RE: Introducing the new 90-1.20 Yak QB
Tower Hobbies
Logged in as Guest
Users viewing this topic: downwind, highflyer66, Ralph White
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Introducing the new 90-1.20 Yak QB
Page: <<   < prev  53 54 55 [56] 57 58 59 60 61 62   next >   >>
Login
RE: I... - 7/18/2008 9:23:42 PM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: bbellfly
I just lost an edge 540 to flutter that stripped the gears in the ailerons servos. couldn't bring it back. Was wondering if this plane would respond to a Saito 125. What throttle would it require to hover.
bbell
Take a look at this RCU Review. It will answer your questions for the 1.25.
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=911
_____________________________
"To fly is everything." -Wright Brothers
Club Site: www.sccmas.org
(in reply to bbellfly)
       Post #: 1376
RE: I... - 7/19/2008 2:43:09 AM
Jimeni
Status: offline
quote:
ORIGINAL: Ferocious Frankie
quote:
ORIGINAL: bbellfly
bbell
Deffinately ck out the review. The 125 will not be enough for 3D. It will fly the plane nicely for some pattern and sport flying though.
(in reply to Ferocious Frankie)
       Post #: 1377
RE: I... - 7/19/2008 2:48:50 AM
Jimeni
Status: offline
Think I'm going to stick with the Saito 180 for a while. Can't seem to make up my mind on how I want to set this one up and with what?!?!?!?
May just get a Funtana X100 and 26cc or
Ck this new combo out, shes a looker, at a good price.
http://www.peakmodel.com/index.php?main_page=product_info&cPath=1_99_96&products_id=648
(in reply to Jimeni)
       Post #: 1378
RE: I... - 7/24/2008 6:10:34 PM
MOTORMAN37
Status: offline
I have decided on selling my Yak 54 to fund another project. It has never seen fuel, and is all brand new. Here is a link to it. http://www.rcuniverse.com/market/item.cfm?itemID=417392
       Post #: 1379
RE: I... - 7/29/2008 3:59:57 AM
jamesrxx951
Status: offline
well today could have been a real bad day for my yak. 2nd flight this morning a clevis broke on the right aileron on a high speed roll and fluttered violently. i cut the throttle and nursed her in and saved it. i fixed it and later today i dumbthumbed it and it landed in a corn field. 3 hrs later of looking for it i found it completly unharmed. not even a hole in the covering. i decided that was the end of my day. by the way for the saito 150 powered ones what prop do you guys like. i have a xoar 17/5 and a 16/8 and the 16/8 seems to be the best on the upline. but its not a strong as i thought it would be. so i want to try some different props and or manufacturers. any suggestions would be greatly appreciated
(in reply to MOTORMAN37)
       Post #: 1380
RE: I... - 7/29/2008 4:01:17 AM
jamesrxx951
Status: offline
sorry i meant a xoar 17/6 not 5
(in reply to jamesrxx951)
       Post #: 1381
RE: I... - 7/29/2008 4:35:16 AM
Ferocious Frankie
Status: offline
Take a look at the Vess sport line of props. They seem to create a lot more power and put a lot less load on the engine.
www.vessaero.com
Buy at:
www.eastrc.org
       Post #: 1382
RE: ... - 7/29/2008 1:37:57 PM
TomTreese
Status: offline
I used an APC 16/8 on my Saito 150. Flew very well till it lost a head-on battle with the runway
< Message edited by TomTreese -- 7/30/2008 12:17:37 AM >
Insanity: Keep doing the same thing expecting a different result.
       Post #: 1383
RE: I... - 7/30/2008 3:19:40 AM
Jimeni
Status: offline
A 17x4W APC would give you the best vertical, and hover with minimal torque roll. Cant see alot of 3D with a 16x8. I have the 180, and I use a 17x4W. It goes almost as fast vertically as it does horizontally. Just received a Xoar sword 17x6, but have not tried it yet. 18x6 Zinger was absolute garbage. I plan on trying the Vess 17x6 also. I would have to use 30% nitro to properly spin an 18x6, so I'm sticking with 17x4, and 17x6. I can afford 15% nitro. But I'm burning 1.5 gallons or more a week.
       Post #: 1384
RE: I... - 7/30/2008 3:37:04 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: Jimeni
I'm running an APC 18x6W and a Vess sport 18x6. Both seem to be great props. The Vess puts a lighter load on the engine, but it doesn't seem to pull as hard as the APC, but the APC puts a bigger load on the engine.
I haven't tried a 17 prop, but I did have a Zinger 16x8 in the beginning and that seemed to be a great prop also, but was a little too fast for style of flying.
I think the Saito 1.80 just gives great power with any prop!
       Post #: 1385
RE: ... - 8/1/2008 1:50:53 AM
Baker
Status: offline
I have a AW 1.20 yak and I just bought a CRRC 26 Pro to go with mine. Has any body else used this combo?
Jim
       Post #: 1386
RE: ... - 8/2/2008 10:20:43 AM
Ferocious Frankie
Status: offline
quote:
ORIGINAL: Baker
Jim
Hi Jim,
If you look back on this thread, I think someone went with it, but I'm not sure. As long as the engine can turn an 18x6 at 8600 RPM and over you should be fine. Weight factors in too and if the plane becomes too heavy it will fly like a brick. You might have some C.G. issues also, but I don't know the weight of the CRRC 26. The Saito 1.80 weighs in at 31 oz so as long as the 26 is only a few ouces more, you shouldn't have any problems. Take a look at QQ's report of the Evolution 26 on his Yak and watch the video. He basically said that it would hover, but would not have the unlimited performace of a Y.S. 1.40, Saito 1.80, or O.S. 1.60.
http://www.horizonhobby.com/Articles/Article.aspx?ArticleID=1614
http://www.qqaircraft.com/default.asp?s_nav=1&s_page=evo73_hi
Good luck!
< Message edited by Ferocious Frankie -- 8/2/2008 10:27:34 AM >
(in reply to Baker)
       Post #: 1387
RE: ... - 8/2/2008 9:34:53 PM
Baker
Status: offline
Thanks for the links. I am headed there now.
Baker
       Post #: 1388
