RE: Thunder Cat 31    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31
Page: <<   < prev  102 103 [104] 105 106 107 108 109 110 111   next >   >>
Login
RE: Thunder Cat 31 - 10/11/2009 11:28 PM
yimmy1
Score: 100
Last Login: 1/27/2010
Status: offline
I am hoping they will take it back, now I am waiting for my hatch lid (SO), just picked up 1 new tank, haven't had the desire to try it yet
Hide Signatures
(in reply to dawg1200)
       Post #: 2576
RE: Thunder Cat 31 - 10/12/2009 10:04 PM
black talon
Score: 100
Last Login: 12/26/2012
Status: offline
nice!
_____________________________
One day at a time, it''''''''''''''''s not always a race.
Hide Signatures
       Post #: 2577
RE: Thunder Cat 31 - 10/14/2009 8:40 PM
dawg1200
Score: 100
Last Login: 4/10/2011
Status: offline
I Had This Happen But as i retreived the boat to discover that there was a tree limb under the water that i could not see from where i was. Now after reading this thread im going to replace my bottom bolt with a shear bolt.
TC31, Shock Wave 55 SS, MIss Elam 1/12th, Gator Air Boat, Atlantic Tug, Vitro Vee
Hide Signatures
(in reply to kuperman)
       Post #: 2578
RE: Thunder Cat 31 - 10/14/2009 8:47 PM
yimmy1
Score: 100
Status: offline
I see you have a blackjack 55, how do you loike it?
I bought a new Miss Elam 1/8 with a Zen 260 in it, works GREAT, but it heats up, and now the clutch is being replaced,I am debating on going straight drive (no clutch) and using the water pickups only without a pump.
Hide Signatures
(in reply to black talon)
       Post #: 2579
RE: Thunder Cat 31 - 10/14/2009 9:50 PM
dawg1200
Score: 100
Status: offline
What was done to my tank was cut the nipple off at the tank and use a metal thredded nipple to replace the plastic molded one
quote:
ORIGINAL: TwistedLiquid
quote:
Well, the bottom line going to the carb where it is connected to the tank leaks on mine. Use wire and twist it around it tight, thats what I did to prevent it from leaking.
Here might be a better cure for your leak. The wire may cut into your line due to vibration. If you will cut off a piece of fuel 1/8 in length, then place the piece of tubing over the end of a closed pair of needle nose pliers. Open the needle nose to stretch out the tubing, then take your fuel line and place it thru the center of your stretched out tubing and release the needle nose. You should have your 1/8 over the very end of your fuel..then connect it to the tank...no leak you should find.
Hide Signatures
(in reply to TwistedLiquid)
       Post #: 2580
RE: Thunder Cat 31 - 10/20/2009 1:17 AM
black talon
Score: 100
Status: offline
my bj 55 i have i ran for a year and had a great time doing it. i like to tinker so i tinkered as much as ran it. i have recently taken the guts out and put them in a conquest and hope to have good luck with that also.
Hide Signatures
       Post #: 2581
RE: Thunder Cat 31 - 10/26/2009 12:52 AM
race1
Score: 100
Last Login: 12/16/2012
Status: offline
has anyone put the thunder tiger 7.5 engine in a tc 31? I like the bigger motor and the clutch and the belt start. how critical is the bottom after my fuel mishap I had a guy at work fix it and paint it. but could never get him to clear and buff it the top is ok but the bottom is a little orange peel looking will it run ok or have it cleared and buffed out?
Hide Signatures
       Post #: 2582
RE: Thunder Cat 31 - 10/26/2009 5:43 AM
wave waker
Score: 100
Last Login: 4/13/2013
Status: offline
quote:
ORIGINAL: race1
i think nobody done it yet but that's a good idea swapping motor, i'l bet it will work with little modification, coz i put os .46 in mine,,,imo, just take a measurement of the engine with the clutch first, might be tight in tc31.
keep us updated if u go to this direction...
