RE: Thunder Cat 31    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31 Page: <<   < prev  104 105 106 107 108 109 [110] 111 112 113   next >   >>
Login
RE: Thunder Cat 31 - 4/20/2011 1:52 AM
erolos
Score: 100
Last Login: 4/10/2012
Status: offline
hi to all.i bought tc31 last year and used it stock form about 1 gallon.i m using %20 byron fuels and prather 220 prop.then i wanted to put some slight modifications on my cat.firstly i removed head shim then balanced&sharpened&polished the prop and finally changed the pipe because stock one was too noisy.i bought .21 purple pipe from www.justengines.com. because i saw it from this tc31 thread.last weekend i wanted to try my boat but something went wrong i think?formerly with stock pipe i used 2 1/4(2.25) High Speed Needle settings but when i passed new pipe it drop to 1 1/8(1.15).i dont know if its normal or not?was it from new pipe or what else?i checked engine temperature after each run and that was ok but pipe and header were too hot.now i have m445 prop and %30 byron fuel in my hand but what can i do with new leaner HSN position?if its normal i will use new prop and fuel on my boat.can anyone say something for me about this?thanks.    ps:sorry about my english but i think its ok for understanding my problem!
Hide Signatures
(in reply to Phazewun)
       Post #: 2726
RE: Thunder Cat 31 - 4/20/2011 3:16 AM
wave waker
Score: 100
Last Login: 4/13/2013
Status: offline
quote:
ORIGINAL: erolos
if the pipe manufacturer recommended an engine range like from .21 to .32 then probably it's fine, as far as i can remember my HSN set below 2 turns..let us know how this thing works for you.
_____________________________
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
(in reply to erolos)
       Post #: 2727
RE: Thunder Cat 31 - 4/20/2011 4:40 AM
Ron Olson
Score: 1175
Last Login: 5/19/2013
Status: offline
The higher the percentage of nitro, the richer the carb will have to be set. The heat could be from a lean condition.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to wave waker)
       Post #: 2728
RE: Thunder Cat 31 - 4/20/2011 10:54 AM
erolos
Score: 100
Status: offline
firstly i want to correct my mistake.http://www.justengines.co.uk/acatalog/Tuned_Pipes.html.this is the right address where i bought my new pipe.in this page "20 purple pipe" is mine and only explanation about pipe is "For 21 Engines (use on 37 & 38 for high rpm use)".on the other hand my aim to bought this pipe was reduce engine noise and yes its sound like brushless now.i think when i use %30 nitro fuel and m445 prop combination then older one(%20 nitro fuel&220 prop) it gives me a richer HSN set(i dont know how but i hope at least step up to 1-1/2 (1.50) or more) and maybe i solve header&pipe heat problem with that?
Hide Signatures
(in reply to Ron Olson)
       Post #: 2729
RE: Thunder Cat 31 - 4/20/2011 10:45 PM
rcguy1411
Score: 105
Last Login: 5/17/2013
Status: offline
when running (lean) this will cause more heat as the fuel will also cool the engine if the problem persists you can cool the headder by raping copper tube around it run cooling line like this pick up to head to exhaust cooler to water outlet i think there are some pic s of this setup i the thread if you need them
Hide Signatures
       Post #: 2730
RE: Thunder Cat 31 - 4/20/2011 10:56 PM
erolos
Score: 100
Status: offline
thanks i checked whole 110 pages of tc31 thread and saw some cooling solutions like you sad.i plan to use this type of system on my header and hope it works.
Hide Signatures
(in reply to rcguy1411)
       Post #: 2731
RE: Thunder Cat 31 - 4/21/2011 9:31 AM
solo2004
Score: 100
Last Login: 5/17/2011
Status: offline
hi i would say if its getting hot you are running it to lean or your cooling pipe might have a blockage
Hide Signatures
       Post #: 2732
RE: Thunder Cat 31 - 4/21/2011 10:04 AM
erolos
Score: 100
Status: offline
cooling pipe is ok because i check it continuosly when i m running my boat and water circulation is ok but i wonder and search if HSN is lean?on the other hand after each tank of fuel i check my engine temperature and its ok.no problem with that but why HSN is drop down to ~1 i want to find this and if its normal i forget it and keep on running  with my boat.
