digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
quote:
ORIGINAL: Vampire Hello Beljet, First, the correct idle for a Simjet - 3000 is approx. 30,000 > 31,000 rpm. It is recommended that you contact Digitech for asistance as Simjet currently uses and supports the GASPAR Fadec ECU which learns the pump you are intending to use. I believe that the Digitech will do the same. A call to Kim at Simjet-Denmark may be of value to you as well as Ed has suggested. Best Regards, Hi the Digitech ECU is basically a "enclosed" ecu. it has different hardware and has a bit more advanced electronics on board.(kerosene ready) it has exactly the same software as they are programmed by Gaspar Espiell so it behaves the same as the Gaspar ecu my guess is you have a problem/restriction somewhere in your fuel line(s) or you changed the fuel lines length since it first run just run it again go from idle to full power in 10 seconds -stay there on full power for 10 seconds , then go to idle again in 10 seconds and for my personal setting i would set the idle to 32000 rpm the turbine runs much better on this point the thrust at 32000 is only 350 grams (0.3N) but faster spool up , and better stabilize is your system 12 volts? @ Kerry US SimJet, LLC Simjet should support all their customers regardless the ecu they are using a bit more investigation would have revealed that the a.t.c.u’s delivered by us worked flawless and never missed a "beat". and where delivered to Simjet at a time that the FADEC ecu was not "Available" but because of gentleman’s agreements we did not deliver them as soon the Gaspar fadec where back on track. Best Regards Sandòr Kruise
< Message edited by Sandor -- 4/4/2006 11:22:22 AM >
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF. "Home of the Pro-Lynx Gears"
