5245 version#??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> 5245 version#??
Page: [1]
Login
5245 version#?? - 4/16/2006 2:25:31 AM
dlwood
Status: offline
Mike I have 6 5245 servos I want to use with a Futaba PCM reciever. I bought these in the spring-summer ? of 2005. There is no version # on the servo nor on the box. No date codes or identifiers other than a ce on the bottom of the case. When cycled using the PCM reciever all seme to function properly except for distinct steps during stick motion.
How do I tell the version#? Is there a functional test?? What is the presentation of the incompatability?
Don Woodruff
       Post #: 1
RE: 5245 version#?? - 4/17/2006 1:38:12 PM
mglavin
Status: offline
The servos are more likely than not revision v1.03 digitals. Early release v1.04 revision servos suffer a known compatibility issue realized when two more servos a driven from a wye connector and a single channel of a Futaba PCM RX. The servos will not react and or function in this circumstance. A free upgrade is offered by Hitec Service which eliminates this short-coming.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to dlwood)
       Post #: 2
RE: 5245 version#?? - 4/18/2006 4:24:49 PM
dlwood
Status: offline
As these will be paired on Ys I'll be sending them in.
(in reply to mglavin)
       Post #: 3
RE: 5245 version#?? - 4/19/2006 1:13:52 AM
mglavin
Status: offline
As noted this problem is only relaized with Futaba PCM RX's... Be sure and mention the need to utilize your servos with Futaba PCM with your return and contact info.
Michael Glavin
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
