RE: Thunder Cat 31    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31
Page: <<   < prev  104 105 106 107 108 109 110 111 [112] 113   next >   >>
Login
RE: Thunder Cat 31 - 9/14/2011 5:08 PM
catman_grrrrr
Score: 100
Last Login: 5/21/2013
Status: offline
Did shorten pipe some as I also thought was a bit long.Installed pressure nipple at the"fat"of the pipe,installed fuel filter and filter on pressure line to prevent crap in the tank.Did fire it(with water running through the head,SOUNDS GREAT!!! This .45 has some gump!!! Gonna try a quick run Sat...next ?????? Should I tilt the strut down a tad since the pipe sits so high to balance getting on plane,keepin the nose down a bit??
Hide Signatures
(in reply to Hesco Racing)
       Post #: 2776
RE: Thunder Cat 31 - 9/14/2011 7:24 PM
Hesco Racing
Score: 110
Last Login: 5/23/2013
Status: offline
Nope. First see how it runs. Negative trim on a cat is recipe for submarine tendencies. Rather keep the strut square and drop in vertical a bit. Will get the nose down quickly. And ditch the filter on the pressure line. Keep one on the fuel line.
Cobus
Hide Signatures
(in reply to catman_grrrrr)
       Post #: 2777
RE: Thunder Cat 31 - 9/14/2011 9:41 PM
catman_grrrrr
Score: 100
Status: offline
Cool...thanks for the info...hopefully weather will hold out so I can run Sat..if not week or so will have to do.
Hide Signatures
       Post #: 2778
RE: Thunder Cat 31 - 9/15/2011 9:40 AM
Hesco Racing
Score: 110
Status: offline
Have you worked on the hull at all or is it still like it came from the supplier?
Hide Signatures
       Post #: 2779
RE: Thunder Cat 31 - 9/15/2011 3:16 PM
catman_grrrrr
Score: 100
Status: offline
Did get the bottom scuffed up a little,all the flotation I could crammed into every hole possible and glued some on canopy,lines zip-tied,pulled everything out and put back with loc-tite,made new gasket for box..jus goin through all the chit.Should have my fail safe today,then pretune(with constant cool water from well running through head)then head for the water to do a few test runs.Center of prop level with lowest part of the boat to start out with.
Hide Signatures
       Post #: 2780
RE: Thunder Cat 31 - 9/26/2011 3:17 AM
catman_grrrrr
Score: 100
Status: offline
All I gotta say is.....WOW!!!!!!!!!! Not even close to full throttle and that baby flies!!!!!!Still got the small prop on and that Rossi.45 zings!!!!Few more adjustments and a couple more tanks of gas and I'll put a gps on it and try to get video.
Hide Signatures
       Post #: 2781
RE: Thunder Cat 31 - 9/27/2011 7:33 PM
rcguy1411
Score: 105
Last Login: 5/19/2013
Status: offline
don t try DO we want vidio and pics
Hide Signatures
       Post #: 2782
RE: Thunder Cat 31 - 10/5/2011 12:44 AM
catman_grrrrr
Score: 100
Status: offline
youtu.be/IfpHBzzfc40
There it is....more tweaking to do and just startng to get broke in...now to get rid of the bugs and get a couple more props and and another pipe and tune it up!!
Hide Signatures
(in reply to rcguy1411)
       Post #: 2783
RE: Thunder Cat 31 - 11/27/2011 9:19 AM
erolos
Score: 100
Last Login: 4/10/2012
Status: offline
it looks it will go enough fast when you find best prop and pipe combination.what about todays position did you tune it up and have any new videos?
Hide Signatures
       Post #: 2784
RE: Thunder Cat 31 - 3/15/2012 11:31 AM
erolos
Score: 100
Status: offline
my stock tc 31 with modified silent pipe.after many years it still looking good and entertaining
http://vimeo.com/37919150
Hide Signatures
(in reply to erolos)
       Post #: 2785
RE: Thunder Cat 31 - 3/15/2012 11:01 PM
1badmaro
Score: 100
Status: offline
Wow that thing is quite!! Can you please provide more info on what pipe it is and what mods you did to it? Thanks.