Hide Signatures
(in reply to solo2004)
       Post #: 2733
RE: Thunder Cat 31 - 4/22/2011 3:35 AM
rcguy1411
Score: 105
Status: offline
there are a few things we also have to consider is temp outside and also altitude you run at because i run at two different altitudes and there is a 1/2 turn difference between the two ponds running my hull today i was at 3 turns out and it ran great but it was 60 deg outside lots of air if i run it in july i find my setting around 1 3/4 turns out to about 2 1/4 turns out hot humid air i like to be on the rich side for the simple reason a fat engine cant be hurt but a few passes with a lean neadle and you wil be spending $$$$ also rember when your engine is under a load it will lean out a bit so set it up a little fat on the beach
Hide Signatures
       Post #: 2734
RE: Thunder Cat 31 - 4/22/2011 9:09 AM
erolos
Score: 100
Status: offline
quote:
ORIGINAL: rcguy1411
of course different altitude,humidity and etc. affect HSN may be half turn like you sad but mine is over 1 turn and i think its in critical position now.in this thread i m trying to reach "asmund" from norway.may be 5 or 6 months ago i saw his video here on page 101 and i wonder how quiet his pipe and made a decision to buy one for me.but now i have interesting HSN problem and i wonder what he did when he used this pipe formerly???i send him a mail and a private message so i m waiting his reply impatiently.i hope i will find a solution with this new pipe because i dont wanna use stock pipe again its too noisy
Hide Signatures
       Post #: 2735
RE: Thunder Cat 31 - 4/23/2011 7:59 PM
asmund
Score: 111
Last Login: 5/18/2013
Status: offline
Hello, sorry for taking so long, haven`t been in here for a while because the boating season has been waiting for the winther to go away. You have PM
Hide Signatures
       Post #: 2736
RE: Thunder Cat 31 - 4/24/2011 4:37 PM
erolos
Score: 100
Status: offline
quote:
ORIGINAL: asmund
thanks a lot asmund.  you answered all of my questions.  now i will pass %30 nitro&m445 combination and like you sad i m trying to reach 35mph and if its possible may be more   but in my city i dont have any pond and i m running my boat only on the sea so i dont run my boats when i want only if i catch calm sea.  anyway when i reach possible top speed i will post video here to take some opinion from you and other tc31 fans.
Hide Signatures
(in reply to asmund)
       Post #: 2737
RE: Thunder Cat 31 - 5/8/2011 9:37 PM
Phazewun
Score: 100
Last Login: 1/31/2012
Status: offline
can anyone tell me what size allen i need to start this boat with the drill.
Hide Signatures
       Post #: 2738
RE: Thunder Cat 31 - 5/9/2011 1:20 AM
Serpents Den
Score: 100
Last Login: 5/15/2013
Status: offline
welcome back Asmund, and Erolos, good luck and dont give up...the tc31 is a fun boat to play around with     I know a few were looking around for a different carb to run on the dynamite as well,  and Asmund was using a different one than what others have tried....an ASP .91 carb if I recall...
T-Rex 600N Hughes 500 TOW defender, 450SE Airwolf and 250 NYPD Hughes 500D
TC31, TS2, TS3, SV27
Hide Signatures
       Post #: 2739
RE: Thunder Cat 31 - 5/10/2011 3:25 PM
Phazewun
Score: 100
Status: offline
anyone for the size of the starter ??
Hide Signatures
(in reply to Serpents Den)
       Post #: 2740
RE: Thunder Cat 31 - 5/10/2011 3:56 PM
Ron Olson
Score: 1175
Status: offline
Try sticking allen wrenches in there until you find one that fits. Use a cut-off ball-end so that you can. I can't remember what the size is for sure, somewhere around 5/32".
