Volcano STX truck    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Volcano STX truck
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Volcano STX truck - 4/16/2006 7:04 PM
xxxraidernationxxx
Score: 100
Last Login: 2/3/2007
Status: offline
The truck went thru two tanks during the brake in period. But then whenver I tried starting it after that it would die on me as soon as I would put it on the ground and sometimes it would just go full throttle. Does someone know what the problem is. Im a beginner to this hobby.
< Message edited by xxxraidernationxxx -- 4/16/2006 7:06 PM >
Hide Signatures
       Post #: 1
RE: Volcano STX truck - 4/16/2006 7:14 PM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
sounds like the clutch spring and bad radio system, buy a new spring preferebly not redcat but traxxas #4146x, this is the one i used and has been fine ever since i put it in. If you have the truck less than 30 days and have made sure all the batteries are good then contact redcat an let them know about the radio problem(throttle problem) or buy a new radio, like a futaba set up. I would also say order a couple of extra spur gears if you decide to order the redcat clutch and spring, i would also reccoment to buy your redcat parts from cubbysdad on this forum, his site is clermontmotorsports.com.
< Message edited by ehroof -- 4/17/2006 6:19 AM >
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to xxxraidernationxxx)
       Post #: 2
RE: Volcano STX truck - 4/17/2006 6:09 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
thanks ehroof, if you need a part or 2 let me know. THats the least I can do for referring me to everyone. Thanks man.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
(in reply to ehroof)
       Post #: 3
RE: Volcano STX truck - 4/17/2006 6:23 AM
ehroof
Score: 105
Status: offline
no problem dennis, your a good guy and stick to your word, you ship fast, have alot in stock so its not shipped from redcat(super slow), you dont push on anyone, very helpful, and good businessman. i have only and will only order my redcat parts from you. I am sure with the way these strip spur gears and break clutch springs, you'll be in business a long time .
Hide Signatures
(in reply to Chubbysdad)
       Post #: 4
RE: Volcano STX truck - 4/17/2006 7:40 AM
Fltlander
Score: 100
Last Login: 5/31/2007
Status: offline
HAY.....CHUBBYSDAD GIVE ME UR WEVSITE ( IF U HAVE ONE ) SO I MAY CHECK OUT ALL THE REDCAT PARTS U HAVE AND MAYBE ORDER SO FROM YA..
THANX FLTLANDER
Hide Signatures
       Post #: 5
RE: Volcano STX truck - 4/17/2006 8:37 AM
jcam54
Score: 100
Last Login: 12/7/2009
Status: offline
Fitlander look at chubbysdad's post again the web site is in every post as his "signature"--last lines of posts
savage le sts d30m-savage axial 28-hellfire ss mach 28
Hide Signatures
(in reply to Fltlander)
       Post #: 6
RE: Volcano STX truck - 4/23/2006 4:41 AM
funkapotamus
Score: 100
Last Login: 8/23/2006
Status: offline
I just got my himoto, it is the same as the redcats volcano right? I had a bad clutch spring, but i got that workin. Now when i start it runs for 15- 20 secs the dies. And i have to prime it every time to get it started. Anyone know whats up, this is my first car. You can e-mail me at brad77420@yahoo.com
Hide Signatures
       Post #: 7
RE: Volcano STX truck - 4/23/2006 5:22 AM
ehroof
Score: 105
Status: offline
richen the high end 1/2 turn and see what happens. Also check glow plug. put it in the ignitor and see if the coil light up all the way thru.
Hide Signatures
(in reply to funkapotamus)
       Post #: 8
RE: Volcano STX truck - 4/23/2006 10:35 PM
funkapotamus
Score: 100
Status: offline
Hey thanks for the help, you nailed the problem right on the head. But now i broke one of my steering arms. Is there any aluminium ones i can put on or am i stuck buying the plastic ones. Also what would be a good radio to invest in for it.
Hide Signatures
       Post #: 9
RE: Volcano STX truck - 4/24/2006 1:42 AM
ehroof
Score: 105
Status: offline
stick with the plastic a arms, if they break you can replace easily, with the aluminum something else will break down the line and may cost more to fix or take much more time to fix. I would get the futaba magnum sport for it, its like $50 and is much better than the one that comes with it. You could spend more, dont know if you would want too.
Hide Signatures
       Post #: 10
RE: Volcano STX truck - 4/26/2006 5:27 AM
xxxraidernationxxx
Score: 100
Status: offline
Im attempting to inspect the clutch spring. I took the fuel tank out. I took the diff gear out to give me some room. I removed the allen screw from the engine gear. How do I take the engine gear out? Im stuck at this point?
