Robbe SF-36
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> Robbe SF-36
Page: [1]
Login
Robbe SF-36 - 3/28/2006 7:45:42 AM
flightmate
Status: offline
greeting to all this is my first posting to this website so please try to be gentle
today i bought a used Robbe SF-36 motor glider from a local hobby shop the aircraft itself is in great shape save the missing main spar metal joiner to plug the wings to the fuselage , anyone have a copy of the instruction manul and or could cut me a copy of there spar wing joiner, would really love to get this bird airborne.
what can i say was a good deal for the plane and figure someone out there might have another and could copy it for me, of course i would pay for the materials and labor ,to copy it ,but be nice the SSI check is only so big
thanks for any and all assistance
John
       Post #: 1
RE: Robbe SF-36 - 3/28/2006 7:28:03 PM
daveosoar
Status: offline
My mate (nowdead!) had one. As I remember it was a single joiner with incidence pegs. Was it a rod or blade joiner? Either is easy to replicate. Just a length of spring steel. However it may well be a Metric size, easy in Europe but in the US?
(in reply to flightmate)
       Post #: 2
RE: Robbe SF-36 - 3/29/2006 6:38:19 AM
flightmate
Status: offline
thanks for the repl yes it is a flat piece of either alluminum or spring steal and as far as i can tell 2mm thick and about 12 mm tall but not sure on the lenght or dihedreal needed
that is the kink if someone had one they could trace out then i could easly replicate it from local stock
       Post #: 3
RE: Robbe SF-36 - 3/29/2006 6:54:20 PM
daveosoar
Status: offline
Hi flightmate,
This a standard system of asteel blade. ?Does the slot go right through? If so it is probable that the dihedral is taken care of in the wing.
This very common in europe and the spring steel blades are available easily.I buy 1M lengths as required. I'm sure someone like a Multiplex importer should be able to help. If you have a real problem give me accurate dims inc. total length, I may be able to help.
David.
       Post #: 4
RE: Robbe SF-36 - 4/3/2006 8:00:11 AM
flightmate
Status: offline
dave soar , yes the slot in the fuselage goes completely thru the fuse, i was thinking along the same lines as they mayhave built in the dihedral in the wing slots and only need a flat piece, i was looking at an aluminum yard stick and got to thinking it is the right thickness and could easly cut it down to the right height but worried about flight loads, so i think i shoud follow your advice and find some spring steal at a scrap yard, would be nice to get her in the air
(in reply to daveosoar)
       Post #: 5
RE: Robbe SF-36 - 4/3/2006 7:57:25 PM
daveosoar
Status: offline
Use only spring steel which is a firm fit and full length thro' fuz and both wing slots.
Dave.
       Post #: 6
RE: Robbe SF-36 - 5/14/2006 12:45:21 AM
mrkite
Status: offline
Have a new kit here and this is what you need for the wing is 2 pices of Spring Steel 12x 2x 322 mm Here is how it all goes together Hope this helps Craig mrkite2integraonline.com
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 7
RE: Robbe SF-36 - 5/19/2006 5:35:23 PM
flightmate
Status: offline
Thanks MrKite,
i was wondering why there are 2 square slots on each side of the fuselage, never occurred to me tobe a 2 piece spar hmmmm doooooopppppp
oh well explans allot, brain cramp 1 pilot 0
thanks will get a new spar cut thanks again
       Post #: 8
RE: Robbe SF-36 - 5/22/2006 1:11:40 AM
forus
Status: offline
I have this plane and I must say it has been one of my favorites....It is now waiting for a full refurbish since I have flown it and flown it since I got it in -99 (my plane is from -86).. I wonder what size engine it is supposed to have? Mine came with an ASP 75 2-stroke, way overpowered, giving me 2 metres takeoffs! I want the plane to be a gentle, slow flyer so I want to fly with the design engine size.
       Post #: 9
RE: Robbe SF-36 - 5/22/2006 11:31:45 PM
daveosoar
Status: offline
Forus,
Now is the time to go electric!
David.
(in reply to forus)
       Post #: 10
RE: Robbe SF-36 - 5/23/2006 3:52:31 AM
forus
Status: offline
electric you say Sure, it would be a dream, but what size brushless would this plane take? I planned to put my old Saito twin cylinder (2x40) motor on it, but electric is actually more tempting.
       Post #: 11
RE: Robbe SF-36 - 5/26/2006 10:54:13 AM
daveosoar
Status: offline
Try the Axi series of outrunners. They swing a nice big prop without a gearbox.
I fly a 1/4 Scale Fournier on an Axi 4120/18 swinging a 15x10 wooden prop and 5S1P 3300 LiPo pack, lovely 'brisk' scale performance and plenty of airtime - it does glide!
(in reply to forus)
       Post #: 12
RE: Robbe SF-36 - 6/6/2006 8:59:20 AM
flightmate
Status: offline
Davesoar
where did you get the 1/4 Scale Fournier
always liked that aircraft
thanks john
       Post #: 13
RE: Robbe SF-36 - 6/7/2006 12:30:39 PM
daveosoar
Status: offline
Hi F'mate,
Built from a plan by one of the best known UK designers. Trouble is I cant remember his name! Its on the plan so I'll dig it out and post it here ASAP. I think its an age problem!!
David.
       Post #: 14
RE: Robbe SF-36 - 6/9/2006 7:09:37 AM
daveosoar
Status: offline
Flightmate,
The Fournier was from a Mick Reeves plan. Another source for a similar motor glider, the Falke, plans by maestro Cliff Charleswoth, can be found, I think, on the 'aviation modeller international' site.
Daveosoar.
