RE: Thunder Cat 31    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31 Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Thunder Cat 31 - 8/29/2006 4:23 AM
Raylon
Score: 101
Last Login: 10/12/2012
Status: offline
Well, the bottom line going to the carb where it is connected to the tank leaks on mine. Use wire and twist it around it tight, thats what I did to prevent it from leaking.
_____________________________
Shockwave-M
E-Flite Blade CP - E-Flite Blade CX
Hide Signatures
(in reply to kuperman)
       Post #: 801
RE: Thunder Cat 31 - 8/29/2006 6:18 AM
tunnel222
Score: 100
Last Login: 10/27/2012
Status: offline
ANY ONE FOUND THE PERFECT PROP FOR THE THUNDER CAT?
Hide Signatures
(in reply to wave waker)
       Post #: 802
RE: Thunder Cat 31 - 8/29/2006 6:20 AM
Ron Olson
Score: 1175
Last Login: 5/25/2013
Status: online
Not the perfect prop yet but the Octura M-445 is close.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to tunnel222)
       Post #: 803
RE: Thunder Cat 31 - 8/29/2006 6:35 AM
Raylon
Score: 101
Status: offline
Yea, but it has be sharpened and balanced and the boat has to be running real good for it to work. At least on 20% that is. Mine has trouble revving up with it. And when it does it seems to catch air and flip.
Shockwave-M
Hide Signatures
(in reply to Ron Olson)
       Post #: 804
RE: Thunder Cat 31 - 8/29/2006 7:28 AM
TwistedLiquid
Score: 100
Last Login: 8/30/2006
Status: offline
Perfect prop for the Kat is 225...but not on 20%...Mike has tested many props on the TC 31...and I would say hes got the fastest Kat and master a perfect prop. But we hope in a couple day it will be our Kat A Twisted Kitty sounds good to me.
James
TWISTED LIQUID RACING
Hide Signatures
       Post #: 805
RE: Thunder Cat 31 - 8/29/2006 7:31 AM
Ron Olson
Score: 1175
Status: online
One problem that you'll find is that out of the box, the strut is too high. It helps to get the engine to wind up but at the expence of cavitation.
269 Racing Team
Hide Signatures
(in reply to TwistedLiquid)
       Post #: 806
RE: Thunder Cat 31 - 8/29/2006 7:35 AM
TwistedLiquid
Score: 100
Status: offline
Here might be a better cure for your leak. The wire may cut into your line due to vibration. If you will cut off a piece of fuel 1/8 in length, then place the piece of tubing over the end of a closed pair of needle nose pliers. Open the needle nose to stretch out the tubing, then take your fuel line and place it thru the center of your stretched out tubing and release the needle nose. You should have your 1/8 over the very end of your fuel..then connect it to the tank...no leak you should find.
James
Hide Signatures
(in reply to Raylon)
       Post #: 807
RE: Thunder Cat 31 - 8/29/2006 7:40 AM
TwistedLiquid
Score: 100
Status: offline
I agree with ron check you strut depth...this is critical to run proper. but if you are blowing out quickly, you might want to throw some negative on the strut to point the nose down a bit. And I would boost my nitro a bit...Mike runs 40% and does very well.
James
Hide Signatures
       Post #: 808
RE: Thunder Cat 31 - 8/29/2006 8:23 AM
toyotatruckin
Score: 100
Last Login: 5/24/2013
Status: offline
hay do it the easy way with a zip-tie
quote:
ORIGINAL: TwistedLiquid
http://www.youtube.com/user/toyotatruckin
www.aircapitolhobbies.com
Hide Signatures
       Post #: 809
RE: Thunder Cat 31 - 8/30/2006 5:20 AM
Raylon
Score: 101
Status: offline
I have used about 20 different strut positions, from all the way up to all the way down to everywhere inbetween. I have also adjusted the angles. Nothing seems to make it run quite right.
I tried zip-tie, didn't work to well, still leaked. Th wire has done the trick.
Shockwave-M
Hide Signatures
(in reply to toyotatruckin)
       Post #: 810
RE: Thunder Cat 31 - 8/31/2006 7:31 AM
kuperman
Score: 100
Last Login: 2/3/2007
Status: offline
Well I am still out of a boat at this time. I got my rudder and attempted to put it on, but the rudder arm was also damage when the rudder broke off. The set screw will not tighten enough to hold the rudder in place. I ordered a new arm today, so hopefully it will be in early next week, until then I will have to run my T-Maxx
Hide Signatures
       Post #: 811
RE: Thunder Cat 31 - 8/31/2006 3:49 PM
brownvhf
Score: 100
Last Login: 3/31/2009
Status: offline
Most of the people that run the TC31 have had to go to a bigger set screw because of the original striping out. These can be picked up at your local hardware store. Just retap the hole and put the new screw in. T-Max is a lot of fun too. Jerry
Hide Signatures
       Post #: 812
RE: Thunder Cat 31 - 9/6/2006 6:32 PM
gooycheese
Score: 100
Last Login: 7/18/2010
Status: offline
well i am still looking for a new carb, and over the winter think im going to look at a new motor. i really like the idea of a .45 would anyone have any recommendations on which motor i should try? hope everyone is doing good i miss your posts on improvements. at the present time i am really hurting finacially so i havent done nothing to my boat and i am hoping to maybe be able to run before the end of the season.
