RE: SPAD Sickle with pics    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> RE: SPAD Sickle with pics
Page: <<   < prev  1 2 [3]
Login
RE: SPAD Sickle with pics - 6/10/2007 12:06 AM
cwick1989
Score: 105
Last Login: 3/24/2013
Status: offline
chow
how much did youre sickle come out to weigh with the .40 on it?
Hide Signatures
(in reply to chowclb)
       Post #: 51
RE: SPAD Sickle with pics - 6/10/2007 7:33 AM
chowclb
Score: 100
Last Login: 12/26/2007
Status: offline
hi there cwick
the sickle weighs 4pound or close to 2 kilos seems very heavy but leaves you hand without throwing it and screems off only thing is the landings are a bit hot but once you get used to that there a breeze becarful of flutter i am working on resolving the problem as we speek trying some new ideas
cheers chris
Hide Signatures
(in reply to cwick1989)
       Post #: 52
RE: SPAD Sickle with pics - 6/11/2007 9:28 AM
somegeek
Score: 100
Last Login: 10/1/2011
Status: offline
quote:
ORIGINAL: chowclb
hi there cwick
cheers chris
4lbs? Would think it closer to 2lbs to 3lbs depending on the engine and the type of material used for the fuselage. My dogfighter is on the heavy side and weighs 3lbs 11oz. Think it'd be difficult for a sickle, built to spec, to exceed 4 lbs.
somegeek
_____________________________
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
Hide Signatures
       Post #: 53
RE: SPAD Sickle with pics - 6/11/2007 9:36 AM
somegeek
Score: 100
Status: offline
Nice to see these planes can take a lickin' and keep on tickin'...
Here's my sickle in progress - built to spec. Gonna be powered with a GMS .32 (once I put some time in on my dogfighter).
Had to temporarily tape a piece of balsa to the bottom surface of the front edge to keep it straight while gluing in the balsa filler. Used balsa on the back edge instead of coro(figured the coro would crush). Wing spar is two large Home Depot paint stir sticks(22" each). Connected with epoxy and fiberglass.
somegeek
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by somegeek -- 6/11/2007 10:11 AM >
Hide Signatures
(in reply to somegeek)
       Post #: 54
RE: SPAD Sickle with pics - 6/11/2007 10:23 PM
cwick1989
Score: 105
Status: offline
Mine is a lil more than 4lbs but I did put a .40 on it plus I used 1/2'ply for the fire wall and a bigger battery so I can undersand mine weighing a lil more
Hide Signatures
       Post #: 55
RE: SPAD Sickle with pics - 7/30/2007 10:21 PM
somegeek
Score: 100
Status: offline
quote:
ORIGINAL: somegeek
quote:
ORIGINAL: chowclb
hi there cwick
cheers chris
somegeek
I will now eat my own words... my sickle AUW is 3lbs 4 oz.
Gained some weight from using standard servos for the elevons(+1 oz a piece roughly when compared to smaller servos), using an O.S. .46 AX engine and have a AA sized 5-cell NiMH pack(+2 oz vs 4 cell AAA sized pack).
Maiden report soon.
somegeek
Hide Signatures
       Post #: 56
RE: SPAD Sickle with pics - 7/31/2007 2:57 AM
MrGreenSpeed
Score: 100
Last Login: 4/22/2012
Status: offline
A Sickle using an O.S. .46 AX engine ........bring a spare pare of shorts....that thing is going to cook
Can't wait for the flight report.
Good luck on the maiden flight.
Jeff
Hide Signatures
       Post #: 57
RE: SPAD Sickle with pics - 7/31/2007 8:47 AM
somegeek
Score: 100
Status: offline
Planning to use a 10x6 APC sport prop for this plane's maiden on Wednesday. Heard of folks running 10x8s on this engine... now that'll cook! Need to order a few of those props.
Got it trimmed tonight and balanced and it's ready to shake & bake!
.... is it Wednesday yet?
somegeek
Hide Signatures
(in reply to MrGreenSpeed)
       Post #: 58
RE: SPAD Sickle with pics - 8/10/2007 7:37 AM
Bobcat1506
Score: 100
Last Login: 11/24/2008
Status: offline
quote:
ORIGINAL: MrGreenSpeed
I fly a Debut w/ an OS .40 LA and the other guys at the club fly Sickels with OS .46 AX. I make a great target. They scream.
Hide Signatures
       Post #: 59
RE: SPAD Sickle with pics - 8/18/2007 8:09 AM
somegeek
Score: 100
Status: offline
Jeff
Maiden was a success tonight! I did some last minute eyeball trimming and fired it up to adjust the mix and high speed needles - still need to spend a little more time with these. Was starting to get dark so I wanted to get this maiden in. Walked out to launch this thing - oh man does this plane pull with this engine! My dogfighter pulls away without drooping but this sickle pulls hard and kept a flat line climb. I had it at a 30º angle up from horizontal. Opened to roughly 3/4 throttle and when I let go it pretty much snapped out of my hand and by the time I got my right hand on the stick it was up there a ways. Needed three clicks of elevator and two of aileron and it was set. I did a few loops and a few circuits and then landed it. Landing is hot but smooth. Gonna check a few things tonight and then get some more flights on it tomorrow! Currently running an APC 10x6 on that .46 AX. Plan to swap that for an APC 10x8. Zoom zoom!
It was very stable in the air for this short flight even though we had a good amount of wind. I changed the design a bit to move the fin back about 7". This should help with stability.
At any rate this is my new hot rod at the field. Thinking about calling it Melba Toast (see Dazed and Confused)
Funny to think this is the same engine model I run on my Sig Somethin' Extra which I was flying this evening as well.
