Tornado XP problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Tornado XP problem
Page: [1]
Login
Tornado XP problem - 4/9/2006 3:42 AM
YZ80racer
Score: 100
Last Login: 11/18/2006
Status: offline
I was driving my tornado xp and then it just started reving out and not moving is the gear stripped or some spring bad?
Hide Signatures
       Post #: 1
RE: Tornado XP problem - 4/9/2006 3:48 AM
shawnTXP
Score: 100
Last Login: 5/8/2006
Status: offline
it sounds like your clutch slice spring is broken. I had the same problem, replaced it and now all is fine. get it from chubbysdad for less than $5 and his shipping is super quick!
Hide Signatures
(in reply to YZ80racer)
       Post #: 2
RE: Tornado XP problem - 4/9/2006 3:49 AM
AJsToyz
Score: 304
Last Login: 5/18/2013
Status: offline
Good chance the gears are stripped. Flip it over and look up from the bottom. There is a hole that you can see to gears through , if one or both is stripped thats the problem
_____________________________
www.Deathbychina.com
Hide Signatures
       Post #: 3
RE: Tornado XP problem - 4/9/2006 3:51 AM
Stormy_H
Score: 100
Last Login: 5/5/2006
Status: offline
Often times the gears do strip.
We do have them in stock and www.RedcatRacingParts.com when you are in need.
Gear grease can help prevent stripping gears.
Stormy
Hide Signatures
       Post #: 4
RE: Tornado XP problem - 4/9/2006 4:07 AM
YZ80racer
Score: 100
Status: offline
Well one piece of it is chipped so thats the problem so what part(s) should i exactly order
Hide Signatures
(in reply to Stormy_H)
       Post #: 5
RE: Tornado XP problem - 4/9/2006 4:21 AM
YZ80racer
Score: 100
Status: offline
There are alot of gear parts i just dont know which one to order
Hide Signatures
       Post #: 6
RE: Tornado XP problem - 4/9/2006 5:04 AM
Stormy_H
Score: 100
Status: offline
Do you still have your manual? If so, there's a parts explored view in the back that should be fairly easy to navigate.
If not, I can surely help you out. Just shoot me an email at stormy@hildcycles.com
Stormy
Hide Signatures
       Post #: 7
RE: Tornado XP problem - 4/9/2006 5:20 AM
shawnTXP
Score: 100
Status: offline
you need the 42 and the 47 tooth gears
Hide Signatures
       Post #: 8
RE: Tornado XP problem - 4/9/2006 5:35 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
shawntxp is right, i am on my 2nd set already, this is a problem for some reason. i am experienced in nitro and still happens to me, next time i will be putting the single speed in it.
< Message edited by ehroof -- 4/9/2006 5:37 AM >
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to shawnTXP)
       Post #: 9
RE: Tornado XP problem - 4/9/2006 6:14 PM
AJsToyz
Score: 304
Status: offline
I took mine apart to check the whole car for loose parts. I'm a little tired of this thing falling apart. I've got that small screw loctite and will be quite liberal with it. The clutch housing on mine is a total POS . There is no way to make mine sit straight so the gears mesh properly with out just jambing them together. The tips of the gears are the only thing touching and the clutch housing is about worn out from the plastic wearing on it. I also looked at the two speed , the little weight that comes out to hit second seems stuck. No matter what you do it does not move. If I can I might try to put the Volcano gears in mine then go with the bugger tires. If not , I'll go single speed from the XL, there is no way this will hold up the way the parts are made.
Hide Signatures
(in reply to ehroof)
       Post #: 10
RE: Tornado XP problem - 4/9/2006 8:18 PM
YZ80racer
Score: 100
Status: offline
How exactly do u change the two speed to the one speed. What are all the parts required to convert the two speed to the one speed.
Hide Signatures
(in reply to AJsToyz)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
