Virtual reality
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> Virtual reality Page: [1]
Login
Virtual reality - 12/11/2002 9:32 PM
gubnuh
Score: 100
Last Login: 1/13/2003
Status: offline
If you've got some extra cash, pick up some virtual reality goggles and link them to the video out. You need to be seated (so you don't fall down when you spin!) and have someone on a buddy box (so you don't crash!) if you try this.
We have a color system w/ 1.3 mile range. We also record the flights during dogfights hoping for a camera-center mid-air. We've only gotten the debris on film so far.
Even on a rainy day you can still be in the cockpit by watching the tape with the VR goggles. We are working on a telemetry system so we could fly by TV monitor - our main problem is finding an instrument small enough to indicate altitude. Any ideas?
_____________________________
one is too many; one thousand is not enough
Hide Signatures
       Post #: 1
Virtual reality - 12/14/2002 8:05 AM
billf
Score: 100
Last Login: 2/1/2010
Status: offline
Hello Gubnuh...
Congratulations! You are doing what I have thought about for a long time. Do the goggles you have give a 3D effect? That is does each eye see a stereoptic image. To do this I assume a person would need two cameras and two down-links.
For me the first step would be to obtain the goggles that could accept two video images. Can you suggest a couple of brands?
Bill
Hide Signatures
(in reply to gubnuh)
       Post #: 2
Virtual reality - 12/17/2002 8:20 PM
gubnuh
Score: 100
Status: offline
No 3-D effect with the goggles we are using. It is the equivalent of viewing an 80" TV screen from 10' away. I don't know much about VR goggles other than how to hook them up, but I would say get as high a resolution (measured in pixels?) as you can afford.
Hide Signatures
       Post #: 3
Virtual reality - 12/18/2002 6:16 AM
lvspark
Score: 105
Last Login: 11/2/2009
Status: offline
Here is the perfect unit.
[URL=http://www.sky-spy.bigstep.com/generic.html;$sessionid$F3AYOZQAAABEPTZENUFJPQWPERWRJPX0?pid=0]here[/URL]
I have one, and just get the board only and it goes inline with your video signal. You can also connect a GPS super easy. Just plug it in!
Hide Signatures
       Post #: 4
Well.... - 12/18/2002 7:25 AM
jsonin
Score: 100
Last Login: 12/16/2009
Status: offline
VR or virtual reality is different from this thread's current example of projected small displays (such as iGlasses, etc). iGlasses are a simple, accessible, inexpensive, and great way to view the on-board camera image. They cost just a few hundred dollars. iGlasses are fed a single video signal from the on-board camera (on-board transmitter to the on-ground receiver) and GPS data can be overlayed (as seen on the link in the post above).
Flying with iGlasses (or any type of HUD/video lcd) can be tricky... primarily because the camera's field of view is narrow (~50mm) and it's difficult for the pilot to get a grasp of the entire geography (especially during take-off and landing). High-flying is not too difficult with iGlasses, but a spotter is highly recommended.
Loosing field orientation can be easy when wearing the iGlasses and flying high (above 500 feet).. again because of camera field of view. We've found a half-baked remedy:
1. Pipe the on-board GPS data into a laptop (the CPU is on-ground).
2. Using Syzygy or another real-time visualization application, render very basic terrain data and orientation (not just altitude and speed, but more importantly, terrain markers).
3. Overlay this simple render over the on-board video so the pilot can view the camera image as well as real-time geospatial data on the iGlasses.
Note: Even simple terrain data overlays can complicate flying. Typically simple markers such as a wireframe flag noting where the field is (and a moving vector if the field isn't in view....so the pilot can quickly navigate back) is all that's required. Any extraneous or complicated viz overlay disrupts points of interest and more importantly, pilot orientation.
This works very nicely.
-Juhan
Juhan Sonin
http://www.mit.edu/~juhan/rc_home.html
Hide Signatures
       Post #: 5
Virtual reality - 12/18/2002 12:44 PM
wojtek
Score: 100
Last Login: 2/2/2010
Status: offline
I flew my 30 sized heli via a 3d VR interface 2 years ago. I set up a dual set of ccd cameras, transmiters and receivers ... I wired 2 paist os Sony Glasstron HUD visors together for separate left and right view to each eye.
I managed to align the cameras fairly well and was getting true 3d depth perception. It was fun flying the heli from the HUD, but I could only go under 500 feet away with my setup ... Also, 5 minutes of this would give me a nasty headache (going crosseyed) it was neat to fly nose in and actually be looking at myself ...
the whole project 2 years ago cost me over $2000, and im sure this stuff is still up there $$
Wojtek
Nothing can ever be fast enough !!!
Hide Signatures
       Post #: 6
VR - 12/24/2002 9:18 AM
hobbyboy
Score: 100
Last Login: 1/28/2004
Status: offline
I have been flying full vr flights from inside my house using I glasses and my Raptor 30 for a few years now. I did find using a big screen TV was better then the I glasses when it was practical.
Bob
Jesus is Lord!
Hide Signatures
       Post #: 7
Virtual reality - 12/24/2002 9:50 AM
wojtek
Score: 100
Status: offline
awesome .. glad to hear someone else is doing this stuff too ... i will say, nothing beats the actual 3d experioence ...
Wojtek
Hide Signatures
       Post #: 8
3D VR with IGlasses - 12/28/2002 12:36 AM
rcjetpilot
Score: 100
Last Login: 3/11/2010
Status: offline
I've been using Iglasses with two cameras and a flop flop video circuit so that I can use one transmitter interlacing the two video feeds. I cant fly and view at the same time but I have been selling VR rides out at our fields to spectators.
Ray Grauberger
rcjetpilot@rcmodeler.net
Hide Signatures
       Post #: 9
Where to purchase - 1/8/2003 7:03 PM
NathanGerhards
Score: 100
Last Login: 10/10/2003
Status: offline
Where do you purchase these goggles? I am a real pilot and would love to utilize this setup to fly on days where I want to be on the bround with my other rc buddies. Thanks
Fly hard and grab your &@!!$ and try that manuever you want to learn, just keep it safe and stay out from above the spectato
Hide Signatures
       Post #: 10
Virtual reality - 1/8/2003 8:21 PM
MikeDD
Score: 100
Last Login: 9/23/2007
Status: offline
Here is a comparison page for VR googles
http://www.stereo3d.com/hmd.htm
http://www.mrcc.info
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
