Airworld baby Cougar
Guys
After the success of my first AW Cougar EDF conversion, except the dolly system-I decided to have another go with retracts.
Micro Springair units fit with a little work, the only thing I really need is a FOD to stop stones going through the wheel openings, as these also go into the inlet ducts.
Lambert T32 as before.
I should fly it soon if the wind drops in the UK.
Dave Wilshere
Dave Wilshere
RE: Airworld baby Cougar
Is that the 1 1/2 Kg thrust Lambert? A friend has one in a foamy (Multiplex Twinjet) and I'm the hand launch volunteer (I suppose that's what he meant when he called me a tosser!) A superb little engine. - John.
John
Yes, They were flying one in a twin Jet at JetPower when I damaged my first Cougar.
Gear means no more dodgy launches!
Dave W
Dave W
He's a wake up to inconsistent launches too, he was showing me a bungy launch cradle plan today. He had to epoxy some carbon on the foam elevators as they were blowing flat at high speed, all good now. Question, how do you start it? There does not look to be enough space for the blower gadget, have you put an extension tube on it & push it through an inlet? - John.
Banned
My Feedback: (119)
Good move. Bungees are for securing plywood atop a car. Dollies are for little girls. Planes need landing gear!
Cougar looks great, should fly great, the six extra ounces or whatever should not matter at all. You are probably still lighter than the original stuffed full of nicads.
Flew my ducty, a pleasant little airplane...
ET
Its the same weight as Mk 1 due to AW's new moulding methods...
Yep, flew my Ducty yesterday, try full bore-negative opposite sticks flick!
Dave
Dave
Banned
My Feedback: (119)
ORIGINAL: Dave Wilshere
ET
Dave
ET
Dave
You should get one of the AMD/Aero-Fever foamie Hawks. The bare airframe is only a pound. You will be getting 1-1 T-W! Voiticle pahformance, as dey say in Brooklyn! I did a thread on it somewhere, if you want to check it out...
Banned
My Feedback: (119)
I am always short a toki rotor or two! The only other part that goes is the pull start assembly, I have plenty of those.
Say...do you think you can get a Scorpio Skyray for review purposes without it costing me an arm and a leg? Scorpio seems to have sold the design to a German company that I cannot contact...
