CCbusa05
NV, USA Status: offline
quote:
ORIGINAL: up4speed Quick question, My coco Lama V3 flew rock solid (maybe with one or two trim corrections per battery pack), until recently. It seems that I am always chasing the tail to trim it out. It varies which direction it drifts, but it may start out rotating to the left, then a minute later back to the right, then left, then left, then right etc. I seem to be doing this for the full battery charge every 1/2 to 1 minute. Does anyone have any idea what's going on? Do I maybe have worn out motors? If so, can I get upgraded ones? Thanks in advance. First thing you want to do when you first lift off with a fresh battery is immediately note which way your yaw is. Land and make proportional screw (on the 4in1) adjustment accordingly. What you are looking to accomplish is a straight tracking tail UPON FIRST LIFT OFF with a freshly charged battery. OK, next, fly for 30 to 60 seconds (make NO rudder trim adjustment during this period) then land. Unplug and rearm your battery and fly as you normally would. You should now only have to make minor and infrequent rudder trim adjustments during the course of your flight (10 minutes +/-). Now, if the above had no effect on your frequent trimming during flight, you might want to try increasing the gyro gain ever so slightly (your tail will quiver if you have increased it too much). Regardless, get into the habit of initially flying for 30 to 60 seconds, landing, then rearming, then flying as you normally would. Believe it or not, this little trick works wonders!
< Message edited by CCbusa05 -- 2/16/2007 6:05:03 PM >
