Red Scholefield
FL, USA Status: offline
[QUOTE]Originally posted by Jube T. Cornpone Red, When I tested the Triton, it apparently fully charged the larger LiPolys, e.g., Kokam 1020-3270s. Have you observed variation in the Triton charging performance apparently depending on the C of the charged cell? - Jube [/QUOTE] Yes the higher the capacity of the cells the more closely the Triton brings them to full charge. Backing off on the charge rate also gets them charged to a higher state, albeit taking a lot longer. Life is full of trade offs. With my Lite stick on 2 1020 cells I get a half hour of flying - more than enough, so I don't even bother charging at the field.
_____________________________
Red S. AMA 951 Leader Member
