Which Fuel to use?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Which Fuel to use?
Page: [1] 2   next >   >>
Login
Which Fuel to use? - 3/25/2006 8:46:23 PM
SaK610
Status: offline
Hello, i was wondering wich of both these nitro fuels would be better (for a Traxxas Revo 3.3(if that matters)), i have the options of both Morgan Backyard Basher 20% and XP Car Extreme 20%, i heard people say Morgan fuel is good, but i never heard of XP fuel, any help appreciated, thanks.
< Message edited by torque wrench -- 4/1/2006 11:44:39 AM >
       Post #: 1
RE: Wich Fuel to use? - 3/26/2006 3:05:58 AM
loughbd
Status: offline
Any 20% fuel is good. When you buy that "car" stuff, you are paying a fortune for a name. It's the same stuff airplane guys use.
(in reply to SaK610)
       Post #: 2
RE: Wich Fuel to use? - 3/26/2006 4:46:33 AM
ace420
Status: offline
odonnell 20%
(in reply to loughbd)
       Post #: 3
RE: Wich Fuel to use? - 3/26/2006 7:22:20 AM
loughbd
Status: offline
Which probably costs twice what Cool power, Power Master, Wildcat, etc 20% costs. YS20-20 is 20 bucks a gallon. You car guys are paying that for a quart.
(in reply to ace420)
       Post #: 4
RE: Wich Fuel to use? - 3/29/2006 7:47:55 AM
ace420
Status: offline
cool power is plane fuel and has to much oil for cars. also might not get as much power with it. odonnell is 25$ a gallon
       Post #: 5
RE: Wich Fuel to use? - 3/29/2006 4:10:17 PM
Dil
Status: offline
well the airplane fuels are fine, more oil its better for the engines as well, for people who race all day long thoose fuels with less oils and the big names is good, but for most of us who just have fun and play i really see no point in buying racing fuels, its actually a waste!!
i have a tamiya TNX i i use my own mixed fuel i run about 7 to 8% nitro and it runs perfectly! with the stockl engine and about 17 to 20% oil, plenty of power and acceleration of the block, i can even wheelie sometimes on the grass
_____________________________
I Could'nt Fix Your Breakes, So i hooked up a loud Horn
       Post #: 6
RE: Wich Fuel to use? - 3/29/2006 8:04:47 PM
loughbd
Status: offline
Too much oil, huh? Funny how OS recommends no less than 18 % oil and that is what cool power has. I have several OS 21VF-C car engines and that's what the instructions say.
(in reply to Dil)
       Post #: 7
RE: Wich Fuel to use? - 3/30/2006 4:22:01 AM
ace420
Status: offline
Additional Fuel Information
If you read the R/C car magazines, engine instruction manuals or talk to local racers, you'll likely find conflicting information about car fuels. The main controversy seems to focus on how much and what type of oil is needed for a car fuel.
Here the straight scoop based on over 15 years of experience that includes working closely with engine manufactures, industry experts, top-level racers and the results of testing literally hundreds of formulas in all types of car engines and conditions.
Why Not Airplane Fuel
Car engines operate in a totally different environment than do airplane engines. Airplane engines spend a great deal of their running life at full rpm, they have a constant airflow from the prop to aid in cooling and instant throttle response and acceleration is not as critical as with a car engine.
Car engines spend most of their life accelerating from one corner to the next and are seldom at full RPM for more than a few seconds. They rely on an oversize heat sink head to dissipate combustion heat and racers actually tune car engines based on throttle response.
Fuel designed for airplanes typically have from 15 to 20% oil. While the manufactures that truly understand the requirements of car engines typically put 8 to 12% oil in their car fuel.
Why 8% to 12% Oil
Using high oil content fuels (above 15%) in gas car engines won't provide improved engine life, as some would expect. Through extensive testing we've discovered the point of diminishing return as far as oil content to engine life is actually around 8% for most car engines. In other words any more oil than 8% in the fuel does noting to improve the life of a car engine. In fact the secondary effects of high oil content fuels can actually cause engine damage by encouraging over lean runs. Here's how.
