RE: Thunder Cat 31
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Thunder Cat 31
Page: <<   < prev  76 77 78 79 80 81 [82] 83 84 85   next >   >>
Login
RE: ... - 6/20/2008 5:48:39 PM
SinCityInc.
Status: offline
X33....use a blow dryer to soften the adhesive and the decals should come right off with a nice slow pull, then use lighter fluid or something like it to remove any residue left over.
_____________________________
Most days, I'd rudder be boating....
(in reply to x33racer)
       Post #: 2026
RE: ... - 6/20/2008 8:51:22 PM
x33racer
Status: offline
Ka350kaptain and SinCity.
Confident now that it will be a simple decal removal, not a major refinishing ordeal.
Thanks Again.
(in reply to SinCityInc.)
       Post #: 2027
RE: ... - 6/23/2008 1:19:52 PM
jerj
Status: offline
Do any of you know the part number from MAC's pipes for the header that will fit the TC 31? thanks.
       Post #: 2028
RE: ... - 6/30/2008 8:41:40 AM
lomdel
Status: online
Jerj, I unfortunately don't know the part number, it is featured somewhere in the 82 pages of threads in here...
Meanwhile, I received my new 4" rudder kit from TopSecretBoats and installed it over the weekend. Here are a few pics. The two cooling lines is one for the engine head and one for the exhaust header cooling sleeve. See post #1898 with my old rudder set-up.
Click to see fullsize image.
Click for fullsize
Click for fullsize
He who dies with the most toys, wins...
(in reply to jerj)
       Post #: 2029
RE: ... - 6/30/2008 1:44:07 PM
wave waker
Status: offline
quote:
ORIGINAL: lomdel
very nice rudder
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
(in reply to lomdel)
       Post #: 2030
RE: Thunder Cat 31 - 7/3/2008 7:36:34 AM
pissedoffpete
Status: offline
Ever look on youtube? There are at least 4 or 5 videos.
(in reply to wave waker)
       Post #: 2031
RE: ... - 7/3/2008 11:29:48 PM
jerj
Status: offline
Nice! thanks any way all I may just call macs
       Post #: 2032
RE: ... - 7/4/2008 7:27:55 AM
lomdel
Status: online
Here is the Tower link to the Macs tuned pipe for the TC31's .32 Dynamite engine : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ558&P=SM
Hope it helps!
(in reply to jerj)
       Post #: 2033
RE: ... - 7/6/2008 3:30:08 PM
jerj
Status: offline
Thank you, it doesent say if its high nitro or a low nitro pipe..hmm.
       Post #: 2034
RE: ... - 7/7/2008 8:15:10 PM
nitronut911
Status: offline
hey, how does that rudder compare to ****'s breakaway? how much is it?
When your over 65, NEVER trust a fart!
       Post #: 2035
RE: ... - 7/8/2008 7:52:23 AM
lomdel
Status: online
The rudder is the 4" kit with two internal water pick-ups and a BEAUTIFULLY detailed mount. It cost $48,80 without shipping. I needed to cut off about 1cm or 1/3" off the bottom to reduce drag and get it closer to stock length and do a slight modification to the servo-arm. The mounting holes didn't correspond with the stock mount's and I therefore needed to fill them up with plastic marine putty and drill new holes for the new mount. It's as sharp as a knife with a perfectly squared off trailing edge. I haven't had it in the water yet (winter in South Africa)...
< Message edited by lomdel -- 7/8/2008 7:53:18 AM >
(in reply to nitronut911)
       Post #: 2036
RE: ... - 7/9/2008 6:11:41 AM
ERV JR
Status: offline
anone ever use the grim racer props on a tc31 ? we went to the lhs today and a friend got talked into a grimracer prop.
Also anyone ever have a problem with the hull cracking at the rear bulkhead right by the stuffing tube ? Both of our Tc31's cracked there this last weekend
       Post #: 2037
RE: ... - 7/9/2008 6:55:18 AM
lomdel
Status: online
My hull never cracked and I've been running it quite hard. Please post some pics of the cracked section. I only run Prather P225 and P235 props, they seem to work well enough for me...
(in reply to ERV JR)
       Post #: 2038
RE: ... - 7/10/2008 1:55:21 AM
ERV JR
Status: offline
quote:
ORIGINAL: lomdel
I already ground the crack out and glassed inside the hull about 1 1/4 of an inch to stiffin the section. goin to go out to finish the bottom side with marine tex
       Post #: 2039
RE: ... - 7/10/2008 5:00:10 AM
wave waker
Status: offline
try coating of clear epoxy inside the hull to prevent from crackin',,
anybody doin some speed test with tc31??
