RE: Introducing the new 90-1.20 Yak QB
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: Introducing the new 90-1.20 Yak QB
Page: <<   < prev  95 96 97 98 [99] 100 101 102 103 104   next >   >>
Login
RE: Introducing the new 90-1.20 Yak QB - 5/22/2009 5:21 AM
capt1597
Score: 100
Last Login: 11/8/2009
Status: offline
well tonight i returned to assembling my new (replacment) plane and i have run into a snag. all the movable control surfaces have 6-hole duel control horn pre-drilled in them but i have 4-hole single control horn hardware like that which came with with my first plane. i am guessing they grabed the wrong  templet during construction. well i assume AW will help me out and  i wll upgrade to a duel-control horn system but i am womdering if my push-rods will stil fit? anybody else run into this situation? i do want to say that i really liked my first plane alot but the replacment seems to be even have  better construction detail. happy flying, capt
Hide Signatures
(in reply to Draknkep)
       Post #: 2451
RE: Introducing the new 90-1.20 Yak QB - 5/22/2009 4:05 PM
capt1597
Score: 100
Status: offline
i talked to mark at AW and he said to match with the inboard or top set of holes and i will be good to go. i'm happy.   looks like good flying this weekend so i need to got her done.  capt
Hide Signatures
(in reply to capt1597)
       Post #: 2452
RE: Introducing the new 90-1.20 Yak QB - 5/24/2009 5:01 AM
capt1597
Score: 100
Status: offline
tonight  i put in the radio, reciever, elevater, rudder, all servos, pull pull cables, aft wheel, main landing gear(reinforced internally with west system epoxy and popcycle sticks such that i now use 1" bolts to secure) and am pleased with the results. i fly off grass so i alwas like to reinforce the gear for the unexpected lump or bump. i do not use wheel covers in grass-to much mantainence.  i do not use a spinner - dead  weight. i  love my saito 150 would never conceder going gas. every time i fill with fuel or get a  wiff of the plane as it flys by it takes me right back to my childhood where i  was flying my big fox35 in my u-control nobler out  behind the grade school. the 150 flys this plane hugh.  so i'll try and slip her in place tomorrow and get this bird finished. my first one flew  great so i am hoping this repacment  will be as good.   HAPPY HOLIDAY,  GOOD FLYING, AND REMEMBER THE VETS,  capt
Hide Signatures
       Post #: 2453
RE: Introducing the new 90-1.20 Yak QB - 5/24/2009 11:01 PM
Draknkep
Score: 100
Last Login: 9/6/2009
Status: offline
HI Capt....
I had the same concern about the way the holes were drilled, but when I called to find out what was going on, I was told that they use the same template for a few planes, including some larger ones that take dual control horns. I  added one more hole, so that I could use four screws in each control horn.
SteveT
< Message edited by Draknkep -- 5/25/2009 6:32 AM >
_____________________________
To go up....pull back on the stick!!!
To go down... back farther on the stick!!!
Hide Signatures
       Post #: 2454
RE: Introducing the new 90-1.20 Yak QB - 5/27/2009 2:59 AM
Ralph White
Score: 100
Status: offline
Angelob,
 Did you find a new choke rod for your MLD-28?  I also broke my choke rod (where the screw goes thru) and need a new one.  I guess I'll try Cermark, but its not listed in the parts section of the manual.
Thanks,     Ralph White, Neoga, IL
Original AMA # 5646
Vintage R/C Society # 846
Hide Signatures
       Post #: 2455
RE: Introducing the new 90-1.20 Yak QB - 5/27/2009 4:20 AM
jjman11
Score: 100
Last Login: 11/6/2009
Status: offline
I just listed my YAK for sale if anyone is interested, building something new.
http://www.rcuniverse.com/market/item.cfm?itemId=518464
I LIKE JET NOISE
Hide Signatures
(in reply to Ralph White)
       Post #: 2456
RE: Introducing the new 90-1.20 Yak QB - 5/27/2009 3:18 PM
angelob
Score: 105
Last Login: 10/17/2009
Status: offline
Ralph,
No I never did find a choke or throttle rod, but admittedly I didnt look too hard.  I just bought a new carb from www.greathobbies.com.  Even though they are in Canada they have fast shipping and it cost me just under $60 including shipping (their website is in canadian dollars).
Angelo
Hide Signatures
(in reply to jjman11)
       Post #: 2457
RE: Introducing the new 90-1.20 Yak QB - 5/27/2009 3:26 PM
Ralph White
Score: 100
Status: offline
Angelo,  Thanks for the reply.  I e-mailed Cermark last night.  I'll let you know how the reply.