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
(in reply to race1)
       Post #: 2583
RE: Thunder Cat 31 - 11/22/2009 7:28 AM
rcguy1411
Score: 105
Last Login: 5/19/2013
Status: offline
does any one know if hesco came out with the new hatch fot the tc 31 and where to get it if he did peice on it thanks for any info
Hide Signatures
(in reply to wave waker)
       Post #: 2584
RE: Thunder Cat 31 - 3/4/2010 7:35 AM
Owen18
Score: 100
Last Login: 4/12/2011
Status: offline
Hey Guys I'm getting ready for another season of great boating with My Thundercat, I was wondering if you guys knew of some simple mods that could boost performance or just overall a better boat.
Thanks, Owen
Hide Signatures
(in reply to rcguy1411)
       Post #: 2585
RE: Thunder Cat 31 - 3/4/2010 8:25 AM
rcguy1411
Score: 105
Status: offline
every mod that can be done to improve on the tc 31 is here in the form its a long read but you will gain all the knoladge that we have all contributed over the many years this thred a few quick mod are port match the exhaust header cut about 1/2 inch off the rudder less drag make shure your prop is sharp and ballanced open up rear of the hatch to allow air to excape the hull changing the carb will help cant rember the best one but it is in the fourm i run mine with the stock engine as im teaching my 7 year old how to drive with it good luck with the read it si worth it in the long run
Hide Signatures
(in reply to Owen18)
       Post #: 2586
RE: Thunder Cat 31 - 3/4/2010 6:51 PM
Owen18
Score: 100
Status: offline
Thanks for the quick reply, I know well of this forum I have been reading it since 2008, I have read it all. When you say open up the back of the hatch, should I just drill some small to medium sized holes in the back of the hatch cover.
Thanks, Owen
Hide Signatures
       Post #: 2587
RE: Thunder Cat 31 - 3/4/2010 10:11 PM
rcguy1411
Score: 105
Status: offline
think the rule of thumb is twice as much out as two what comes in it is hard to do with the tc 31 but if you open up the back the hatch is weakend up big time i reinforced mine with a pice of brass and glued if on the back i opend up over the mounting bolt and enlarged the two existing holes
Hide Signatures
       Post #: 2588
RE: Thunder Cat 31 - 3/6/2010 6:34 PM
Owen18
Score: 100
Status: offline
OK Thanks I don't know if ill be doing that yet because I don't want my back hatch braking or caving in to me when I drill it out.
Thanks ,Owen
Hide Signatures
       Post #: 2589
RE: Thunder Cat 31 - 4/12/2010 10:42 PM
Highvoltage272
Score: 100
Last Login: 5/17/2010
Status: offline
Hey guys i was just wondering what engines you guys have swapped out how fast you have gotten them to go and how difficult it was. i dont really like this dynamite .32, i really want to put the Rossi .21 Piranha. and i love this forum i found out a bunch of tips to make my boat better.
Hide Signatures
       Post #: 2590
RE: Thunder Cat 31 - 4/24/2010 6:09 AM
yannicksjh
Score: 100
Last Login: 5/12/2013
Status: offline
Alright, finaly got my two boats in the mail (a used blackjack 26 SS with a grim racer prop (sharpened and balanced, after market pipe) and a TC 31) The TC has some hull damge so its giving me the oportunity to fix, custom paint, open up some air vents in the back etc. I'll have lots of time doing this one right with some or all the mods from the very long thread, since i'll just use the BJ 26 in the mean time. Anyway, i need a prop or two, which ones should i get that won't be too hard on the motor. I remember reading it a few ago but now i can't find it? Also, where to order from (i live in Canada). thanks!!!!
Hide Signatures
(in reply to Highvoltage272)
       Post #: 2591
RE: Thunder Cat 31 - 4/25/2010 2:17 AM
sippirat
Score: 100
Last Login: 2/6/2013
Status: offline
yannicksjh, not sure which boat needs props but here is a link to the tc31 prop used by most of the guys in this thread. i just ordered one sharpened and balanced for my tc31.
Hide Signatures
(in reply to yannicksjh)
       Post #: 2592
RE: Thunder Cat 31 - 4/25/2010 5:58 AM
1150ap
Score: 100
Last Login: 3/15/2013
Status: offline
Mike Hallam at hallam marine hobby out of London.
