flatfour
Joined: 12/29/2001 From: Midlothian, IL, USA Status: offline
No the rate you select is the actual amperage that will be delivered during the charge. The ST has no way to tell what the "C" value of the attached pack is. It is up to you to do the C/10, C and 2C calculations. 0.1=100 MA 1.5= 1.5 amps or 1500 MA The ST is a peak detect charger. You can't set a time limit for charging. All you can set is the current. The one extra setting is the max charge that will be put in. As the charge cycle runs, the ST keeps track of the accumulated MAH. You can see this on the screen as the charge progresses. It is a simple calculation of current multiplied by the time of charge. If you have a 1000 mah battery, a good number to set would be 1200. This way, if the charger does not peak detect for some reason, it will shut down when it has given the pack 1200 MAH A "rule" of thumb is to set it to 10-20% higher than the pack capacity. Now discharge is another animal. Most manufacturers rate the capacity of their cells at a 5 hour rate (C/5). The downside to this is that it will take 5 hours to discharge the pack. If you go significantly above this (discharge a 1000ma pack at '2C' 2 amps) the apparent capacity will decrease. If you plan to keep records of your pack capacity over time, just be sure to stick with the same discharge rate every time. Your screen should look like this: M1 NiCD C=1.5 D=0.2 1200
< Message edited by flatfour -- Jan 4 2003 5:33AM >
_____________________________
Jim in Chicagoland
