RE: Official Dark Impact Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Official Dark Impact Thread
Page: <<   < prev  56 57 58 [59] 60 61 62 63 64 65   next >   >>
Login
RE: ... - 5/20/2008 1:03:29 PM
ArildS
Status: offline
quote:
ORIGINAL: redline433
Can anyone tell me please how tight the diffs should be?
I have melted two diffs because i think they have been too tight?
Too loose. You should also tighten the diff regularly. Specially on Lipo and BL power
_____________________________
Garage: Avante-1988 | Dark Impact MM5700 | Brat | Midnight Pumpkin | TXT | Baja 5B SS| Nxt:Frog, Hornet and Avante Mk.I
(in reply to redline433)
       Post #: 1451
RE: ... - 5/20/2008 4:41:14 PM
stealth assassin
Status: offline
quote:
ORIGINAL: stealth assassin
I think I have done something a little differant with my set up... I am running a hub that takes 64 pitch spurs that fit most pinions for the 5mm shaft motors I run.
Surely someone else Is doing this? Nobody Is running a 5mm shaft motor???
(in reply to stealth assassin)
       Post #: 1452
RE: ... - 5/21/2008 12:41:06 AM
streetracer745
Status: offline
im running 5mm motor shaft in my erevo... you sure its 64pitch and not 32p? i didnt think they made a 64p pinion with a 5mm shaft... what spur are you running on the car? and how?
-who needs the street to drift?
       Post #: 1453
RE: ... - 5/21/2008 12:55:41 AM
stealth assassin
Status: offline
The spur Is a 64 pitch on a hub made for univeral spurs. the pinion Is the big round tooth mod 1 from... I forget the name Of the online store.
(in reply to streetracer745)
       Post #: 1454
RE: ... - 5/21/2008 1:10:20 AM
redline433
Status: offline
quote:
ORIGINAL: ArildS
Cheers for the diagnosis. I have done some research and found some info on how tight the ball diff should be and i did indeed have it too loose, even though i thought it was tight enough.
Thanks again.
(in reply to ArildS)
       Post #: 1455
RE: ... - 5/21/2008 2:57:01 AM
streetracer745
Status: offline
64p spur with mod1 pinion???? is that what your saying? because that just doesnt work... got any pictures?
       Post #: 1456
RE: ... - 5/21/2008 3:10:08 AM
stealth assassin
Status: offline
I may have confused the mod1 with the 32 pitch.Opps.... Anyway close enough. I have run these pinions with 64 spur on this DI and a rs4. I looks all wrong but It works. e-mail the site owner and ask him.
http://www.rc-monster.com/proddetail.php?prod=32pinion5mm&cat=40
< Message edited by stealth assassin -- 5/21/2008 3:12:30 AM >
       Post #: 1457
RE: ... - 5/21/2008 8:50:43 AM
Texy
Status: offline
My DI kit arrived from Hong Kong yesterday minus the ESC that was described in the eBay listing
I knew the ESC is not supplied in the kit, but it was in the listing so I sent an email to the seller asking him where it was.
He said it was a listing error and that it is not supplied in the kit, but he will send me one anyway
Not that I really need it as I have the sidewinder combo on its way in the post
Anyway I,m looking through the instructions and as you all know, the rear diff assembly is built first.
I see that it is telling you to CA the diff plates (MK6), however I notice that it does NOT tell you to CA
the diff plates when building the front diff assembly. Is that right, as it seems strange to CA one diff and not the other?
Also are there any other places I should CA or locktight whilst building? If I am right, the only place I can see CA mentioned
in the build instructions is when building the rear diff.
Oh, and another question - I have the slip clutch kit also - which pinion/spur ratio is best to use with the 4600kv sidewinder
combo?
Cheers,
Texy
< Message edited by Texy -- 5/21/2008 8:53:55 AM >
http://myweb.tiscali.co.uk/texyuk/
       Post #: 1458
RE: ... - 5/21/2008 9:56:44 PM
streetracer745
Status: offline
you should probably try the gear supplied with the slipper. its like 81 or something? 82 maybe? and if its not hot step to the 78 and if it is step to the 85.
how does that work out? the 64 spur with the 32 pinion? i just dont see how it could work! and what motor are you running? and where can i get the hub? is it useable with the slipper?
(in reply to Texy)
       Post #: 1459
RE: ... - 5/22/2008 12:02:26 AM
svavrek
Status: offline
What other rims will fit on the DF-03 Chassis? Im havin major issues with wheels here Looking at:
http://cgi.ebay.com/3Racing-TAMIYA-DF-03-5-Spoke-Tyre-Rim-Set-Black_W0QQitemZ160242608567QQihZ006QQcategoryZ34061QQrdZ1QQssPageNameZWD4VQQcmdZViewItem
for an upgrade... hoping these have more clearance than the stocks, but dont want to wait 2 weeks or more and spend 50 bucks on these shipped to the US if they WONT work... I may have to suck it up and just modify these YR Arms... Don't want to but may have to Dammit all.
       Post #: 1460
RE: ... - 5/22/2008 12:21:50 AM
stealth assassin
Status: offline
quote:
ORIGINAL: streetracer745
Sounds off but, The teeth line up while rolling the gears and this Is my second car running these type gears without any damage to either gears. FDM sells the 5mm hub for a boat tranny... I did my research on this one. Trail and error!
I run NEU and feigiao motors. It's all about the kv... I can run a $60 motor and a $60 dollor esc If I want and run with any Mamba max, novak or lrp set up. I prefer NEU motors.
the slipper on my rs4 worked. It depends on differant specs. The one thing I do not like about the DI Is there Is not alot of adjustment of the motor for taller gears until I found the lower tooth pinions with the 5mm shaft.
       Post #: 1461
RE: ... - 5/22/2008 1:01:05 AM
muckute
Status: offline
quote:
ORIGINAL: Texy
The reason for the glue on the rear diff is because it has two piece diff joint and the part that the diff plates go on is plastic. I would get steel replacements for these asap as the plastic won't last long with a brushless setup. My suggestion would be to get the square diff joint (*LINK*) and put them in the front and then use the standard kit ones in the rear. The square ones are more expensive than others but they have lasted heaps longer in my car
(in reply to Texy)
       Post #: 1462
RE: ... - 5/22/2008 2:12:19 AM
streetracer745
Status: offline
does the 32pinion like skip every other tooth on the 64 spur? where can i get the hub? does it have a link? what esc?
(in reply to muckute)
       Post #: 1463
RE: ... - 5/22/2008 3:24:41 AM
