reyn3545
Joined: 7/1/2006 From: Alpharetta, GA, USA Status: offline
Yes, we are in the same boat. I had some spare parts laying around from when I re-worked my biplane, so I had enough to get the pull-pull working. I did the ailerons, elevators, rudder, then started laying in the receiver, regulator and battery. Things seemed to be moving ahead OK, then I noticed one of the ailerons wasn't returning to its proper location when I was moving the sticks. It looked like the gear teeth on my airwild servo arms were stripped out. The more I worked the servos, the more it became aparent that the only thing holding ANY of the servos in place was the surface tension from the screw. Airwild sent me the wrong )(* arms. Maybe I ordered the wrong ones, who knows at this point. I only know that if my LHS doesn't have any (they probably don't) .... its going to be a week or more before this thing flies... GRRRRRR. Other than this, I did notice on the wings, if you use the clips to hold the wings against the fuse, the rear pins won't go fully into position unless you drill a hole in the plywood below. The rear of the wings do stick out just a little, so at least on my plane, I think I'm going to use the rear pins. I still like this plane a lot, I think its going to be a nice flyer.