Original AMA # 5646
Hide Signatures
(in reply to angelob)
       Post #: 2458
RE: Introducing the new 90-1.20 Yak QB - 5/31/2009 12:17 AM
capt1597
Score: 100
Status: offline
today i completed the assembly of my replacement yac. all good. this bird seems to be sterdier then my first one and i like that. when i went to ballance the plane she was tail heavy so i moved the battery next to the fuel tank and it still required 1&1/2 oz to achieve 3&5/8 ballance point which i liked on my first plane. so that was different.  i did coat the engine area and the landing gear area (all forward of the ballance point. i also put on the nose cone this time for the fun of it (also forward of ballance point) but again did not go with the wheel covers. she however felt heavier then i remembered my first yac to be. we all know the mind can play tricks. so for the fun of it i got a digital scale and guess what, she came in at 11lbs 1oz.  over 1& 1/2 lbs more then the first plane. same motor, same gear, same enhancments, we all know that the weight of balsa can very alot. i am sure it will fly fine but not like her thiner sister did. this is a 15% heavier  and the only thing it can be has to be wood density. i am sure she will last forever what with as strong as she seems to be.   HAPPY FLYING, capt
Hide Signatures
       Post #: 2459
RE: Introducing the new 90-1.20 Yak QB - 5/31/2009 7:09 AM
Draknkep
Score: 100
Status: offline
Hi Capt.....
And if that was the dry weight (no fuel), and you are using the stock tank, you will add about 1.4 pounds of fuel, so even heavier all up weight. But don't fear, my electric conversion weighs 12.8 pounds ready to fly, and flies VERY well. I have just under 200 watts per pounds, and vertical is unlimited. Of course, I don't fly 3D, so if you do, you may notice a difference.
SteveT
< Message edited by Draknkep -- 5/31/2009 7:10 AM >
Hide Signatures
       Post #: 2460
RE: Introducing the new 90-1.20 Yak QB - 5/31/2009 9:43 PM
JCINTEXAS
Score: 100
Status: offline
I am considering getting this Yak.
Would just like to hear from those of you who already have one,
how are you liking yours?  How does the quality compare with
other ARFs on the market?  Do you like the way it flies?
If you had it to do over again, would you still buy this airplane?
Would appreciate any comments and advice.
Regards
JC
Regards
JC
Hide Signatures
       Post #: 2461
RE: Introducing the new 90-1.20 Yak QB - 6/1/2009 3:01 AM
capt1597
Score: 100
Status: offline
JCINTEXAS - read the  RCU review  by mike east it is right on the money. my oppinion- great plane  backed by a first class company. happy flying capt.
Hide Signatures
(in reply to JCINTEXAS)
       Post #: 2462
RE: Introducing the new 90-1.20 Yak QB - 6/1/2009 3:22 AM
jamesrxx951
Score: 100
Status: offline
jcintexas
i don't believe that you can go wrong with this airplane. this plane does fly very well and tracks very good. it does have some wing rock to get used to but i usually kept from doing things that had the wing rock. inverted was more stable though. it does come in heavy so try to keep it light but it is also built for durability. aeroworks is a great comany with goodsupport. for 3d style flying a 18/6 prop is the best. either xoar or vess are great options. a 17/6 is good to but i had a big improvment with the 18"
Hide Signatures
       Post #: 2463
RE: Introducing the new 90-1.20 Yak QB - 6/1/2009 4:50 AM
Ferocious Frankie
Score: 100
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: JCINTEXAS
Regards
JC
I've had mine since August '07. The best airplane I've owned so far bar none!
Plane: AW 50cc Extra 300
Radio: Futaba 12FG 2.4 GHz
Hide Signatures
       Post #: 2464
RE: Introducing the new 90-1.20 Yak QB - 6/1/2009 11:30 PM
capt1597
Score: 100
Status: offline
maidened the plane and it flys great. not one click of trim needed.vertical was slower but still unlimited. i will be having some fun with this plane.the tracking was fabulas, just smooth as silk. it is a little heaveier than before but so is my wife. next winter i'll but put both of them on a diet and see what happens.i am sure i will have better luck with the yac. for now it is summer time here in the great lakes region so i will be playing outside  till the snow flys.   HAPPY FLYING, capt
Hide Signatures
(in reply to Ferocious Frankie)
       Post #: 2465
RE: Introducing the new 90-1.20 Yak QB - 6/2/2009 1:36 AM
Ferocious Frankie
Score: 100
Status: offline
quote:
ORIGINAL: capt1597
Ouch! Make sure she doesn't read that one.
Hide Signatures
       Post #: 2466
RE: Introducing the new 90-1.20 Yak QB - 6/2/2009 1:51 AM
Jimeni
Score: 105
Status: offline
I guess if I compared my wife to this Yak, would I have to sell her too?
It was a glitch, a technical malfunction!