269 Racing Team
Hide Signatures
       Post #: 2741
RE: Thunder Cat 31 - 5/17/2011 12:43 PM
asmund
Score: 111
Status: offline
I have now changed my Dynamite .32 for a Sirio Race .27 buggy engine, Jammin JP-1 exhaust, Octura M445, Rapicon 60%. Air-cooling works great and I could remove the draggy water-pickup. With this set-up the boat litterally flyes along the water, I have to let go on the throttle sometimes to avoid beeing airborne. I will radar it as soon as possible, but I have a good reason to believe that it is faster than my previous personal best of 45 miles on the modded Dynamite
I know this for sure, I will stick to air-cooled buggy engines and have a wide selection of relatively inexpensive very powerfull engines to choose from. Now I am trying to decide which one will be my next engine, LRP .28 Spec 3, LRP .30 Competition or the Picco P3 .28, all of which should be even more powerfull than my old well used Sirio (used to be in my buggy before)
Hide Signatures
       Post #: 2742
RE: Thunder Cat 31 - 5/17/2011 9:01 PM
erolos
Score: 100
Status: offline
quote:
ORIGINAL: asmund
woww finally your new project came alive asmund i would like to see your new projects detailed photos and of course videos.on the other hand i have a bad news from my side today i broke my dynamite 32 piston rod but i dont know why because i didnt push too much when i run my boat but later i saw many rust inside the engine so may be its from long term salt water corrosion? anyway now i need a new piston rod or a new engine. but the question is which engine? i like dynamite engines tiger drive systems very much and i dont want to leave this practical operation system so if i buy different brand 32 engine can i use this system on it?
< Message edited by erolos -- 5/17/2011 11:53 PM >
Hide Signatures
       Post #: 2743
RE: Thunder Cat 31 - 5/19/2011 7:39 PM
asmund
Score: 111
Status: offline
I really don`t know about that, but the Dynamite is quite a decent engine. I couldn`t kill mine and I ran it as hard as possible. Maybe the easiest is to fix the stock engine again if there`s spare rods to find out there?
Hide Signatures
       Post #: 2744
RE: Thunder Cat 31 - 5/19/2011 11:32 PM
erolos
Score: 100
Status: offline
quote:
ORIGINAL: asmund
yes i tought same as you sad and ordered piston rod 2 days ago.i like dynamite engines too and think it deserves one more chance!
Hide Signatures
       Post #: 2745
RE: Thunder Cat 31 - 5/28/2011 11:51 PM
Serpents Den
Score: 100
Status: offline
Yeehaaa...finally picked up my hull from the painter's...
Now to get 'er reassembled...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2746
RE: Thunder Cat 31 - 5/29/2011 10:03 AM
erolos
Score: 100
Status: offline
quote:
ORIGINAL: Serpents Den
its looking good put it on water as quick as possible
Hide Signatures
       Post #: 2747
RE: Thunder Cat 31 - 6/6/2011 6:52 PM
Phazewun
Score: 100
Status: offline
looks real good i want to paint myn, just have no idea what paint to use to protect the boat.
Hide Signatures
       Post #: 2748
RE: Thunder Cat 31 - 6/12/2011 9:53 PM
asmund
Score: 111
Status: offline
I ran my TC 31 again today and swapped the Jammin jp-1 pipe to a new STS 0403 that is a top-end pipe as opposed to the JP-1 which is a bottom-end pipe. The boat was noticeably faster and actually was quicker from the start and on the pipe too, this was a little surpricing. The best pass on the radargun was 83 kpm ( 51.67 miles) This is the best for me so far and now I will try a M545 instead of the M445.
Set up right now is: Sirio Race .27 buggy engine, ASP .91 carburator, STS 0403 tuned-pipe, Octura M445, Rapicon 60% fuel.
The buggy engine holds up well and works like a dream, aircooled and all
< Message edited by asmund -- 6/12/2011 10:44 PM >
Hide Signatures
       Post #: 2749
RE: Thunder Cat 31 - 6/28/2011 3:46 PM
helicrazedout
Score: 100
Last Login: 5/16/2013
Status: offline
hi all after running my tc 31 on the water for about 8 mins alot of white smoke comes out of the engine is this normal? is it possible to be running to hot?
DX7 Transmitter , Trex 450 heli , Avatar Z009 heli , Thundercat 31 nitro boat
Hide Signatures
       Post #: 2750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.188RCU1