After I get some more time on this plane, gonna have my friend get some footage and throw a flick up on YouTube like I did for my Dogfighter.
somegeek
< Message edited by somegeek -- 8/18/2007 8:19 AM >
Hide Signatures
       Post #: 60
RE: SPAD Sickle with pics - 8/22/2007 12:50 AM
OzMo
Score: 113
Last Login: 5/18/2013
Status: offline
NICE bird
SOOOOO can you reproduce this "Maple leaf" thing?.....SPAD helicopters???
Yes dear, I did glue my hand to the airplane to keep from dropping it.
Hide Signatures
(in reply to Smooth Spanky)
       Post #: 61
RE: SPAD Sickle with pics - 8/22/2007 1:04 AM
OzMo
Score: 113
Status: offline
quote:
ORIGINAL: dasintex
John Palica; In reading your reply you suggested the following:
you epoxy 1/8 X 3/16" spruce or bass wood strips into the flutes in the coro at both the leading edge and trailing edge in the area where the fuselage slot is. The strips are about 1" long and pushed in so they're flush with the edge of the coro.
If I understand it correctly. do you insert the srtips on the inside exposed fuselage slot cut out on the top surface of the wing; not sure I understand what this does; I have on some of my SPAD's inserted a 1/8" dowel the entire length of a flute like on a coroplast aileron, or elevators; I can see inserting a dowel the entire length in the leading edge flutes in the bottom side of the wing to prevent the mounting screws from crushing the coroplast.
Thanks Doug.
bamboo skewers are the standard spad flute reinforcer but then refer to spad 101"use what you got"
Hide Signatures
(in reply to dasintex)
       Post #: 62
RE: SPAD Sickle with pics - 8/22/2007 8:12 PM
Square Nozzle
Score: 105
Last Login: 5/22/2013
Status: offline
Round peg in a square hole? I like the square peg better.
John
Hide Signatures
(in reply to OzMo)
       Post #: 63
RE: SPAD Sickle with pics - 5/29/2012 1:42 PM
3D Flyer
Score: 100
Last Login: 5/13/2013
Status: offline
Just built a Sickle and flew it for the first time this weekend. I have a GMS .25 on it. It flies pretty fast and I like the plane but I can't seem to keep it in trim. When at 1/2 throttle it pulls to the right and at full throttle it seems to pull to the left. Any suggestion?
Focus on the Fun!
Hide Signatures
(in reply to Square Nozzle)
       Post #: 64
RE: SPAD Sickle with pics - 5/29/2012 4:24 PM
Clean
Score: 116
Last Login: 5/4/2013
Status: offline
Build it straight next time?
Pull or roll?  If it's rolling then you've got a little bit of a warp in there somewhere.  If it's pulling then maybe a bit of engine off thrust and then address the alignment of the verticals.  My present Flippers are straight as a string till they get going really fast then they tend to stray a bit from the straight and narrow, it may just be one side is deforming under pressure more then the other OR that I have a bit of a warp in my building board OR that it's just really hard to get a straight, dead level wing out of a folded piece of plastic.  Doesn't really show up that much with lower speed planes but can really get to you at higher speeds.
then again, the sickle was designed for combat and in combat we got really used to flying planes that were cobbled together from other planes and the remnants of other planes.  I've flown remnants that really didn't qualify as whole planes too.  To have an airframe that is pretty much straight was good enough, they didn't stay in that condition long.
I am usually pleasantly surprised by how good these folded up airplanes can fly.  My USS simply floats on landing even without the flaps down and is a fun Touch n Go aircraft.  I can manhandle my DPS around to be a good bomb drop plane and target for the "painting crew"  and again my Flipper is just a blast.  Still, it's nice to get a good, straight aircraft made of light materials to see how nicely they can fly.
But with my schedule and the times I can get out, it's is fantastic to have an airplane I can fly all day, hang up and forget for 6 months and know that the covering hasn't sloughed off, the glue joints haven't started to let go and there isn't something broken inside that I can't replace for next to nothing.  The limiting factor for me is time not money and I have airframes that I get rid of because I want something new and there just isn't room.  Not that I haven't had airframes that needed retired as well.
You sickle, with a good engine in it, can reach the kind of speeds that will have you trimming from one side to the other if there is a bit of a warp in there.  If it's pulling one way more then the other it's the Verticals and the engine offset.  More then likely you have a bit of right rudder in there that was un-intentional and while at low speed that doesn't make much difference as the speed increases the amount of force also increases.  The amount of torque from the engine on launch will yaw and roll your airplane to the left.  Scale ships look like CL Rat Racers when you let go of them flat, they turn a good 20 degrees before the airspeed over the Vertical straightens them out.  If you put some right thrust on the engine that will help mellow out left yaw at lower speeds.  Engine side thrust effects DECREASE as a percentage of speed, the faster you go the less they matter where the aerodynamic forces of your air frame increase with speed.
Intentional landings WITH a PBF are not
the intentional design OF the PBF
Hide Signatures
(in reply to 3D Flyer)
       Post #: 65
RE: SPAD Sickle with pics - 5/29/2012 5:35 PM
3D Flyer
Score: 100
Status: offline
I think it might need right thrust ... I have none right now. I think the wing is pretty straight.
My GNAT is horrible when it comes to trim, but I guess you can't expect much from plastic. However I have a SPAD Diamon Dust that goes 90+ mph and it is perfect with regard to trim .... Maybe it is the design ... maybe it flexes too much
Focus on the Fun!
Hide Signatures
(in reply to Clean)
       Post #: 66
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