Hide Signatures
(in reply to sippirat)
       Post #: 2593
RE: Thunder Cat 31 - 4/25/2010 7:08 AM
Coyotechaser
Score: 100
Last Login: 5/21/2011
Status: offline
I just got my tuned and modded engine back and went to install the flywheel. When I was tightening it on I noticed the pull cord got real tight. Almost like it was pulling itself in. So I went to unscrew it and now I cant get it off. Either way I turn it there seems to be an unreal amount of reistance. Any help or ideas would be greatly appreciated. Thanks.
Hide Signatures
(in reply to 1150ap)
       Post #: 2594
RE: Thunder Cat 31 - 4/25/2010 5:10 PM
wave waker
Score: 100
Status: offline
quote:
ORIGINAL: Coyotechaser
common cause of that is engine flooding, so remove the glow plug then try to pull the cord, don't let it squirt to ur face,it should work, then if not the cord might got tangled inside otherwise there's something seriously wrong with the engine..
HIGHVOLTAGE..,,imo, i'l put any engine that is bigger than the stock than gettin' smaller,,
Hide Signatures
(in reply to Coyotechaser)
       Post #: 2595
RE: Thunder Cat 31 - 5/3/2010 9:15 AM
cooltruck64
Score: 100
Last Login: 2/20/2011
Status: offline
hey guys, i bought me a tc31 today. i got it used for 175 bucks at a garage sale. ive been lookin at them for a while so i seen it and grabbed it. i havent got to run it yet. what are some good mods for this boat? there is some model boat club thats always running on sundays in delcity (oklahoma) i might have to go check them out next sunday and talk to them about it. also is there any cool paint schemes anyone has done with there tc31? i do paint and body work for a living and i was tryin to think of a cool paint scheme
Hide Signatures
(in reply to yimmy1)
       Post #: 2596
RE: Thunder Cat 31 - 5/3/2010 10:34 AM
rcguy1411
Score: 105
Status: offline
the first two i would do as far as mods are remove 1/2" from the stock rudder . the next thing i did was port match the exhaust header with the stock exhaust header there is alot of restriction there is an aftermarket carb that is said to really wake up the engine it is in this thread somewhere and change the prop make shure the one on the boat now is ballanced and sharpened and tou have alot of reading to do and every question will be answered have fun and as far as paint i like to look as full size boat and pick and chose aspects of what i like
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to cooltruck64)
       Post #: 2597
RE: Thunder Cat 31 - 5/4/2010 7:37 AM
Highvoltage272
Score: 100
Status: offline
Hey Guys well i have decided on doing a engine swap and as wave waker said go big or dont go at all i am going to put the O.S. 46 vx-m in my boat. The .32 doesnt cut it for me i want something that people are gonna take a double look at.
well i just though i would post a couple pictures of my boat with the mods i have done. one is the canopy i lost one in the bottom of lake pleasant in hum big cove somewhere then the one i have now has foam in it to keep it from sinking and bought aero marine cowl locks and they worked until it fliped and where i glues the lock on the canopy broke but good thing it now floated. Then made some body pin mounts for it and it seemed a lot easier that trying to make brass tabs and it work really well.
Second is i was running 60% omega in my boat with a x646 and my boat would be really hot so i made a exhaust cooling coil with its own inlet and moved the header cooling line to have its own inlet ,it stays a lot cooler after i did that,i also port matched the header,put  2 autobailers one in each sponson. I also trimed the rudder, and moved the preasure fitting to the pipe. Braized the preasure fitting on the header and sealed it up really nicely has no leaks. Put the traxxas 2.4ghz radio and trans in my boat from my 4x4 slash that i sold to buy the boat . i painted it with hobby paint on the top(silver) that i got from the lhs and lexan h20 paint from ACE on the bottom(red) i love working on this boat and tuning it as much as i love driving it. heres the pictures
Anyone in the phoenix area?
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2598
RE: Thunder Cat 31 - 5/5/2010 5:42 AM
wave waker
Score: 100
Status: offline
nice clean boat,,,any action shot?
Hide Signatures
       Post #: 2599
RE: Thunder Cat 31 - 5/5/2010 5:51 AM
Highvoltage272
Score: 100
Status: offline
yes they are on my laptop i will get some of the good ones later and post them.
Hide Signatures
       Post #: 2600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