Hide Signatures
       Post #: 2786
RE: Thunder Cat 31 - 3/15/2012 11:53 PM
erolos
Score: 100
Status: offline
hi 1badmaro.i use %30 nitro byron fuels and prather 220 prop with that pipe on my tc31.u can find this pipe in below adress and i definitely suggest it
http://www.justengines.co.uk/acatalog/Tuned_Pipes.html.  this is the address where i bought this pipe.in this page "20 purple pipe" is mine and only explanation about pipe is "For 21 Engines (use on 37 & 38 for high rpm use)"
Hide Signatures
(in reply to 1badmaro)
       Post #: 2787
RE: Thunder Cat 31 - 3/16/2012 5:06 AM
Ron Olson
Score: 1175
Status: offline
The Prather 220 works OK on this boat but try an Octura M-445 or Zippkit's 444 and you'll see more speed.
_____________________________
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
       Post #: 2788
RE: Thunder Cat 31 - 3/16/2012 2:19 PM
erolos
Score: 100
Status: offline
hi ron.i have balanced,polished and shapened m 445 but i dont know why i didnt find the best setup with it?instead i m more comfortable with prather 220 but i will try again probably tomorrow
Hide Signatures
(in reply to Ron Olson)
       Post #: 2789
RE: Thunder Cat 31 - 3/16/2012 4:40 PM
catman_grrrrr
Score: 100
Status: offline
work in progress...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2790
RE: Thunder Cat 31 - 3/23/2012 3:16 AM
catman_grrrrr
Score: 100
Status: offline
All done except for buffing,,,what ya think??
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2791
RE: Thunder Cat 31 - 3/23/2012 11:36 AM
Hesco Racing
Score: 110
Status: offline
Very neat. Hope you have flashing light on the hatch or it will vanish from sight on the water.
Cobus
Hide Signatures
       Post #: 2792
RE: Thunder Cat 31 - 3/23/2012 1:15 PM
catman_grrrrr
Score: 100
Status: offline
I don't run that far out to have to worry bout that and with the gold candy it really brightens up in the sunlight.
Hide Signatures
       Post #: 2793
RE: Thunder Cat 31 - 3/25/2012 4:14 AM
wave waker
Score: 100
Last Login: 4/13/2013
Status: offline
very nice artwork catman ....do u have action shot?
ww
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
Hide Signatures
       Post #: 2794
RE: Thunder Cat 31 - 3/25/2012 4:40 AM
Ron Olson
Score: 1175
Status: offline
Well, look at what crawled out of the woodwork! Hey Jul, long time no see Bro! I was just thinknig about you today while I was in Me Time's site watching videos.
OK, I'm OT but just had to say Hi.
269 Racing Team
Hide Signatures
(in reply to wave waker)
       Post #: 2795
RE: Thunder Cat 31 - 3/25/2012 5:10 AM
catman_grrrrr
Score: 100
Status: offline
Still gotta get all the guts back in..hopefully I'll get some time and good weather soon,plus workn on a paint job on otherTC and a tunnel.That was actually my first airbrush job.Next one with skull oughta look awesome.
Hide Signatures
       Post #: 2796
RE: Thunder Cat 31 - 6/1/2012 5:19 PM
catman_grrrrr
Score: 100
Status: offline
Hide Signatures
       Post #: 2797
RE: Thunder Cat 31 - 6/3/2012 9:23 PM
catman_grrrrr
Score: 100
Status: offline
Had a good run with the fellas yesterday..my leopard TC was hitting 48 by radar..didn't have my gps..skull boat got creamed by someone so gotta find another hull now.
Hide Signatures
       Post #: 2798
RE: Thunder Cat 31 - 6/6/2012 1:38 PM
catman_grrrrr
Score: 100
Status: offline
Action shot.....
Hide Signatures
       Post #: 2799
RE: Thunder Cat 31 - 6/6/2012 3:12 PM
catman_grrrrr
Score: 100
Status: offline
http://youtu.be/WVUH7wGuoXk
Hide Signatures
       Post #: 2800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