Using high oil content fuel causes a car engine to be unresponsive during acceleration acting as if the engine were running rich. Typically when using high oil content fuel, in order to get crisp acceleration and response, an engine will need to be adjusted overly lean. In addition the high oil content prevents lean bog when an engine is over-leaned thus allowing the engine to run at this lean setting without the customary telltale lean bog warning letting you know the engine is overheating.
In summary, high oil content fuels don't give added protection. The point of diminishing return from a protection standpoint in a gas car application is about 8% oil depending on the oil type and engine. Anymore oil than this doesn't offer added protection and has potential secondary effects that reduce performance and can actually cause you to over lean your engine in an attempt to get crisp throttle response and acceleration. Do yourself a favor and follow these two rules:
(in reply to Dil)
       Post #: 8
RE: Wich Fuel to use? - 3/30/2006 5:17:22 AM
Dawman
Status: offline
I remember once at a race a guy was running some airplane fuel . He had no power at all . We asked what he was running , think it was wilcat or cool power. He said that he was told he could use it and has for few months he got into nitro . We gave him some O`Donnel 20% and he was in shock the difference. So I guess if you just put around the yard ok then . If you do any racing , you sure won`t be winning with that stuff.
SH Engines
       Post #: 9
RE: Wich Fuel to use? - 3/31/2006 2:08:45 PM
speedracer1129
Status: offline
it really doesn't have to deal with racing Dawman! everyone wants to have their cars running their best even when we are playing! that is why it is only logical that we use the proper fuel for theproper purpose
(in reply to Dawman)
       Post #: 10
RE: Wich Fuel to use? - 3/31/2006 3:22:57 PM
Sport_Pilot
Status: offline
IMO the car engines are under a lot more stress thant the aircraft engine. Only speed racers prop their planes for 20K plus RPM. Constantly accelerating from idle to full speed is a lot more stress than running a constant 12K or so. I would think the car engines would last a lot longer with more oil. Airplane racers have been known to lower the oil for more power as well. But at least they are aware that they may have to junk the engine after a short time.
(in reply to speedracer1129)
       Post #: 11
RE: Wich Fuel to use? - 3/31/2006 7:00:06 PM
Dawman
Status: offline
quote:
ORIGINAL: speedracer1129
NO S**t ! I was saying if these people want to use airplane fuel let them . I made a comparison as to how it performs using the right fuel . I would never use airplane fuel and beleive no one should in cars . People want to be cheap and get that stuff . I`ve been through this years ago when I see people using the wrong fuel , you try to convince them to use the proper fuels , but all they look at is the price . So I figure if thats what they want and won`t change, heck with them . Also if you took the time to read , all I said is that you sure won`t be winning any races with airplane fuel.
SH Engines
       Post #: 12
RE: Wich Fuel to use? - 3/31/2006 8:14:27 PM
Sport_Pilot
Status: offline
quote:
ORIGINAL: Dawman
You do know that they are over charging you for the fuel, don't you? Fuel with less oil should cost less not more. I would consider mixing my on fuel, experment with fuel and glow plugs. I suspect you would have an edge on the competition.
       Post #: 13
RE: Wich Fuel to use? - 3/31/2006 9:08:08 PM
loughbd
Status: offline
Won't win any races using airplane fuel??? Would you like to see all my boat racing trophies? I raced Namba class A hydro, Class B hydro and Class A outboard. Used 15 to 20% nitro with 18% oil. Boat racing is just as demanding on engines as car racing. As a matter of fact, I even used a OS21VF-C in my A hydro. That is a CAR engine. We used them to eliminate the hassle of water cooling. With a tuned pipe they turned around 26,000. That was on AIRPLANE fuel as you call it.
Don't tell me that car racing is all that different from boats. Boats can be worse especially if you lost the water cooling. Or you blew off and had no load on the engine. With a tiny prop and tuned pipe response was almost instant. That's why we all ran RPM titanium rods.
Oh and I used those same Car engines in CARS using the same fuel. Worked just fine. I still have 4 of those engines new in the box. I bought them 8 to the case diestly from Japan
< Message edited by loughbd -- 3/31/2006 9:11:27 PM >
(in reply to Sport_Pilot)
       Post #: 14
RE: Wich Fuel to use? - 3/31/2006 9:42:29 PM
ace420
Status: offline
more oil does not mean better than less most of t
