RE: Introducing the new 90-1.20 Yak QB
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Introducing the new 90-1.20 Yak QB
Page: <<   < prev  46 47 48 49 50 [51] 52 53 54 55   next >   >>
Login
RE: Intro... - 4/22/2008 2:48:26 AM
capt1597
Status: offline
flaperons on 3d style planes read post 1229 you get the reverse of what you expect. conclusion it does not work!
< Message edited by capt1597 -- 4/22/2008 2:53:14 AM >
(in reply to beto9)
       Post #: 1251
RE: Intr... - 4/22/2008 3:11:12 AM
capt1597
Status: offline
i am flying with the saito 150 which i am used to and i started with a 16-8 apc which i have used alot on other planes . i found on this plane it was to much pitch for slowing the plane on landing so today i tryed a 17-6 apc an was was quite happy with the results. with a touch of throtle see came in slower but with athority also it greatly improved vertical power
(in reply to capt1597)
       Post #: 1252
RE: Intr... - 4/24/2008 2:17:58 AM
TomTreese
Status: offline
I checked my inventory and I had a 17x6 APC prop, so I tried it today. Much Better. Fly's well and lands slower.
Thanks for the suggestion.
The plastis spinner the came with the Yak basically melted today when the prop came loose. I had to pry the prop off of the back plate and the engine side of the backplate also melted from the groves on the engine. Replacing with an aluminum spinner.
I guess a plastic spinner isn't a good idea on the larger engines??
_____________________________
Insanity: Keep doing the same thing expecting a different result.
       Post #: 1253
RE: Intr... - 4/24/2008 3:37:34 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: TomTreese
Yes, exactly. With larger engines, especially those who use hi torque starters, do not use plastic spinners because of what exactly happened to you. Carbon fiber and aluminum spinners are more durable.
"To fly is everything." -Wright Brothers
Club Site: www.sccmas.org
(in reply to TomTreese)
       Post #: 1254
RE: Intr... - 4/24/2008 12:19:59 PM
Zippi
Status: offline
I've had my YAK 54 out a few times so far and keeping an eye on the landing gear, wheel pants nuts & bolts, etc. Everything seems fine and it's still a joy to fly as it was on the first flight. Everything seems to be holding up very well and it's just an all around well built plane and a very nice flying plane as well. The concrete runway that I use will probably chew up the tires before this season ends so I'm hoping that's all I'll have to replace.
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
(in reply to Ferocious Frankie)
       Post #: 1255
RE: Intr... - 4/25/2008 2:52:34 AM
Jimeni
Status: offline
You will be suprised with the tires. I fly from a paved runway and have them on an AW edge also. They are holding up better than the rubber ones on my funtana.
I see you have a QQ yak also. How does this one compare?
< Message edited by Jimeni -- 4/25/2008 2:54:41 AM >
(in reply to Zippi)
       Post #: 1256
RE: Intr... - 4/25/2008 12:34:59 PM
Zippi
Status: offline
quote:
ORIGINAL: Jimeni
The QQ YAK 54 looked better than it really was as far as fit and finish. The Aeroworks YAK 54 IMO is a much better quality ARF all around.
(in reply to Jimeni)
       Post #: 1257
RE: Intr... - 5/12/2008 11:12:14 PM
Jimeni
Status: offline
I was hesitant to put the 17x4W APC on the Saito 180 because I like the 18x5 Zinger so much. WOW, shouldnt have waited. It flies like a totally different plane, and I was able to use 15% nitro instead of 20%, significant savings, and more reliable run with the 17x4W. I was having trouble with the hover because of the torque rolling with the 18x5. Now it hovers great, and I can stop the torque roll if I want Rolling harriers are smoother too. Just cant believe that prop could make that big of a difference. Tried some inverted elevators, and was quite impressed, does them better than the Funtana X100, not quite as slow but much much more stable. Inverted harriers are rock solid, slight wing rock in uprights. To be honest, I cant find anything I dont like about this plane yet. Seems to be capable of far more than I am!
(in reply to Zippi)
       Post #: 1258
RE: Intr... - 5/13/2008 5:14:40 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: Jimeni
If you really want to blown away use the Vess sport series props. I bought a 17x6 and a 18x6 and power is awesome with both.The 18x6 seems to have the upper edge in pulling power in terms of hovering. Hover at 1/3 throttle!!! I had an APC 18x6W before and although I had lots of power, the prop was too heavy and put a larger load on the engine. The lighter wood Vess props are awesome!
       Post #: 1259
RE: Intr... - 5/13/2008 5:41:49 PM
adamiani
Status: offline
Anyone with an CRRC pro 26cc in this bird that can give some input? thanks
Alex & Gabriel Damiani
AMA 898637
       Post #: 1260
RE: Intr... - 5/13/2008 6:06:51 PM
budchugger
Status: offline
Just finished mine yesterday, will fly this weekend
26cc evolution gas engine
Duralite 4000mah Lithium Ion redundent with 6v regulator for flight controls
Duralite 1450mah for ignition
Hitec HS-5955 on rudder
Hitec HS-5985 on all other flight controls
Hobbico CS-140 high speed on throttle and choke
18x6 Evolution prop
3" anodized black Tru Turn spinner
custom made tail gear springs (10x better than what came with it)
All Sullivan golden clevices on all controls including pull pull
Bisson muffler
JR 9 channel 2.4 receiver
JR 9303 radio with 2.4 module
Click to see fullsize image.
Click for fullsize
(in reply to adamiani)
       Post #: 1261
RE: Intr... - 5/14/2008 1:28:52 AM
Jimeni
Status: offline
Where can you get vess props in that size? Their site only has 22" and above.
       Post #: 1262
RE: Intr... - 5/14/2008 2:14:44 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: Jimeni
East RC is their sport prop dealer.
http://www.eastrc.org/shop.cgi/page=estoreprops.htm/SID=1210727614.945
       Post #: 1263
RE: Intr... - 5/14/2008 2:16:43 AM
Jimeni
Status: offline
Thanks Frankie!!
       Post #: 1264