thanks Paul
Good Luck and Good Boating. :)
Hide Signatures
(in reply to brownvhf)
       Post #: 813
RE: Thunder Cat 31 - 9/7/2006 11:44 PM
kuperman
Score: 100
Status: offline
Has anyone put foam into the TC31 to keep it from sinking, if it flips over?
Hide Signatures
(in reply to gooycheese)
       Post #: 814
RE: Thunder Cat 31 - 9/8/2006 3:49 AM
impulse
Score: 100
Last Login: 4/29/2013
Status: offline
Yes Kuperman, pool noodles.
Hyper 7 PCR
XXX-BK
Hide Signatures
       Post #: 815
RE: Thunder Cat 31 - 9/8/2006 6:03 AM
Raylon
Score: 101
Status: offline
quote:
ORIGINAL: kuperman
Look in the sides. Just cut up pieces of it and glue them in. I used the same stuff to seal shower doors. Nasty stuff but does the trick. Works like a charm to keep it form sinking.
Click to see fullsize image.
Click for fullsize
Shockwave-M
Hide Signatures
       Post #: 816
RE: Thunder Cat 31 - 9/8/2006 11:35 PM
kuperman
Score: 100
Status: offline
Thanks for the info, I happen to have a few around the house. I am going to try them without glue. Therefore if I need to remove them I can. Thanks again.....
Hide Signatures
       Post #: 817
RE: Thunder Cat 31 - 9/13/2006 8:45 PM
lc newbie
Score: 100
Last Login: 11/6/2006
Status: offline
has anyone else had any problems with tiger drive for this boat? i seem to have chewed a few gears and i just want to know is it something i've done or is there a flaw with it. i did have it seated right when installed.
Hide Signatures
       Post #: 818
RE: Thunder Cat 31 - 9/13/2006 9:00 PM
Ron Olson
Score: 1175
Status: online
Yeah. You'd have to go back a few pages to see where one person ditched his Tiger Drive in favor of the pull-starter.
Sullivan guarantees their parts so you can contact them or Horizon Hobby about the problem.
269 Racing Team
Hide Signatures
(in reply to lc newbie)
       Post #: 819
RE: Thunder Cat 31 - 9/13/2006 11:23 PM
Raylon
Score: 101
Status: offline
Make sure that when you get it repaired, or if you do, grease it up. It's a must. I grease mine every once and a while. Keeps it running smooth.
Shockwave-M
Hide Signatures
       Post #: 820
RE: Thunder Cat 31 - 9/14/2006 12:45 AM
brownvhf
Score: 100
Status: offline
Horizon will replace the the tiger drive as they have replaced two of them for me. I went to a pull start and not sorry as it works well. Quite a few people have had there tiger drives go bad. As far as adjustment, there isn't any I'm aware of. Just keep it greased good. Jerry
Hide Signatures
       Post #: 821
RE: Thunder Cat 31 - 9/14/2006 4:10 AM
kuperman
Score: 100
Status: offline
When you talk about greasing the tiger drive, do you mean the part in the boat are the handheld portion. I have not figured out how to get into the handheld portion.
Hide Signatures
       Post #: 822
RE: Thunder Cat 31 - 9/14/2006 6:28 AM
Bullitt01
Score: 100
Last Login: 7/12/2009
Status: offline
part in boat...
Hide Signatures
       Post #: 823
RE: Thunder Cat 31 - 9/14/2006 7:29 AM
FE_Chris
Score: 100
Last Login: 10/22/2012
Status: offline
OK, The gear mesh must be all wrong. The problem is that you have to set it without looking at it. So it is quite hard to get proper mesh. I have done so ONCE when I first got the TC31. No Problems. Just a tick of play in the gears and some heavy grease....you'll be all set.
GEAR MESH. Thats it. Good luck.
quote:
ORIGINAL: lc newbie
RC Airman
Hide Signatures
       Post #: 824
RE: Thunder Cat 31 - 9/14/2006 11:17 PM
lc newbie
Score: 100
Status: offline
who would you contact if your tiger drive gears are wasted? does anyone have an e-mail address?
Hide Signatures
(in reply to FE_Chris)
       Post #: 825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
