to do to convert some SW files into g-code.
I think that we could do the whole process right here on this forum. I can take pictures and post results.
EZ
(in reply to daven)
       Post #: 30
RE: build composite aircraft - 3/30/2006 4:09:52 AM
daven
Status: offline
Just let me know what you need and I will help out as much as I able.
Have you ever cut epoxy board? I have a friend who was looking for molds cut out of this material, although I am not all that familiar with it.
Dave Norman
klasskote.com
supertrc.com
       Post #: 31
RE: build composite aircraft - 3/30/2006 4:26:01 AM
cncfoam
Status: offline
quote:
ORIGINAL: daven
I would assume that the router could cut it. Why dont you sent me an email, jjme @ comcast. net (put together)
Eric
(in reply to daven)
       Post #: 32
RE: build composite aircraft - 3/31/2006 12:25:07 AM
cncfoam
Status: offline
I just finished a test cut. I used some regular, floor underlayment particle board.
I took the profile of an airfoil, converted the profile, then I set up my machine to cut into the board, index over .00629", cut the profile, step over, etc. I think the total step over was about 3/4", so it almost looks like a mold for some wheel pants.
The airfoil was 5" long. just a simple naca 0009.
I used a 1/4" ball nose carbide cutter.
My machine cut out this female mold spectacularly. The entry and exit was dead on. you cant tell by the picture, but it came out super smooth.
I think I will cut out the male part as a test, and use MDF.
EZ
Click to see fullsize image.
Click for fullsize
       Post #: 33
RE: build composite aircraft - 3/31/2006 3:12:10 AM
ptxman
Status: offline
Looks good. For sure I think your setup could make semi-decent plugs if you were prepared to surface coat & finish, at least 95% of the surface shape is there. Here is an mdf (female) mold I have seen for surface comparison. Havent seen the finished one yet. Also shows a bit of the tear out problem I was mentioning along the lamination when the surface angle is shallow relative to the glue joint line.
Click for fullsize
< Message edited by ptxman -- 3/31/2006 3:14:25 AM >
       Post #: 34
RE: build composite aircraft - 3/31/2006 5:18:38 AM
daven
Status: offline
Looks very good. I have been tied up all day and just caught this.
Where in Minnesota are you?
Dave Norman
klasskote.com
supertrc.com
       Post #: 35
RE: build composite aircraft - 3/31/2006 10:19:24 PM
cncfoam
Status: offline
quote:
ORIGINAL: daven
Im in Brooklyn Park.
got your email
Eric
I think your friend, Randy emailed me too.
talk to you later.
(in reply to daven)
       Post #: 36
RE: build composite aircraft - 3/31/2006 10:24:12 PM
daven
Status: offline
Cool, I work in Maple Grove, right off 169 and 694. Yep, Randy is the guy I mentioned, a good friend.
Dave Norman
klasskote.com
supertrc.com
       Post #: 37
RE: build composite aircraft - 4/3/2006 3:51:15 PM
2wingsonly
Status: offline
Ok here is a really crazy thought but here it goes anyway. If you are looking for a way to create a smooth finish could you spray the inside of the foam mold with a multi-layer of a dry wall material? Then run it through the router? I use this method to cover foam blanks for canopies to fill holes. (the following would not be part of your process) Then I create a plaster mold (the -). And then pour plaster for the positive. Your machine could make killer blanks for vacuum forming canopies as well.
(in reply to daven)
       Post #: 38
RE: build composite aircraft - 4/4/2006 1:24:43 AM
cncfoam
Status: offline
I dont think I would like the dust, but Im sure it could be done. I was also thinking, in the back of my mind, I believe the auto industry uses some sort of modeling clay, and they use a 5 axis router to create prototypes.
I would need to find a longer router bit, because you need clearance below the gantry to do any deep stuff like canopies and the like.
EZ
(in reply to 2wingsonly)
       Post #: 39
RE: build composite aircraft - 4/9/2006 12:33:04 AM
cncfoam
Status: offline
js3, I sent a PM to you, not sure if you got it.
mustang, I sent PM to you too.
Let me know if you got them
Eric
or send email to jjme@comcast.net
