RE: Thunder Cat 31    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31
Page: <<   < prev  104 105 [106] 107 108 109 110 111 112 113   next >   >>
Login
RE: Thunder Cat 31 - 5/31/2010 7:22 AM
rcguy1411
Score: 105
Last Login: 6/17/2013
Status: offline
i like the speedmaster hardware have had it on a few other boats havent upgraded it on my tc31 as with this boat im using the if it aint broke dont fix it rule although i did upgrade my flexshaft today when i broke the stock one today even got lucky and still had the prop but think i will order a few spares this week
Hide Signatures
(in reply to 1badmaro)
       Post #: 2626
RE: Thunder Cat 31 - 6/1/2010 10:32 PM
1badmaro
Score: 100
Last Login: 6/15/2013
Status: offline
Has anyone ever put one of these on the TC? http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=AQUB7880&search=Go
Hide Signatures
(in reply to rcguy1411)
       Post #: 2627
RE: Thunder Cat 31 - 6/1/2010 11:17 PM
rcguy1411
Score: 105
Status: offline
should work fine but i would also get the bracket that goes with it also that rudder will also help some of the handling isues the TC 31 has
Hide Signatures
       Post #: 2628
RE: Thunder Cat 31 - 6/3/2010 5:53 PM
1badmaro
Score: 100
Status: offline
Just ordered the rubber and bracket. I will post some pics when I install it and a vid of how it works out!
Hide Signatures
       Post #: 2629
RE: Thunder Cat 31 - 6/11/2010 6:52 PM
1badmaro
Score: 100
Status: offline
How much of a power increase can I expect by changing to a Macs tuned pipe over the stock pipe? Also is there any other pipes out there that you guys would recommend?
Hide Signatures
       Post #: 2630
RE: Thunder Cat 31 - 6/11/2010 7:32 PM
rcguy1411
Score: 105
Status: offline
not shure how mich you will gain over the stock pipe but one of the best things you can do is to open up the header (port match) the engine will breath alot better along with a Mac pipe you should see a marked increase in performance there is also a carberator change in here somewhere that is said to really suposed to wake this engine up
Hide Signatures
       Post #: 2631
RE: Thunder Cat 31 - 6/11/2010 7:39 PM
1badmaro
Score: 100
Status: offline
The port match is already done and the carb is on back order. I just wanted to know if its worth spending the 36$ for the macs pipe? Thanks for the response though.
Hide Signatures
       Post #: 2632
RE: Thunder Cat 31 - 6/20/2010 11:36 PM
1badmaro
Score: 100
Status: offline
I opted for the Aeromarine rudder upgrade instead of the SV rudder. And now that I had a chance to run the boat with the new rudder it was worth the $ http://www.funrcboats.com/ProductInfo.aspx?productID=AER1310TC
Hide Signatures
       Post #: 2633
RE: Thunder Cat 31 - 6/21/2010 2:05 AM
wave waker
Score: 100
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: 1badmaro
i don't see any difference from stock rudder. i don't get what's the aeromarine talking about for the rudder description..do you have picture?
ww
_____________________________
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
       Post #: 2634
RE: Thunder Cat 31 - 6/21/2010 8:47 AM
Serpents Den
Score: 100
Last Login: 6/3/2013
Status: offline
I was checking a few sites for pictures of that rudder as well, from what i gather tho, its similar to the 'old' rudder, or the .21 aeromarine system...only real difference performance wise i would guess is the balance / turning point of the rudder, instead of being in the middle like the stock one, it'll be at or near the leading edge...
