wave waker
IN, USA Status: offline
quote:
ORIGINAL: ERV JR Hey guys Im new here and to boats. I bought a Tc31 and a blackjack26 last sunday, and have read thru th efirst 11 pages and last few. I have heard that the carb settings have been way off , so my question is what should I set them at for break in ? do i check them and set them to what the manual says or do you guys rec something ? The Bj26 was out on monday and it was running rich and would die/stall while driving at part throttle ,i thing it was loading up, what do you guys suggest ? Oh the Tc31 never made it to the water,it started on the stand then died and wouldnt restart and I messed with the other one welcome! with tc31 start with HSN in 2.5 turn, LSN 2 turn, if flooding occur try leaning the LSN by 1/8 turn and so on, HSN also needs to be lean if floding occur but it needs to run rich while break-in.... try as reference point. my present set-up now is 1.5 turn in HSN and 1 turn in LSN. goodluck.
_____________________________
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
