Phelansa
Joined: 7/9/2006 From: PretoriaGauteng, SOUTH AFRICA Status: offline
Lolol, so you had no traction because you had overcooked the throttle, but it is the buggies fault? [)] Dont mind me. I am just pulling your leg! The gears weak? I have never found the front gears on the DF03 to be weak. I run a MM5700 with a 3S LiPo and have never had any problems what so ever with the front gears. The point is, if you don't like the buggy then sell it. Not worth aggravating yourself over a car you do not like to begin with. Just as long as you know that you will not find anything that is better than the DF03. By better I mean a combination of speed, handling, price and toughness.
_____________________________
DF03-MM 4600, RS4 MT MM4600, Mayhem ST. Lama V4, HB Cool, BeltCp, TRex 450 and next...... ESmart!
