Hal DeBolt's "Intercepter"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> Hal DeBolt's "Intercepter"
Page: [1] 2   next >   >>
Login
Hal DeBolt's "Intercepter" - 3/29/2006 5:17:34 PM
windslore
Status: offline
I have recently been given a fibreglass 'fuz' of what I believe to be a DeBolt Intercepter, according to the label on it! Can anyone verify this? There is a label on the inside saying when and by whom it was made, which I have photographed. Does anyone know anything about this aircraft and if it's worth the time and effort to build? I have no other information, it would be nice to know what it looks like and if I can get hold of any plans.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by windslore -- 3/29/2006 6:55:13 PM >
       Post #: 1
RE: Hal DeBolt's "Intercepter" - 3/29/2006 7:08:47 PM
rainedave
Status: offline
Plans:
Click for fullsize
Click for fullsize
(in reply to windslore)
       Post #: 2
RE: Hal DeBolt's "Intercepter" - 3/29/2006 7:18:08 PM
windslore
Status: offline
Thanks for the images Raineday, are the plans still available? I can probably enlarge the second image you posted but the first is not clear enough to read the detail.
Thanks again.
(in reply to rainedave)
       Post #: 3
RE: Hal DeBolt's "Intercepter" - 3/30/2006 2:07:09 AM
Lotus72D
Status: offline
You have a real gem there my friend! Hal deBolt was a legend in RC modeling in the USA. The Interceptor series were perhaps his classiest, best looking pattern designs- circa 1963-1966. Beautiful, streamlined design that used a Merco .49-.61 w/ deBolt retracts. Very advanced for it's time.
Worth building, and worth doing your very best work just for the cool factor. I would probably fly it rarely at vintage events (VRCS in the USA)- wouldn't risk it for sport flying.
I can direct you to plans through a source that I'm sure would ship to the UK. I was never aware of a 'glass fuselage, plans are for an all built up balsa airframe.
"INTERCEPTOR 5 - DeBolt plan for .60 pattern ship, 4 channels. $15.00
Tom Dixon
P.O. Box 671166
Marietta, GA 30066
USA
Or Fax the completed from to (770) 592-3279"
       Post #: 4
RE: Hal DeBolt's "Intercepter" - 4/1/2006 7:03:15 PM
windslore
Status: offline
Thanks for that, sorry slow to respond but been away for a few days. From what you say it looks like it will be worth the time and effort to put one of these ships back in the air. The classic pattern ships do not seem to have the same following in the the UK but maybe it will become more popular. I have been PM'd by someone in the USA who would like to pull a mold from this fuselage. I might well loan the fuselage for this purpose . This glass fuselage was made by D.R. Hartman of Argenta Illinois in 1966, has anyone any knowledge of him?
John
(in reply to Lotus72D)
       Post #: 5
RE: Hal DeBolt's "Intercepter" - 4/1/2006 11:07:16 PM
CoosBayLumber
Status: offline
Windy.....
The fiberglass fuselage was built by Dwight Hartman of Illinois. Around 1978 or so he pretty well got out of model airplanes and got interested in model boats. What you have is referred to as a Zeus 2 fuselage. I have it shown in my catalogue from Hartman.
The original Interceptor had problems when flying full speed. Hal then designed up a fiberglass fuselage to stick onto the original wings. The problem only showed up at a higher speed. No cure. But that did not stop Dwight from selling a few fuselages afterwards. He labeled them the Zeus 2. I have the original plan made by Hal for the Inteceptor two, says to use fiberglass fuselage, and Interceptor (original) wing.
After that he came up with an Interceptor three, four and then the Five. The five was the aircraft which put him within four points of an aerobatic perfect score at the A.M.A. Nats in 1965. I have in my possession several of the plans for Interceptors, and even did laser cut parts for the version Five last year. Biggest thing you will find is that if you cut parts according to any of the older plans, they will not fit properly, for somewhere along the line, who ever did the actual drafting forgot about wood thicknesses. Some parts are shown too thin, some too thick. I chucked the 'ceptor (Five) as Hal referred to it by into Autocad and redid it. If you visit my web site, you can see a picture of the Five. His favorite. And the new CAD plan don't cost near as much as the copies do.
