Cougar-RCU
IA, USA Status: offline
SPEC: Input Voltage: 10- 15.0V DC Battery Types, # cells: 1-24 Nickel-Cadmium cells (1.2- 28.0V NiCd) 1-24 Nickel-Metal Hydride cells (1.2- 28.0V NiMH) 1-4 Lithium-Ion cells (3.6- 14.8V Li-Ion) 3, 6, 12 Lead-Acid cells (6, 12, 24V Pb) Fast Charge Current: 0.1 -5:0A linear (2.5A maximum for Li-Ion) Fast Charge Termination: "zero deltaV" peak detection for NiCd and NiMH "constant current/constant voltage" for Pb & Li-Ion (cc/cv) optional thermal cutoff for all battery types, use GPMM3151 Trickle Charge Current: 0-250mA (n/a for Pb and Li-Ion), automatically set by Triton (not user adjustable) based on the level of the peak charge current. Discharge Current: 0.1-3.0A (2.5A maximum for Li-Ion) Discharge Cutoff Voltage: 0.5-1.16V per cell NiCd & NiMH (0.8V j cell fixed during cycle) Pb fIXed at 1.8V per cell Li-Ion fixed at 3.0V per cell Cycle Count: one to ten cycles (n/a for Pb and Li-Ion) Battery Memories: ten battery parameter storage memories Display Type: 2-line, 32 character LCD Output Connectors: banana jacks Case Size: 6.2"x 4.0"x 2.0" (157 x 102 x 51mm) Weight: 16.4 oz. (466g) COMMENTS: To achieve the Triton's maximum potential, the power supply must be capable of delivering at least 13 amps of current while maintaining 12 volts DC.