I too have aquired just recently a TC31 and cant wait to start working on it...  this will be my first boat to work on.  i have almost 2 dozen planes,  a dozen heli's, and a few cars in my collection atm, each type i also run both nitro and electrics....  i was actually looking at the speedmaster dual water inlet rudder gear and aeromaster machined strut for replacing the stock ones, i just havent decided on the length of the rudder bracket yet.   i figure it will help with the hooking issue having a bit more length to it, but not sure which length i will try.  the hull and canopy will both get overhauled and new facelift.....fuelproofing and strengthening in key areas....locks on front edge of cowl, autobailers....better venting in back of cowl, screen in front vents...new paint..  i plan to run the .32 stock for a while ( after i rip it down and go over it, rebuild if i have to..)  move the pressure nipple off the header, replace exhaust coupler and add cooling tubing of course, grease and adjust tigerdrive gears, once motor is broken / rebroken in, that'll get swapped out for a pull starter... less gear to carry around.  i may try all the engine mods everyone has listed all thru this thread at a later date, i do like speed, but for me its all about having fun.  i just have to kick my brother's butt to get his aquacraft 1:12 Miss Vegas going so we can run together, just like we do with our heli's or planes...more fun when there's more peeps than doing it alone in my opinion.....   hell, who knows.... it might spur me to pick up another boat or 2....or 3........or more hehehe...
oh yea.... i also have a plan for an electric powered 'rescue' boat as well.....  will be soo much easier than using a fishing rod, swimming or paddling out if there's a flameout or mishap of some kind on the water...
T-Rex 600N Hughes 500 TOW defender, 450SE Airwolf and 250 NYPD Hughes 500D
TC31, TS2, TS3, SV27
Hide Signatures
(in reply to wave waker)
       Post #: 2635
RE: Thunder Cat 31 - 6/21/2010 4:36 PM
rcguy1411
Score: 105
Status: offline
welcome to the world of boats Serpents Den sounds like you have a good plan of atack for your first boat the TC31 is a blast to run i find its the boat i grab when iwant to get on the water when i don t have alot of time i only saw one thing with your plan PLEASE DON T SWIM FOR YOUR BOAT as we have lost too many people to this in the past if you must swim please use a PFD
Hide Signatures
(in reply to Serpents Den)
       Post #: 2636
RE: Thunder Cat 31 - 6/21/2010 10:37 PM
Serpents Den
Score: 100
Status: offline
hehehe....trust me, i wont be swimming for the boat   and im a padi certified scuba diver too........the bottom of my last post, i mentioned to have plans making a 'rescue' boat to recover it for me
Hide Signatures
       Post #: 2637
RE: Thunder Cat 31 - 6/22/2010 1:17 AM
rcguy1411
Score: 105
Status: offline
the only reason i mentioned the DON T SWIM FOR YOUR BOAT is that a father and son were lost this year and several other s in the past
Hide Signatures
       Post #: 2638
RE: Thunder Cat 31 - 6/22/2010 3:16 AM
wave waker
Score: 100
Status: offline
quote:
ORIGINAL: Serpents Den
nah! u don't need rescue boat, u have lot's of heli then build one as a rescue heli that will be awesome! watya think?
post ur tc31 once upgrade is done,,,sound really cool..
ww
Hide Signatures
       Post #: 2639
RE: Thunder Cat 31 - 6/22/2010 3:50 AM
nothinbetr2do
Score: 115
Last Login: 5/28/2013
Status: offline
quote:
ORIGINAL: wave waker
quote:
ORIGINAL: 1badmaro
ww
to me they kinda look like a stock rudder, with alittle mod to it. a properly modded stock rudder would have the materail cut back to the the shaft, with no material in front of the shaft. with a razor edge running down from the start of the shaft. if you look back in this thread you'll fing my postings. that i got the knowing how to from guys in this thread, like wave and others that have tested this boat for us
just say no to "shelf queens"
aaf# 111285-25
A.C.E. member
Hide Signatures
       Post #: 2640
RE: Thunder Cat 31 - 6/22/2010 11:13 AM
Serpents Den
Score: 100
Status: offline
*agreed, quite a bit better than the stock rudder....ive read this forum thread front to back and appreciate and learned a bit from all the posters here let alone a few other sites i read through before deciding to get this boat... with experience in rc planes and racing cars ya gotta worry about the drag as much as you do boats.  to me i think it would be better going for a different rudder though, breakaway bolt design with a narrower tapered design, and having the water input rudder seems to be more appealing than the non one using a metal tube water pickup somewhere else mounted on the boat, which would cause more drag...as for the length, it can always be cut down w/o having to worry if you are too close to the water pickup...plenty of room for this application.  hence the reason im opting for the speedmaster setup for mine....