The Zeus Two, is sort of wanted now, Dwight is trying to sell off whatever he has in airplanes at present time. The firm shut down about one year ago, with a relative running it. He is also suing a fellow from St. Louis over his management of the firm for the prior ten years. I wouldn't fly the Zeus two, but instead get it copied. I think Dan of North Carolina is trying to locate an original to copy. He is generally within the Vintage Forums.
Wm.
_____________________________
www.mybloo.com/coosbay/laser/laser.html
Thousands of Laser Cut parts, thousands
       Post #: 6
RE: Hal DeBolt's "Intercepter" - 4/2/2006 3:12:52 PM
windslore
Status: offline
Wm,
From what you have said I won't fly it but will have it copied. You mentioned Dan from Carolina and by coincidence he has contacted me and I am probably going to send him the 'fuz.' It would be a shame to fly what may be the last survivng example. I was given the fuselage by a good friend who had it in his attic for years. Hopefully we'll see a few of them flying again!
Regards
John
(in reply to CoosBayLumber)
       Post #: 7
RE: Hal DeBolt's "Intercepter" - 4/2/2006 3:58:54 PM
CoosBayLumber
Status: offline
Well, as mentioned the Zeus Mk. two (part number HF-12) uses the wing from the earlier Interceptor. Never cut parts for that version, only the last one which used a different airfoil. The original plan does not indicate how the rudder was made up, but assume it was all wood. The picture from catalogue show an Orbit ten channel transmitter along side. Plan says the engine was to be a K&B .45 but catalogue says .49 to .61 power. Finished weight was to be 6 pounds.
Was another Zeus Mk. two on eBay that went for bit more than $100, and owner was completely lost as to heritage.
However, Dan and Mike know of the situation with Dwight now.
Wm.
       Post #: 8
RE: Hal DeBolt's "Intercepter" - 4/4/2006 11:28:44 PM
windslore
Status: offline
Wm
I have spoken to Dan and hopefully the fuselage will be with him in a couple of months. I thought that would be the best thing, the fuselage will now be copied and available to everyone. Thanks for the information, I look forward to seeing one of these ships back in the air.
Regards
John
       Post #: 9
RE: Hal DeBolt's "Intercepter" - 5/23/2006 2:07:36 AM
jjpetro
Status: offline
Hey Dan!! Have you got that fuze yet? That will be an interesting little project, are you going to walk us through it on the forum?
Jeff Petroski
Home and Hobby Solutions
www.homeandhobbysolutions.com
       Post #: 10
RE: Hal DeBolt's "Intercepter" - 5/23/2006 3:35:20 AM
Deadstik
Status: offline
Jeff,
The fuselage should be here soon... and I'll keep everyone informed as to what direction the project will take. It seems there are a lot of unanswered questions, but given all the great folks around here, I'm sure I'll have answers before long.... I'll certainly keep you in the loop.....
Dan Hines
Carolina Custom Aircraft
(in reply to jjpetro)
       Post #: 11
RE: Hal DeBolt's "Intercepter" - 5/25/2006 4:25:18 PM
Mike Denest
Status: offline
Hi Dan,
We missed you at Mid South. Done anything with that Zeus Mk. I yet? I'd love to have a fuselage.
Mike Denest
R/C as it used to be: http://www.vintagercsociety.org
(in reply to Deadstik)
       Post #: 12
RE: Hal DeBolt's "Intercepter" - 5/25/2006 7:34:24 PM
windslore
Status: offline
For all of you who have been following this thread, I thought you might like to know that the fuselage is now back in its home land, after its return trip across the Atlantic! This time on the flight deck of a Boeing 777! Dan has just told me that it has arrived in good condition thanks to UPS and he will be progressing the project soon. Keep an eye on the forum and if things go well, I'm sure Dan will walk us through this one.
Has anyone got a picture of this model?
John Adams
(in reply to Mike Denest)
       Post #: 13
RE: Hal DeBolt's "Intercepter" - 5/26/2006 12:41:58 AM
Deadstik
Status: offline
John,
Thanks to you the Interceptor will keep going. There are quite a few unanswered questions as to the fuselage and exactly how much did DeBolt change it from the Intereceptor I till it got to the Mark V. I've gone thru my archives and am posting all of the available pictures that I have of the plane. It seems the as the plane was originally designed it had retracts and was quite advanced for its' day. DeBolt flew the Interceptor in the 1964 Nationals
