RE: Thunder Cat 31
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Thunder Cat 31 - 4/23/2006 8:48:11 AM
wave waker
Status: offline
lineman, there's a discussion somewhere goin on bout OS 32, try to check the engine specification coz the hp of both engine the os and dynamite somewhat the same so i believe it will not show big difference, i would say get the one with way up higher hp, just my 2 cents.
_____________________________
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
(in reply to sima)
       Post #: 51
RE: Thunder Cat 31 - 4/23/2006 8:48:34 AM
FE_Chris
Status: offline
Got some pics. Let me know if anything looks a-miss. Besides the fuel cap not being on
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
BlackJack 55, go gas or go home! I should change my screen name to "Gas powered Chris" HA!
(in reply to sima)
       Post #: 52
RE: Thunder Cat 31 - 4/23/2006 9:06:06 AM
wave waker
Status: offline
hey Dodamiss, ur cat31 looks same with mine ,,,looks ready to go...i noticed u turned the radio box lid and drilled a hole in the cowling for antenna and have an easy reach to the switch, is that the whole idea there?..nice idea though.
how come the antenna looks shorter?
(in reply to FE_Chris)
       Post #: 53
RE: Thunder Cat 31 - 4/23/2006 9:20:56 AM
FE_Chris
Status: offline
Yeah, I'm hoping she's ready to go....I went all throughit and used lock tight on everything....She should be solid. I even lubed the prop shaft with some Penzoil Marine grease.
The antenna is short because I use a 2.4Ghz Spektrum radio System. They can be as short as 3.5 inches with NO differance in radio range. It's nice for MT's and such because the antenna can ride underneath the body, so it's a cleaner look and no hols to cut for my buggy's or truggy's body's. No glitches or crystals for the Spek either, it's so nice. All the metal in the world can rub next to this radio, and it will not affect anything.
The lid was flipped 180 degrees. Thats all, I did not even drill a hole. I had to do it so I could get all the radio gear to sit right. All the 5-cell packs I have are flat, so I had to move the Rx to the upper right corner of the box. In between the 2 servos. The Rx batt pack is velcro'ed in and sits at an angle if you check the pic out. It works nice. oops....I did drill a hole lol In the top hatch for the antenna to stick out.
O, the Spektrum Radio system also has a built in fail safe.....You can set the proper fail safe trims when the Tx is bound to the Rx. It works really well. When and if the Rx looses radio signal, it reverts to the pre determined trim settings for the throttle and steering. If mine looses signal, the boat will return to idle and run straight.
I'll post tomorrow night with what I come up with and how breakin went. My freind ashley and I are headed to this private lake for some fishing and relaxing....I have'nt told her i'm bringing the Thunder Kitty yet later fellas.
quote:
ORIGINAL: wave waker
< Message edited by DodamissC -- 4/23/2006 9:23:35 AM >
(in reply to wave waker)
       Post #: 54
RE: Thunder Cat 31 - 4/23/2006 3:10:28 PM
sima
Status: offline
Keep us posted!
He,who dies with the most toys, wins!
       Post #: 55
RE: Thunder Cat 31 - 4/23/2006 3:34:46 PM
NitroSS
Status: offline
Nice pictures in this thread. I noticed something in one that has me wondering. Does this boat have a stepped hull underneath it? Let me know or if someone would take some pictures of the bottom of the hull showing the steps it would be cool.
By land, sea & air I R/C it all. Sometimes even in one day.
(in reply to sima)
       Post #: 56
RE: Thunder Cat 31 - 4/23/2006 3:38:46 PM
luvrocks
Status: offline
let us know how the spektrum works in it as there has been some problems with it in boats.I have the spektrum radio for my trucks and would liketo use it on the new boat when I get it.
(in reply to sima)
       Post #: 57
RE: Thunder Cat 31 - 4/23/2006 3:38:53 PM
Tomas_LT
Status: offline
Got mine thundercat a montn ago. Well I dont believe that it starts directly form box and runs. If it does - than you a the lucky one I mean it might run, but... I adding some pictures after the changes has been done. In short this is what was done by the friends of mine who are really good in tis area. 1. Fuel tank cleaned - lots of trash inside. 2. Engine takn in parts, cleaned and collected again. 3. Enhaust system connection between engine and tube fully changed and isolated. 4. Extra cooling system added on enchaust. 5. New hi-tech servos replaced, instead of stock ones. 6. Radio transmiter acumulators changed - instead of 4 elements now 5. 7. radio transmiter box fully isolated. 8. Radio transmiter charger taken out of box in order to avoid extra box opening and getting extra humidity. 9. New stand for boat - the stock one is a joke . And some more minor changes. Next wekk I will put in on the water, because right now water is a bit too cold - 5'C only. Your comments are very much welcome. regards from Lithuania, Europe
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to sima)
       Post #: 58
RE: Thunder Cat 31 - 4/23/2006 3:49:40 PM
NitroSS
Status: offline
Looks like the boat has never been run in those pictures. I'd be interested to see how your exhaust cooler line holds up.
(in reply to Tomas_LT)
       Post #: 59
RE: Thunder Cat 31 - 4/23/2006 4:02:37 PM
Tomas_LT
Status: offline
Yes, you right - this one has never been on the water yet. I wrote that water is too cold now. Next weeked I will do test runs so new post will be comming
(in reply to NitroSS)
       Post #: 60
RE: Thunder Cat 31 - 4/23/2006 7:04:26 PM
paulleonard
Status: offline
I Apologize the flex shaft is from Hughey Boats Part # B6666 it is .187 Hard 18" ...I Also picked up an Octura Propeller X442 2 Blade..
(in reply to sima)
       Post #: 61
RE: Thunder Cat 31 - 4/23/2006 7:05:34 PM
NitroSS
Status: offline
Well I just ordered one. Hope to see it this week.
       Post #: 62
RE: Thunder Cat 31 - 4/23/2006 7:09:20 PM
wave waker