Hide Signatures
       Post #: 11
RE: Volcano STX truck - 4/26/2006 5:30 AM
DiTi
Score: 100
Last Login: 10/16/2006
Status: offline
pull out the bell
Hide Signatures
       Post #: 12
RE: Volcano STX truck - 4/26/2006 5:39 AM
ehroof
Score: 105
Status: offline
take screw out from end of the bell, then pull the bell off.
sorry you said you took it out, just pull off the bell, it may be a little not easy because the spring may be stuck between the shoes and the bell.
< Message edited by ehroof -- 4/26/2006 5:42 AM >
Hide Signatures
(in reply to DiTi)
       Post #: 13
RE: Volcano STX truck - 4/26/2006 5:40 AM
Chubbysdad
Score: 100
Status: offline
I think for some its just easier to remove the engine. Only 4 screws..
Hide Signatures
       Post #: 14
RE: Volcano STX truck - 4/26/2006 5:51 AM
Xeller8
Score: 100
Last Login: 4/26/2006
Status: offline
You beat me to it Dennis.
1/8 Redcat Hurricane XP Buggy/.27 motor (4.43cc)/tuned exhaust
1/10 Redcat Volcano STX truck/.18 motor (3.0cc)/tuned ex
Hide Signatures
       Post #: 15
RE: Volcano STX truck - 4/26/2006 5:59 AM
xxxraidernationxxx
Score: 100
Status: offline
Taking the 4 screws on the engine was a lot easier. Thanks
Hide Signatures
       Post #: 16
RE: Volcano STX truck - 4/26/2006 6:01 AM
Xeller8
Score: 100
Status: offline
Just make sure you have the mesh set correctly and the engine square with the tranny when you put it back together....otherwise....you buy gears.
Hide Signatures
       Post #: 17
RE: Volcano STX truck - 4/26/2006 6:34 AM
xxxraidernationxxx
Score: 100
Status: offline
I matched the engine before I took it off. It's all together now and there's no binding.
Hide Signatures
(in reply to Xeller8)
       Post #: 18
RE: Volcano STX truck - 4/27/2006 6:42 AM
ryanrccars
Score: 100
Last Login: 7/28/2006
Status: offline
I purchased a redcat Volcano STX and the exact same thing happened. I have gone thru 3 clutches and the same thing happens each time. You run it on 2 tanks of gas and its done. I am trying now to get my money back but am getting no where. I am very disappointed with the product.
Hide Signatures
       Post #: 19
RE: Volcano STX truck - 5/2/2006 8:13 PM
Bobbyracer
Score: 100
Last Login: 12/17/2006
Status: offline
i am haveing trouble at hafe trottle it just quits.i gone threw the breakin period,and i am running 20%nitro. new at hobby please help.thanks
Hide Signatures
       Post #: 20
RE: Volcano STX truck - 5/3/2006 11:05 AM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
bobby, sounds like you're either too rich or too lean on the high speed needle. richen it a quarter turn first...if that doesn't make it better...lean it out about a quarter turn (to where you started), and then another quarter turn.
whichever way helps, keep going that way
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
(in reply to Bobbyracer)
       Post #: 21
RE: Volcano STX truck - 5/3/2006 3:17 PM
Bobbyracer
Score: 100
Status: offline
thanks alot i will try that.
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 22
RE: Volcano STX truck - 5/5/2006 4:40 PM
Bobbyracer
Score: 100
Status: offline
you were right it was to lean thanks.
Hide Signatures
       Post #: 23
RE: Volcano STX truck - 5/19/2006 9:43 PM
funkapotamus
Score: 100
Status: offline
I have had my Eldorada for about 2 months and i cant keep it runnin at all. When i did get it runnin i broke a steering knuckle on my 1st tank of gas, i got that replaced and now it won't run for more than 30 sec. to a min. It seems to be flooding out but no matter what i do it will not stay runnin(today it wouldnt even start for the long). I know i am new to the RC world but this is getting stupid. Anyone have any ideas, cause i am all out. thanks for any help in advance.
Hide Signatures
       Post #: 24
RE: Volcano STX truck - 5/19/2006 9:49 PM
TopSpeedToys
Score: 100
Last Login: 12/29/2007
Status: offline
quote:
ORIGINAL: funkapotamus
Make sure you have a good glow plug and try setting the needles back to starting point.
check this thread: http://www.rcuniverse.com/forum/m_4207842/tm.htm
about half way down.
Mark
USA STS Engines Dealer
Engine Mods by RBmods
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.125RCU1
