Winds or no winds ( for speed records )    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> Winds or no winds ( for speed records ) Page: [1]
[Poll]
Yes , ANY speed winds allowed
  27% (3)
Absolutely not ... thats cheating
  9% (1)
yes , but no more than 5 MPH winds
  54% (6)
yes , but no more than 10 MPH winds
  0% (0)
yes , but no more than 15 MPH winds
  9% (1)
Total Votes : 11
(last vote on : 4/18/2006 5:36 AM)
(Poll will run till: -- )
Login
Winds or no winds ( for speed records ) - 3/26/2006 12:30 AM
TERBObob
Score: 100
Last Login: 8/8/2009
Status: offline
Oh , thought about this and also found out by accident .
It was kinda breezy last night and I went out and tested an airboat .
Thing is , it went FASTER with the wind to it back and KNEW that this helped the speeds out a LOT .
So , with 15 MPH tailwinds ... not sure how much faster , but I know the boat DID indeed run faster .
So , my poll is this ..
When going for the record ... should the winds be allowed or not and if yes , what would be the max allowable ?
_____________________________
"experienced " is just another way of saying that you already did all the mess ups and should know better now !
Hide Signatures
       Post #: 1
RE: Winds or no winds ( for speed records ) - 3/26/2006 7:31 AM
Mr Cajun Gator
Score: 100
Last Login: 9/25/2012
Status: offline
for any speed test to be fair, it should be made in two passes. First pass in whatever direction the driver wants, then turn around, run back in the exact opposite path. Average the 2 speeds.
Catch a Gator by the Tail and hang on for the Ride!
Cajun Gator Airboats, M.AB.A
Hide Signatures
(in reply to TERBObob)
       Post #: 2
RE: Winds or no winds ( for speed records ) - 3/27/2006 1:23 PM
Doubledog
Score: 100
Last Login: 3/28/2013
Status: offline
what he said /\
thought you knew that?
You never know what your faith is, until your faith has been truly tested. Mine is being tested and I''''m praying...
Hide Signatures
(in reply to Mr Cajun Gator)
       Post #: 3
RE: Winds or no winds ( for speed records ) - 3/27/2006 5:58 PM
TERBObob
Score: 100
Status: offline
Reason I asked , is that some of the vids that I have seen of the fellows going for speed , seem to be ONLY going in ONE direction . ( not saying that the vids I viewed , were where they had a tailwind , but ... just food for thought since they seem to be only running ONE way when using their radar and with a tailwind , this could CERTAINLY aid them with their speeds )
Hide Signatures
(in reply to Doubledog)
       Post #: 4
RE: Winds or no winds ( for speed records ) - 4/2/2006 2:51 AM
Rowboat
Score: 100
Last Login: 12/11/2012
Status: offline
I agree with the two passes in opposite directions,then average out the two runs.
This will then cancel out the wind assist argument .
Boating is not a matter of life or deth, It is more important than that !!
Hide Signatures
       Post #: 5
RE: Winds or no winds ( for speed records ) - 4/3/2006 5:58 PM
jasperrc
Score: 100
Last Login: 8/12/2011
Status: offline
The only problem I see with doing it this way (averaging the speeds of a run in each direction) is bringing the boat back in to check and clear the GPS between runs.
Realistcally, any single top speed recorded either on GPS or by radar is a snapshot of a split second in time and may not be representative of the highest speed the boat can do consistently. Perhaps a more accurate method would be to average the top speed of say 3 or 5 runs in calm or very light (under 5 mph winds) wind conditions.
Of course all of this brings up the question, what about those folks running on a stream, river, or other body of water with a current? This will have an impact on speed as well.
Jasper
Hide Signatures
(in reply to Rowboat)
       Post #: 6
RE: Winds or no winds ( for speed records ) - 4/3/2006 6:27 PM
TERBObob
Score: 100
Status: offline
Good point .... running on only a lake ...I never thought about that one .
And yeah .. there are some HIGH moving streams ... ( got one REAL close by . Heck , I could just PLACE my NOT running hull in the water and it would travel at around 5 to 10 mph by itself - LOL )
Hide Signatures
(in reply to jasperrc)
       Post #: 7
RE: Winds or no winds ( for speed records ) - 4/5/2006 2:34 AM
boatman1
Score: 100
Last Login: 4/3/2013
Status: offline
Now you got me lol running down stream & with a tail wind
Im busted lol
but i guess 24 mph isnt no record but it gives me a idea
of how fast my slowest nitro airboat go's & that was a 2 way run by radar on
a pond with a old wore out .os .30 with a 9x6 MA prop & a wore out coraplast hull
on 15% nitro fuel
NOt bragging just the facts , it was fun to find out what it did
< Message edited by boatman1 -- 4/5/2006 2:36 AM >
i play harder then most people work
Hide Signatures
       Post #: 8
RE: Winds or no winds ( for speed records ) - 4/7/2006 3:38 AM
Ron Olson
Score: 1175
Last Login: 5/24/2013
Status: offline
You can't have a speed record unless it's on an approved course with the proper timing equipment and a GPS ain't gonna get it.
In the NAMBA and IMPBA record trials you make passes in both directions without a stop in between runs otherwise they don't count. It's a gamble as to when the passes are made, early morning, before sundown or any time in between as you can get a good or bad run at any time. It can be dead calm when you fire u but have a gust of wind come up by the time you're going through the traps.
Keep in mind that Andy Brown's 120 +MPH passes were done in less than ideal conditions with the boat that hadn't been dialed in yet! With the right hull design you can actually go faster into the wind than with it as it can lift the hull making it lighter on the water.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to boatman1)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.609RCU1
