RE: Official Dark Impact Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Official Dark Impact Thread Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Official Dark Impact Thread - 4/7/2006 1:15:06 AM
sibulord
Status: offline
Hi,
I am interested in getting the Dark Impact!
Please, could anyone tell me the wheelbase measurement and
the maximum width of the car (wheel nuts to wheel nuts)?
I may put a different body later on.
Also, about the pinion gears, are they standard 48P like these ones,
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEX24&P=7
or are they 'Tamiya' standard ones like this,
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGJ70&P=7
I heard that Tamiya's 48P are different to those made by Robinson/Kimboroughs.
The reason i am asking is I am about to make the purchase of the Dark one
and would like to order the correct pinions gear as well.
(I guess you can say it is 'Impacting' my purchase right now! hehe!)
Also, are there any 'essential' spare parts or hop-up parts I should get as well.
You know, parts that happen to wear out faster than others and parts that will add
flexibility/functions/performance or whatever.
Thanks in advance.
(in reply to BitHed)
       Post #: 26
RE: Official Dark Impact Thread - 4/7/2006 1:17:40 AM
CustomTamiyas4Life
Status: offline
I believe the tamiya gears are 72 pitch. Not really any aluminum or anything avalible yet, so at this point, all i would reccomend is a nice motor and esc.
_____________________________
TNX / twin detonator truggy / E-firestorm / Tamiya Rising Storm / mod pede / walkera 4 / mini-t
(in reply to sibulord)
       Post #: 27
RE: Official Dark Impact Thread - 4/7/2006 3:15:16 AM
BitHed
Status: offline
...The drivetrain of the DI is a little different..Of course you could all know this already and I am just running behind
...here are the front and rear diffs from TAMIYA...The front is on the left...
...The stock pinion is 26t...Quite big...The stock spur is 78t as noted earlier...An 85t is also included and TAMIYA says it is not used in the instructions but it WILL fit...The bigger spur will give us more start torque than the 'stock' one but a slightly slower top speed...
...This might get confusing because i dont fully understand it myself...Tamiya is using a '05 Module' pinion...It is not something I have seen before but it loks like a trickle-down from the higher level on-road sedans...
...TAMIYA lists the wheel base as 260mm but i am not sure of from where they measure...
< Message edited by BitHed -- 4/7/2006 3:50:47 AM >
Delivered Fresh Daily
(in reply to CustomTamiyas4Life)
       Post #: 28
RE: Official Dark Impact Thread - 4/7/2006 3:43:30 AM
MBX5T Maniac
Status: offline
whn can we US'ers get on hands on one of these little buggers?
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
       Post #: 29
RE: Official Dark Impact Thread - 4/7/2006 3:52:40 AM
BitHed
Status: offline
...TAMIYA still has no info on their site, linked at the top of the thread, but they have a lot more eye-candy up...
...I finished the build last night and the pictures dont even do the CHASSIS justice...It just looks so damn good...
(in reply to MBX5T Maniac)
       Post #: 30
RE: Official Dark Impact Thread - 4/7/2006 4:00:35 AM
BitHed
Status: offline
quote:
ORIGINAL:
...SibuLord they are NEITHER of these sizes...the teeth are MUCH smaller...
...RE: Parts to pick up...IMO; 8 softer o-rings, (30-35 hardness), FOUR x 850 bearings for the steering rack, (i put some in and it is a no-brainer), flouring coated 5mm pivot balls, (10 in a pack but you need 12) and the 'other' 5mm pivot balls, ( the ones that take a screw to be mounted, the ones that DONT have a screw post on them), also flourine coated...other than that you should be good to go...
...BTW the stock threaded shafts are a MAJOR PITA!! Fit them and then get the adjustables the MINUTE they are released...
       Post #: 31
RE: Official Dark Impact Thread - 4/7/2006 8:07:20 PM
CustomTamiyas4Life
Status: offline
Man, that tranny is crap compared to the rising storm...the weight, the tranny...i'm starting to doubt that this is so great. Besides the turnbuckles nothing different really catches my eye.
       Post #: 32
RE: Official Dark Impact Thread - 4/8/2006 5:03:16 AM
_iceman_
Status: offline
sertainly looks intersting with the battary opening from the bottom (there have been a load more pics of this guy on it's page right here)
heres the pics of the "DF serises"
started as this:
then this:
and now this:
think there getting somewhere or is this new one a step back?
Garage: Traxxas E-maxx | Tamiya hummer
       Post #: 33
RE: Official Dark Impact Thread - 4/8/2006 3:59:39 PM
CustomTamiyas4Life
Status: offline
As i mentioned earlier, from hearing the weights and such, i'm not seeing a huge advantage. If i was tamiya, i would've spent that extra 50 bucks per kit throwing camber links and changing the spur/pinion setup on the rising storm.
(in reply to _iceman_)
       Post #: 34
RE: Official Dark Impact Thread - 4/9/2006 1:35:01 AM
BitHed
Status: offline
...rememeber they are different chassis though...The 03 takes the battery IN the chassis front to end in the middle...This chassis is head and shoulders above the other ones they have done...Seriously quick and seriously nimble...I am not trying to 'persuade' anyne at all but it makes past TAMIYA buggys look shameful...
...I have to disagree with ThatsAnEvader...The Di comes stock with bearings and an exceptional set of rims / tires at just a tiny little more in stock cost...It is a superior machine out of the box...The tie-rods suck for sure but thats about it...but I also must say that the 'stock' settings are loose as a goose and the adjustable buckles SHOULD have been in from the start...
< Message edited by BitHed -- 4/9/2006 1:40:41 AM >
       Post #: 35
RE: Official Dark Impact Thread - 4/9/2006 1:37:38 AM
CustomTamiyas4Life
Status: offline
How's the understeer on this one?
       Post #: 36
RE: Official Dark Impact Thread - 4/9/2006 2:01:13 AM
BitHed
Status: offline
...TAE I havent had too much time on it yet and its brushless and mostly on asphalt so far but it feels to be more over than under...The rear is quite slippery...Looks like maybe too much camber with the stock settings...Its turning on a dime though...Pretty impressed...
...You know when you get a new car, be it RTR or kit, and the first time you drive it and a certain thing is quite obviously wrong or not good? The only thing that I came up with was the rear setting...Other than that its great...Of course we all know that you fix one part and the gremlin moves somewhere else...But so far the slippery heiney is all i can point to and say YUCK!! That and the turnbuckles from Satan's own workshop
       Post #: 37
RE: Official Dark Impact Thread - 4/9/2006 11:06:52 PM
_iceman_
Status: offline
bithead are you telling me you atuly have one? or are you just eyeballing it and thinking of what the problems could/will be? (i'm not being rude i hope just hopeing that someone has one )
so uh when are these guys coming out?
       Post #: 38
RE: Official Dark Impact Thread - 4/9/2006 11:59:24 PM
CustomTamiyas4Life
Status: offline
He has one...
I think they're coming out in may.
       Post #: 39
RE: Official Dark Impact Thread - 4/10/2006 12:17:29 AM