Hide Signatures
       Post #: 2467
RE: Introducing the new 90-1.20 Yak QB - 6/2/2009 2:23 AM
jamesrxx951
Score: 100
Status: offline
as long as she don't make you "yak" you will be just fine
Hide Signatures
(in reply to Jimeni)
       Post #: 2468
RE: Introducing the new 90-1.20 Yak QB - 6/2/2009 11:26 PM
capt1597
Score: 100
Status: offline
the process has now begun starting with the easy stuff. nose cone removed and a dubro spinner prop nut in its place with a savings of 2oz. i want to palance this bird at  3 & 5/8" ( just my preference) and i am still just  slightly forward of this. tomorrow i am ordering a  vess prop so to save weight from my  apc . the real chalenge will be getting some weight out of the stearn. i  have the tail feathers from my crashed plane to open up to consider the posibilities. happy flying , capt
Hide Signatures
(in reply to jamesrxx951)
       Post #: 2469
RE: Introducing the new 90-1.20 Yak QB - 6/6/2009 4:41 AM
RC Pile It
Score: 100
Status: offline
Hey all, I am new to this forum, but have been flying my Yak for about 3 months. I first flew it with a YS120, and at 6000ft, it was a little doggy(limited vert.), pulled it off, and went to a SPE26, about the same....I am now gonna try a differant spe26, as I feel the first one had some issues. Upon my last landing(this past Sun.)..., smooth glide, to a nice flare, and the gear falls off! Now I have never had what I would consider a really hard landing, but I did notice that my wheels had broken(prior), so I don't know if they just didn't want to rotate at that very point, but I was a little disappointed to find that my gear block was thin solid wood, not ply. I replaced the split pieces with 1/4" ply, and floated some epoxy mixed with microballoons, from the topside. I might advise others to take a look, and add a little sumpin-sumpin from the top side to transfer stress a little bit. It isn't a bad design, but the epoxy/balloon combo adds a bunch of strength, and little weight. Any other recomendations would be appreciated! Otherwise, I really like the plane. As already noted(By others), it does have some coupling, but I don't mix flying styles, so this one is my li'l imac practice, and is mixed as such. Good Flying!!! Have Fun!
Hide Signatures
       Post #: 2470
RE: Introducing the new 90-1.20 Yak QB - 6/9/2009 1:27 AM
capt1597
Score: 100
Status: offline
 ralph white, have you had a chance to fly your plane yet?   r.c. i to reinforced the inside of the landing gear area. when my first plane bit the dust the reinforcement was one of the few areas that stayed intact so i repeted the prosess this time around.  as far as the flying it is the best 90-120 plane that i have found. happy flying , capt
Hide Signatures
(in reply to RC Pile It)
       Post #: 2471
RE: Introducing the new 90-1.20 Yak QB - 6/9/2009 1:42 AM
Ralph White
Score: 100
Status: offline
Capt 1597,  I plan to fly it this week-end.  All I have left to do is paint the cowl and iron down the seams on the ultra-coat covering.  I've been a little lazy lately about posting any pictures in my build thread.  I'll be posting the finished pictures as soon as I get the cowl painted.
I broke the choke rod in two on the MLD -28.  I'll be posting how I repaired it later tonight if I get time.
Original AMA # 5646
Hide Signatures
       Post #: 2472
RE: Introducing the new 90-1.20 Yak QB - 6/9/2009 4:12 AM
JCINTEXAS
Score: 100
Status: offline
Thanks Frankie and all of you who responded to my questions about this airplane.
Here's another question. Would the MARK 1.35 glow engine be a good powerplant for the AW Yak?
Regards
JC
Regards
JC
Hide Signatures
       Post #: 2473
RE: Introducing the new 90-1.20 Yak QB - 6/9/2009 2:13 PM
jamesrxx951
Score: 100
Status: offline
quote:
ORIGINAL: JCINTEXAS
Regards
JC
if it is stronger than a os120 i would have to think that it would work out just fine. what sized prop can it swing and at what rpm. i have a mld 28 and it swings a 18/6 @8200 rpm and it is awsome. i had a saito 150 swinging a 17/6 vess over 8k i beleive it been awhile and it was great also. so if it can swing a large prop it should be ok
Hide Signatures
       Post #: 2474
RE: Introducing the new 90-1.20 Yak QB - 6/11/2009 4:09 PM
HoverLoW
Score: 100
Last Login: 10/16/2009
Status: offline
Guys, I am totaly lost on my Yak control horn assembly.
Mine didn't came as the others Yaks I,ve seen around here. It doesn't macthes with the manual too.
Looking to the manual, the pictures shows that the flying surfaces has 4 holes for each control horn, but mine has 6 holes separeted by two groups of three holes. At first, I was thinking this should be for using double control horns, but mine kit has come with just 6 horns (2 for ailerons, 2 for elevators and 2 for rudder). So now I have a doubt about it. If I choose one group of holes, one hole is missing, because the control horn claims 4 holes each. Ok, I can do the other hole. But will my plane have that ugly group of pre-drilled holes remained after all?
I'm sending a diagram about what is happening attached.
Could anybody tell me what's going on?
Another question: This QB thing is really cool, but prior to good looking, there is no gap between the fixed and movable surfaces and so my servos are doing a hard work to get 43 degrees of deflection. Is this a good 3D aircraft?
Click to see fullsize image.
Click for fullsize
< Message edited by HoverLoW -- 6/11/2009 4:12 PM >
Hide Signatures
       Post #: 2475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.782RCU1