Hide Signatures
(in reply to nothinbetr2do)
       Post #: 2641
RE: Thunder Cat 31 - 6/26/2010 2:31 AM
rcguy1411
Score: 105
Status: offline
well it finaly hapened tiger drive failed but not what you would expect the wand was toast top my surprise but seing i had a 12 volt starter and belt on hand im now going to use that was a way to wreck a day at the lake i had everything to change over at the lake wich was like glass dosent happen verry often where i run then realised that i left the 12 volt starter at home to free up some weight in my field box
Hide Signatures
       Post #: 2642
RE: Thunder Cat 31 - 6/27/2010 7:39 AM
Serpents Den
Score: 100
Status: offline
hehe ive been there with my Hirobo ZXX when i first started in Heli's....used to have a pull starter on engine, also brought a couple of planes out with me at same time and had my sullivan starter always available (had starter shaft for hirobo just in case pull start failed)  and one day forgot to bring the starter shaft because i had helped a friend out with his hirobo one day, then brought out mine to do some flying and the pull starter broke....
anyhow, im waiting for a few parts ive ordered for upgrades to my TC31...(pullstart, autobailers, cowl locks, etc) just got my Spektrum marine reciever in, way different from the other recievers i use in my cars.  antennas are quite long, one gets inserted up antenna tube like the fm or am radio's...other mounted inside fuse above water line...  well built and looking forward to seeing how well it does or doesnt work with this project...also waiting for extra water outlet from my local hobby shop, once those parts are in i can get the extra mounting stuff drilled and etc then start prepping hull and cowl for paint...hopefully by the time the paint job is finished, the speedmaster parts will be in and i can start reassembling the 'new' girl
Hide Signatures
       Post #: 2643
RE: Thunder Cat 31 - 6/27/2010 9:51 AM
rcguy1411
Score: 105
Status: offline
grabbed a new wand and also have a belt installed on my boat so i should nt have any more problems with starting problems justy an extra couple of pounds to haul to the lake
Hide Signatures
       Post #: 2644
RE: Thunder Cat 31 - 6/27/2010 4:00 PM
amax
Score: 107
Status: offline
loosen your glow plug when starting, it will save your tiger drive or pull starts and your Rod.
Top Speed Hobbies llc. Gotta Need For Speed..
www.youtube.com/user/topspeedhobbies
Hide Signatures
       Post #: 2645
RE: Thunder Cat 31 - 7/9/2010 10:11 PM
loosenut510
Score: 100
Last Login: 8/20/2011
Status: offline
anyone know where to get the pull start to replace the tiger drive? i dont like having to keep the starter charged up and carry it too. i  would rather just pull the rope
WHH Enforcer Magnum 57 m5 Zenoah
ProBoat shockwave 55 RCMK w/clutch, water pump, gizmo motors dry pipe
Hide Signatures
(in reply to amax)
       Post #: 2646
RE: Thunder Cat 31 - 7/9/2010 11:05 PM
Serpents Den
Score: 100
Status: offline
yea, i ordered mine right from Horizon hobby, the Dynamite 32m version is direct fit... part # DYN6480
Hide Signatures
(in reply to loosenut510)
       Post #: 2647
RE: Thunder Cat 31 - 7/11/2010 5:34 AM
1badmaro
Score: 100
Status: offline
What are you guys using for a replacement exhaust coupler on the TC31?
Hide Signatures
       Post #: 2648
RE: Thunder Cat 31 - 7/11/2010 6:40 AM
rcguy1411
Score: 105
Status: offline
im using the ones from venom for there 1/8 scale trucks as they are alot thicker have had the same one on for the last two years and hs held up great
Hide Signatures
       Post #: 2649
RE: Thunder Cat 31 - 7/11/2010 3:29 PM
1badmaro
Score: 100
Status: offline
Is this what you are talking about? http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000775583&I=LXRHR9&P=K
Hide Signatures
       Post #: 2650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
